Question about Samsung PCL545R 54" Rear Projection Television
Green convergence was bad now tv wont turn on!
Green started showing up in pictures. Now the tv wont turn on at all. Is this a convergence module problem or something bigger? If so where is the convergence module located exactly and should i replace it or just the ics on the module? I am trying to determine wether or not to keep the tv. just need to know if it is worth fixing, its a good tv when it works in really good shape.
  • Samsung Master
  • 8,617 Answers
The convergenc module is located abouve the board on the right side of the set looking in the back. Its attached to the metal frame you will notice two large STK392-040 ICs mounted to a heat sink. You can get new ICs or a replacement board at the following link for your model. leave an email if you want the convergence board and they will get back to you quickly. Heres the link.
http://servicemanuals.vstore.ca/
Posted on May 31, 2008
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Picture is not showing correctly. Color seems like it is going out. For example the color green does not show up as green.
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be change to solved the tv picture convergence problems.Try website like Tvrepairworld.com to buy a whole refurbish convergence board for the replacement.The Akai/Samsung DLP tv used the same convergence board.Or the shop,will cost u like $300-350 for parts and labors.
Nov 20, 2010 | Samsung PCL541R 54" Rear Projection...
My LG HD tv screen suddenly went green. sound is
I disagree with info provided, if screen of your LG lcd tv becomes green that means inverter board is working and lcd tv does not have convergence ICs.
Please unplug tv from ac wall socket for minute to get it reset, replug back in and turn it On and check its picture.
If still showing green screen then change input source with remote, if tv shows same green screen on all inputs that means its either lcd panel problem or digital signal processor got bad loacted on main board. Local tv repairman is needed to confirm and fix it.
Thanks.
Jul 21, 2010 | LG 42LC2D 42 in. LCD HDTV
Blurry picture, some color is off
It sound like your tv needs convergence repair. There is a couple of possible causes to this problem on this particular model. One will be a missing voltage due to a loose conection on the fly back transformer, it may cause a fuse to open; it may also be a bad convergence power supply module, or a bad convergence module.
Oct 26, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA projection TV - the picture only shows red green and yellow and the picture is distorted almost concaved. It overlaps and nothing is clear. All 3 bulbs seem to be working. No idea what is wrong.
Sounds like convergence problems. This TV may not have the standard "STK.." modules. These sets are bad to lose voltage feeding the convergence amplifiers.
Mar 31, 2009 | RCA P52926 52" Rear Projection Television
By the picture that you have supplied with the question you have a rear projection tv. The problem you are describing sounds like you have had the convergence module in your tv fail. Depending on the age and make of the tv, the repair costs ( if out of warranty ) can be prohibitive. The convergence module on rear projection tv's not only is in charge of bringing the 3 different color images together into a watchable picture but also handles the east west correction ( concave / convex aspect to the picture or lack there of ).
Jul 02, 2008 | RCA R52WH73 Projection Television
Bad convergence, now wont turn on at all.
The convergence ICs have failed and thats what is shutting the set down. You will need to replace both convergence ICs they are STK394-250 you can get replacement ICs at the following link with free shipping and free instalation instructions with pictures s you can do the repair yourself. Here is the link.
Jun 30, 2008 | Mitsubishi WS-55311 55" Rear Projection...
Pt5598 rplaced convergence board no luck.
If the picture is still bowed, the power supply fuses are open.
Check the power supply on the red connector for + and - 20 volts.
The fuses are on the main board,are on the deflection module in the middle, tward the front of the TV. They should look like green (or brown) resistors. An ohmmeter check will show which ones are bad.
They should be 3.5 amps. Replace with 4 ohm GMA fuses with pigtails if you can't find picofuses. I also had a set that would fry the 1 ohm resistor on the 20 v supply. This was near the fuses.
I replaced the whole module to fix that.
I hope this helps. Lee, www.crazycomputers.com
May 31, 2008 | Akai PT5598HD 55" Rear Projection...
Does not turn on
you probably had a bad solder connection on one of the convergence modules, it's a common problem with projo tv's. that loose connection finally got bad enough to cause a short in the module, and that's what is sending the power supply into shutdown. have it fixed, and have them replace all of the convergence modules, not just the bad one. if one went out, the other(s) (there are 2, sometimes 3 of them) are the same age, and likely will also fail soon. ...... gee i was looking for a picture of one of those modules, but can't find one. well, anyway the modules are on large pieces of finned aluminum (heat sinks), and are about 3-4 inches wide, 2 inches tall, 1/2 inch thick, are usually black plastic, and have about 20 wire leads coming out of the bottom going down to the circuit board.
Jun 29, 2006 | Mitsubishi VS-5043/44 50" Rear Projection...
Samsung PCL545R 54" Rear Projection Television Logo
62 people viewed this question
Jerry Greenberg
Jerry Greenberg
