Question about Maxtor OneTouch 4 Mini 160GB External USB 2.0 Hard Drive
The cable, where it slots into my hard drive has come apart, (the metal sleeve is loose) and is no longer even lighting up the drive, I've not been able to find where to buy a replacement, or what the correct name to call it, and I have a lot of important work backed up on it, help please.
  • j_symmons Dec 12, 2010
    Fantastic, that looks exactly the same. I'm ordering it right away.
    Thanks, June. ;o)
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 198 Answers
This one looks justt what you want and is only £3.25 post free!
http://cgi.ebay.co.uk/USB-Y-Cable-Lead-Maxtor-2-5-External-Hard-Drive-HD-/130416497157?pt=UK_Collectables_HardDriveEnclosures_RL&hash=item1e5d6dd205
Posted on Dec 12, 2010
Motherboard fails to identify any hard drive (4) tested ?
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Shut down the computer.
Unplug all cables and peripheral devices.
Clip the anti-static wrist bracelet to a metal object, and attach the bracelet to your wrist.
Remove the computer's side panel. (Cases vary. Some will require a small Phillips screwdriver for removal and others feature screwless designs.
Please see your case manual if you are unsure.)
Locate the newly installed hard drive.
Check that two cables are running from the hard drive to the motherboard and to the power supply.
If you see only one cable or if either of the cables are not securely seated, plug in the appropriate connector(s).
Leave the case's side panel off for now. Reconnect the power cable, monitor cable, and keyboard and mouse connections.
Restart the computer. Enter your BIOS immediately.
(Your BIOS usually alerts you to the key required to adjust settings).
If your screen does not show this information or if you are unsure, consult your motherboard manual.
If it is an IDE hard drive, enter the IDE settings.
The BIOS should show the hard drive.
Configure it as primary or secondary, according to your computer's configuration.
(If you have only one drive, set this to primary Otherwise, set as secondary.)
Save your settings, and exit the BIOS.
I would also be check RAM
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Use compressed air to blow dust away and clean contacts with a soft cloth.
Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components.
Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r
Allow the pins to dry. They will air dry in a matter of minutes
If reseating the memory did not resolve the issue try swapping the location of the memory.
If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
Check the memory module and memory slot contacts.
They are either copper tin or gold.
The colour will tell you which they are.
Mixing tin and gold can result in corrosion that prevents proper contact.
Look for any sign of physical damage to the memory module, memory slots or the motherboard.
Reseat the memory modules.
You should hear an audible click when they are in place.
Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard.
Once you are certain that the the PC is recognizing the hard drive, replace the side panel.
Hope this helps.
Nov 16, 2012 | ASUS P5S800-VM Motherboard
Hi i bought WD 320 gb sata /8mb hard drive - the cable ribbon on my dell 4600 does not plug into it! do i need a different cable yes
Generally speaking, we have two types of hard disk interface. IDE (the old one with ribbon cable) and SATA (with a 1cm strip like cable).
As your new hard disk is SATA, you need a SATA cable to connect it to you PC.
Below are a few images which would help you.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 23, 2011 | Western Digital WD Caviar Blue WD3200AAJS...
Ive had my book for a while now and my life is on it... it was working fine and now i plug it in and nothing happends... it wont spend and the blue light wont even come on.... i check the cables and the...
#1 MAKE SURE THAT YOU HAVE ENOUGH LIGHTING .....I KNOW BECAUSE I'VE DONE THIS. I PLUGGED THE DRIVE SIDE USB INTO THE LOCK SLOT IN BACK OF DRIVE INSTEAD OF THE CORRECT SLOT......HOPE THIS HELPS..........JEFFXC
Feb 07, 2011 | Western Digital My Book Essential 1TB...
Trying to replace fr & rear shifter cables can not get hand shifter apart to put in new cable
You shouldn't have to disassemble the shift levers. Remove the cable from the cable clamp at the business end. Push the cable a bit toward the shift lever. The little barrel end of the cable at the lever end should raise itself out of the lever, then you can just pull the whole cable out. Make sure your replacement cable and cable sleeve are about the same length as the originals. The new cable can be longer because you can cut it off later, but the cable sleeve should be pretty close to the same length as the original - maybe 1/4 inch longer would be ok.
Aug 19, 2010 | kawasaki Cycling
Not playing on the screen. green light is lit,
Remove all Smartridges, controllers, adapter or batteries.
