E3EB-015H Nordyne™ Electric Furnace...this is only a 6 year old system and thanks to lovely weather, we have had the thermostat on OFF for about a week. we hear a buzzing sound coming from the closet furnace....there are 2 switched on the system and when i cut off switch "A" the buzzing stopped. when its on and the thermostat is off, there's the buzzing. the heat and a/c both work fine. what is the buzzing and can i do something myself??? thank you
Buffalo12980
  • 625 Answers
SOURCE: Heater won't shut off.
you say you hear a click. this indicates the relay is opening and closing, BUT the contacts may have welded itself shut. try replacing the relay - contactor.
Posted on Nov 15, 2007
  • 18 Answers
SOURCE: Furnace will not come on, need heat!
birds nest or spiders. could also be a partial pilot tip plug.
Posted on Jan 05, 2008
Master_Tech
  • 770 Answers
SOURCE: furnace problems
On - OK
1 Blink - Ignition failure. Check Gas flow, gas pressure, gas valve, flame sensor.
2 Blinks - Closed pressure switch. Check pressure switch (stuck in closed position).
3 Blinks - Pressure switch - failre to close. Check venter, pressure switch, vent blockage.
4 Blinks - Open limit switch. Main limit or aux limit are open. (My comment - Means overheating in chamber. Often result of blocked intake air. Bad filter. In my case, plastic wrap had been sucked into the intake. )
6 Blinks - False flame sensed. Check sticking gas valve.
Rapid continuous blinking - Incorrect twinning, incorrect primary polarity. Reverse transformer secondary leads, reverse primary wires.
Closed pressure switch can be from dirty combustion vents, bad chamber pressure - like missing screws, maladjusted gas pressure, failing pressure switch, loose hoses, moisture in the hoses or fan blades The switch need to be closed to ge the unit to work
Posted on Jan 23, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: Goodman GMS90904CXA Wont ignite, light blinks 3 times
Ok, you either have a inducer fan issue or a pressure switch issue or a plugged vent pipe. The inducer turns on to establish a draft for the exhaust. If it is not working you will get this error code. If the pressure switch does not sense pressure caused by the inducer, it will give this code. If either the intake pipe or exhaust pipe is blocked (even y just a little) it will give you the same error code. If the condensate hose or receptical is plugged, again it will give you this error code. Good Luck!
Posted on Oct 21, 2008
boanhtgclg
  • 34 Answers
SOURCE: New honeywell thermostat on new gas furnace not working
sometimes there's a differential setting anywhere from 1-3 degrees, see if you can make sure it's down to 1
Posted on Nov 12, 2008
I have a nordyne furnace model # e3eb-017h. Furnace doesn't kick on at all. No relay click or anything but it's getting power. Did the thermostat trick with touching wires together to kick on the furnace...
Check the pilot light sensor. Have seen this issue before. Sometimes after lighting need to hold it in longer. If it doesn't detect the lit pilot wise it will sit in safety shut down mode
Oct 28, 2014 | Heating & Cooling
My intertherm e3eb-015h electric furnace will not do a thing even temp.on thermostatdont show up breakers are on still nothing
Check to see if the fuse is blown. If it apprears to be blown, replace it. It is inexpeisive and simple. If you locate the fuse, you will be abel to determin if it is blowin becuase you will be erruption or a burnt mark in the fuse wires.
Sep 21, 2014 | Heating & Cooling
Wiring diagram for electric furnance model E1EB-015HA
THIS IS THE WIRE DIAGRAM FOR THE NORDYNE E1EB-015HA UNIT.
Feb 14, 2012 | Heating & Cooling
How do u wire athermostat to the furnance and ac unit on model e3eb-015h nordyne
You need to get low voltage wire known as 5 wire. run wires thru wall to stat and furnace Red wire goes to R terminal white to W terminal Green to G terminal Yellow to Y terminal on both the stat and furnace circuit board. Now you need a wire called 2 wire low voltage wire run that from furnace circuit board to outside A/C. At furnace hook red wire to Y terminal and white to C terminal doesnt matter which ones you hook up at outside unit. Do it just like i told you this will work properly.
If this helps please rate me.
May 20, 2011 | Heating & Cooling
Anyone have a wireing diagram for a nordyne E1EH-015HA
Intertherm does not offer a wiring diagram for the E1 series anymore. So I have included a link to the E2 series. They are very similar and you may find this service manual helpful for whatever problem you may be having.
http://www.nordyne.com/literature/359a.pdf
Apr 11, 2009 | Heating & Cooling
Furnace blowing cold air
Nordyne Furnace, pilot is lit, thermostat is reset, Heater is on but blowing cold air.
Mar 28, 2009 | York Furnace Draft Inducer Blower Fasco #...
Heating & Cooling Logo
287 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
