Question about Bunn VPR Coffee Maker
I inherited a Bunn VPR and the water tank sounds like it has rock deposits rattling around in it (probably scale deposits). I believe it's going to need removing the tank and emptying out the contents. What do you suggest?
    Sergeant:
    Novelist:
  • 193 Answers
It may just be the sound of the water heating up. A lot of times when the heater element first comes on, it makes crackling or popping noises inside the tank. If you want to look into the tank, its fairly easy to get into it. Take the four screws off the top, You can lay the top off to the side carefully without disconnection the top element. Or carefully unplug the two wires connected to the top element. If you are not very careful, you will break the connectors loose, and its almost impossible to repair the connector. You will see a flat tank made of plastic with about a 1 inch nut with a hole in the middle. Take the nut off and the washer under it. Be sure to put it back in the same order it came out. You will see the top of the tank. There are two rubber bushings with cap tubes sticking out of them. Pry these two rubber bushings loose and carefully pull the cap tubes up and out of the tank. You are now able to look into the tank. If it has a lot of scale in it you can put vinegar in it and let it sit for an hour, turn the whole coffee maker upside down and pour it out rinse it several times and put it all back together. My suggestion would be to leave it alone and descale it by putting vinegar into the tank through like a pot of water and let it sit for an hour and then flush it until it no longer smells like vinegar. My gut feeling is that it is the sound of the element heating up normally.
Posted on Oct 11, 2010
Overflows when pouring a pot of water in it's a commerical two burner
Remove sprayhead and run a deliming spring into the brew tube.Push spring into tank to remove line deposit.Try brewing it now.
Jan 27, 2011 | Bunn VPR Coffee Maker
On a Bunn VPR why is the water boiling out the top of holding tank?
This brewer has a dial type thermostat inside the top lid. I believe a small counter-clockwise turn (about 1/16 turn) should lower the maximum heating of the brewer. If the brewer is old you may need to replace the thermostat AND the High Limit thermostat... the small "button type" device on the top of the tank with wire to and from the heating element.
Oct 19, 2010 | Bunn VPR Coffee Maker
How do youclean the water resevoir
remove top cover; remove pouring tray via large nut in center; disconnect heating element and thermostat; remove tank lid via nuts; unscrew basket sprayhead and nut underneath. remove tank lid ***'y. dump all that water inside tank; along with all the calcium deposits on bottom. refill tank and reassemble. take care in not overtightening the tank lid nuts; as it will squash the gasket.
Aug 24, 2010 | Bunn VPR Coffee Maker
I have a Bunn VPR, it brews fine for a couple pots
Try running a quarter-pot 50/50 solution of white vinegar and cold water through to clean out calcium deposits in the pump system. Use a clean filter to catch the pumped debris. When pumped through, let cool somewhat, and reuse the cold mixture again twice more. Pour out the vinegar solution and run several cold water loads through to wash out the taste. Hope this helps!
May 24, 2010 | Bunn VPR Coffee Maker
Our Bunn VPR coffeemaker takes a LONG time to heat up the water. If we don't wait several hours between pots of coffee, the coffee is luke-warm at best. Does this sound like a heating element or...
We left vinegar in the coffeemaker overnight. Seems to have done the trick - water is heating up now after 20 or so minutes instead of several hours.
Jan 05, 2010 | Bunn VPR Coffee Maker
I pour water in my Bunn VPR coffee maker and it does not come out of the sprayer.
you need to take it apart and clean it out. hard water is horrible on these machines. once every three to four months we clean ours. take the top off and you will see all the calcium deposits. need to clean it out. you can use CLR, just make sure you run the hell out of it before serving. you may need to let it sit over night once you get the majority of it out. after that you can run "brew-right" through it. just follow directions
Jul 29, 2009 | Bunn VPR Coffee Maker
Adjusting the temperature
Our Bunn VPR was delivering luke warm coffee. The problem was lime scale buildup on the heating element. I recommend using a cleaner such as Brew Rite or a vinegar solution. If it still does not heat properly, unplug and remove the heating element for cleaning. This corrected our problem.
Jun 17, 2009 | Bunn VPR Coffee Maker
Water leaking our bottom of machine
Hello. Anything can be fixed, its how much do you want to pay ? :)
Anyway, it sounds like the tank basin fitting is clogged, or blocked by something, or scale build up. Take the lid off, unplug first please, then look down into the hole in the basin. This should be open to allow water to go into the tank, clean if not. The pipe to the spray head, up under the funnel may be clogged also, there is a "deliming spring" that is supposed to be used to keep this clean/clear, you can get from Bunn, or a local servicer found under "restaurant equipment repair". If you don't have one, a spring, you can use some wire, not very big though, it has to make 2, 90degree bends, about 18 inches long.
Hope that helped, and thank you.
If you need further help, "ask me"
Apr 19, 2009 | Bunn VPR Coffee Maker
Bunn coffee maker leaks water
There are 3 seals in your unit that could cause your problem. there is a silicon seal right under the pour-in tray, and two on the top of the tank. one of those is for the thermostat, the other is for the sprayhead tube. any of these could leak, causing water to come out the bottom of the brewer. One other thing that can cause this is a scale buildup between the pour-in tray and the tank.
Jan 12, 2009 | Bunn VPR Coffee Maker
BUNN VPR
It sounds like the tank isn't full. Unplug the machine and make sure there is a pot underneath to catch water. Pour clean water into the tank until it starts flowing out. Plug the machine in and let it heat up. Then try brewing coffee.
The way your machine works is that there is a holding tank for the water and it isn't actually brewing with the water you just poured in, it is using the holding tank water. If the holding tank gets low, and you pour water in all it does is fill the tank but nothing will come out.
Hope this helps.
Jul 19, 2008 | Bunn Pour-O-Matic VPR
Bunn VPR Coffee Maker Logo
85 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
gbob59
evans_lloyd
Level 1 Expert
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