Examine the Smartridge slot for loose objects, Blow into it to
remove dust or debris.
Pull back the plastic sleeve on the Smartridge and clean both sides
of the metal contact with alcohol and a cotton swab.
Insert the Smartridge into the Smartridge slot and remove quickly
twice without turning on the V.Smile unit.
May 15, 2010 | Vtech V.Smile TV Learning System
I'm getting a code 10; cannot start device on my maxtor 3200 . The power light is on, but it no longer functions.
What is wrong with your drive is probably what was wrong with my drive. After two whole days of gut wrenching about should I or shouldnt I take the darn box apart , I took it apart figuring well it is a code 10 and Seagate ( bought maxtor) tells you that the drive has probably failed.
I took mine apart and found a printed circuit board that was attached to a standard IDE drive. I took the board off and plugged the now IDE drive into a spare IDE cable and power connection, turned on my computer and crossed my fingers. Lo and Behold the "CODE 10" DEAD HARDDRIVE WAS ALIVE!!! my guess is that the circuit boards overheat as their are very little air flow slots for this drive and something lets go between the hard drive and the connections. So dont throw it away , carefully pry open the plastic case and remove the hard drive and the printed circuit board ( you have to unscrew the metal cage around both and take out the 3 screws in the printed circuit board. then carefully separate the board from the hard drive . At least you should be able to recover your data on the hard drive. I ran a quality test on the hard drive after I copied all the files from it and there is not one sector wrong on the whole drive. This may not be the solution you are looking for but in the least you are not throwing away a possibly good hard drive. Patience is the rule in prying the case open ( I did it with two medium screwdrivers and started at the hole in the case near the connectors that is rectangular in shape. I too had the lights are on but nobody's home syndrome. Good luck
Aug 05, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
External USB Drives No Longer Detected
There are two possibilities:
The Mybook USB/ATA controller board is faulty.
In this case you can simply take apart the enclosure and mount the disk into a new enclosure. WD Mybooks are SATA, but double check the hard disk connector to ensure.
The hard disk inside is faulty.
In this case repair may be expensive. You need to locate a data recovery facility with a 'clean room' , the cost is usually more than $800.
If this happened after a power surge, then the problem is most likely a faulty controller board.
If instead you have dropped the hard disk it is possible an hard drive failure, in that case repair will be expensive.
A replacement enclosure will stfrom art about $20 on Ebay or Amazon, and must not necessarily be WD .
Check if your disk is Sata or PATA (IDE) before buying the enclosure.
Apr 22, 2009 | Western Digital 320GB MyBook External USB...
Dropped the 'My Book Essential' 500MB, now doesn't work
ok wow i dont even think i dropped mine but it doesnt work.. like the light flashes when i plug it in but then it isnt recognised...
Feb 03, 2009 | Western Digital My Book Essential 500GB...
WD 500 GB Hard Drive just stoped working, It has the alternating blue lights in front, now as soon as it powers up it turns off - the alternation blue light don't even come on I still had 316 GB left on...
I had the same exact problem for a while and I think it's a problem with the slot where the USB cable connects to the HDD. I eventually just took a small knife and pushed in the metal tabs around where the cable connects as they were pushed out from the cable being pulled at random angles before. Somehow it works perfectly now, so I guess it just wasn't detecting a computer or in this case an xbox and automatically powering down to save electricity and heat. Anyway I just thought I'd share my experience, good luck with your HD!
Dec 14, 2008 | Computers & Internet
LaCie F. A. Porsche Hard Drive
Try this...
use a long bladed kitchen knife to get carefully spread apart the sides from the bottom plate. there are 4 small tabs along each side of the case going int 4 slots on the bottom plate. The long sharp blade inserts easily between the side and bottom plate.
Carefully pry the side away from the bottom plate starting from the front working towards the back. You gently twist the blade to get the tabs out of the slots. the first one is the hardest. After that they pop out easy.
to remove the hard drive mechanism, once you have the bottom plate off, remove the four silver screws--two along each side--then use the knife to separate the sides of the hard drive from the case, so that the front of the drive is angled up (you'll also have to pull the activity LED loose from its hotmelt glue), then slide the drive out of its metal mounting bracket--you won't be able to pull the drive out along with this bracket.
Jul 11, 2008 | LaCie F.A. Porsche (301177) Hard Drive
Maxtor OneTouch 4 Mini 160GB External USB 2.0 Hard Drive Logo
154 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
