Question about RCA P52926 52" Rear Projection Television
I have a model P52720BA RCA 52" TV chassis # PTK16PFB. when i turn it on, sometimes the picture comes on, then a pop noise and it tries to restart or just the picture goes out but still have the sound. If tap on the lower board to the right from the front of the TV with a stick, everything starts working OK. does this board need to be replaced. A little brown/Black can type cylinder in the board seems to make the picture jump when i tap it?? looks like a mother board that slides out from the chassis. Thanks for any help. Den
  • RCA Master
  • 5,138 Answers
Bad FBT flyback Transfomer or high voltage trippler block.
Mats Electronics 1-800-628-1118 CK hori output Transistor.
Posted on Oct 11, 2010
Power wont come back on TV
the most common component to fail with that sympton is the flyback. If the chassis is a ITC222A the flyback will be 259296 or 265409 as they were both used in that chassis and model number. If you need more assistance let me know the Chassis number from the tag in the back.
Mar 13, 2009 | RCA R52WM24 52" HDTV Projection Television
52 inch RCA TV Model P52755BA about 12 yrs old
probably you have glycol leaking on the anode lead, in one off the pic tube, check for wets spots, or pay attention on the chassi where the hv leads are located, be careful
Nov 23, 2008 | RCA P52926 52" Rear Projection Television
RCA 52 PROJECTION TV MODEL P52151WK
No , if fuse was blown you would not get the popping. How old is unit ? It sounds like your high volt splitter. common problem with rca. repair should not cost more than 250.00. you will want to have chassis number  and manu date for help
www.classtorations.com
Jun 04, 2008 | RCA P52937 52" Rear Projection Television
52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Apr 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P52937SG 52" TV Made March 2002
youre having deflection problems could be related to the flyback. But this type of repair is better off with an experienced tech that has the proper equipment and knowledge to diagnose this chassis
Apr 06, 2008 | RCA P52937 52" Rear Projection Television
Will not turn on
Does the set make any sounds. DOes the front green led light or flash when you try to turn it on.. if not then it could be as simple as a fuse, if it does flash then it can be many problems
Jan 06, 2008 | RCA D52W19 52" Rear Projection Television
RCA P52920BL
F32 or F36650 = same transformer = 257805 or Asti 2078
P52920BL = need service number = P52920BLXXX then I will
confirm flyback part #..................................T.
Dec 26, 2007 | RCA F36650 36" TV
Tv not working
Probable bad HV divider block, part # 205064 ?
Need accurate info = Model / Chassis # 's........T.
Oct 28, 2007 | RCA P52926 52" Rear Projection Television
RCA P52920BL
i'd like to help.that model# looks familiar.but that chassis num you gave looks more like a serial num all my rca prints go buy chassis # is there anothe num like ctc197 exet or ptk19 doc
Aug 25, 2007 | RCA P52921 52" Rear Projection Television
RCA P52926 52" Rear Projection Television Logo
103 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
