Question about Electronics - Others
Laptop not recognize wd1200u017 004 usb driv e
I received a gift of a WD1200U017 004 WD Passport May 11th. It works great when plugged into the USB port of my desktop Macintosh G5 computer but is not recognized by my laptop (Mac PowerPC, G4, running Mac OS10.04.11). . .in the past, I have used thumb drives on a regular basis, with no problem.
  • 1 more comment
  • slynasity Jul 04, 2008
    I have a DELL XPS M1530 / Vista OS. My wd1200U017 used to work with it without a problem. Today I hooked it up and it didn't show in the "My Computer" window. However the light comes on and it says it's working fine. I have tons of important things on it that I can't retrieve now :( It was given to me as a gift in September 2006. I had the same problem with my laptop Dell which was an XP operating system. I had to reconfigue it and lose what I had. I don't wish to do that this time. Please help? My email address is slynasity@yahoo.com
  • kwh6 Sep 18, 2008
    same, testet on five comps, dont work
  • eudoro Oct 24, 2008
    Lo mismo no me reconoce mi WD en mi ordenador, aunque si en mi Lap Top y no se como solucionarlo, alguna ayuda please a chuleesprella@hotmail.com
2 Suggested Answers
  • 77 Answers
SOURCE: I can't use my external HD
Do you have any kind of security software/firewall installed? It will often block hard drives because it sees them as a security threat. Disable the firewall or security should do the trick.
Posted on Oct 19, 2008
I've downloaded documents & pictures on my passport yesterday. Everything seemed to work OK. I did however, have to plug it into the USB port twice to get a connection. I'm quite sure the downloads...
Sometimes, portable drives need more power than a USB port provides. If this is a laptop, be sure it is plugged in to power and not running off battery. Also, if you have TWO usb plugs on the end of the wire, plug them BOTH in. This provides the extra power needed.
Mar 19, 2011 | Western Digital WD Passport 250GB Portable...
I have a WD passport 320gb, at first it worked one of my usb. then all of sudden, it stop recognizing my WD Passport with one usd port, so i plug it in another usb then it works. and after a couple of days...
Are you using an external power supply for the disk? If not, you might be overloading the USB port. It should not happen, but USB ports are limited in the amount of power they can output. Especially laptops might face such problems.
Do other USB devices still work on those USB ports? If so then the port is at least not broken.
Sometimes you can uninstall and reinstall the USB hubs and controller devices in the Device Manager to fix USB problems.
For other ideas on troubleshooting external hard disk issues, you can check: www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Jun 13, 2009 | Western Digital Passport WDXML800UE...
USB ports on my laptop and others wont recognize my 320GB Passpor
ok
go to your computer bios setup .
U can go to bios with "del" or F@ oe any key for enter in bios setup then go to usb configuration then set high speed and legacy 2.0 enabled then save alls ettings .
May 03, 2009 | Seagate Snow Translucent...
My computer does not recognize WD Passport WD2500XMS-00
I use a USB extender cable so I do not have to get down on the ground and plug stuff into my USB ports behind my computer. Everything that I own works through this cable except the WD passport drive. (It is a 2.0 USB cable at that so that is not the issue, plus 1.0 should theoretically still work, just not at 2.0 speeds)
SO...I tried to plug it directly into the USB port on the back of my computer and it worked instantly.
Other people have reported a fix after finding that their cable was loose. This USB cable that comes with the drive seems to be picky for some reason. Perhaps these are faulty cables somehow. Hopefully this will help some people.
lefteris from greece
Mar 26, 2009 | Computers & Internet
Ibm t43, xp pro won't recognize my WD 320 passport
Well, that IBM is from 2004, the usb port and drivers is to old for the WD 320 who requries USB 2.0. Thats why your IBM dosent recognize it, your IBM getting wrong signal from the WD thrue the old usb port.
I dont think you gona make those items to work properly togher M8, sorry
Nic
Feb 06, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Oct 19, 2008 | Electronics - Others
WD Passport appear as an unknown device
try it again, after going to wd dot com, and getting and installing a new set of drivers..
Oct 13, 2008 | Western Digital Computers & Internet
My PC is not recognizing my WD Passport 120GB USB external drive. I used just few days ago and connected the usb cable to my computer and the WD Passport drive and not recognized on my 2 laptop and 2 other...
I have the 80GB WD passport and it suddenly stopped working one day.  The unit lights up but nothing else.  Finally I cracked the case open and found, as I suspected, that the drive is simply a SATA laptop drive with a SATA-to-USB conversion card built in.  I suspected that the card was **** so I disconnected it and used a USB hard drive adapter (http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=3770&name=USB_Hard_Drive_Adapter) and I can read/write to the drive just fine.  Best part is that the adapter I use has its own power supply so I'm not pulling juice through the USB cable for a SATA drive.
Even though mine "works" again I don't recommend these drives to anyone.  They're just not sturdy enough or well designed.
Sep 09, 2008 | Western Digital Passport WDXML800UE...
I had a similar problem with my WD passport 320GB. When I connected it to my laptop it never showed up on My Computer even though the blue light on the hard drive came on.
Here is what I did:  Right click on "My Computer" and click on "Manage" and then "Disk Management",. you should see your WD hard drive listed. then click on "change driver letters and paths"  and change it from the listed to another drive. I changed mine from G to F drive and it worked for me.
Jul 29, 2008 | Western Digital Passport WDXML800UE...
WD Passport Portable Hard drive 250GB
It could be that your computers do not put out enough power in the USB ports. (Apple laptops are notorious for this). You can call up Western Digital and tell them that it is not working and they will send you a free dual USB cable. This cable has one plug for usb power and one for data so the drive should work with it (although it will use up 2 of your USB ports!!).
Mar 05, 2008 | Western Digital Passport WDXML800UE...
Electronics - Others Logo
1,192 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
