Cell Phones Logo
Posted on Oct 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I HAVE NOKIA 7510 NOW PHONE WAS NEAR ABOUT DEAD (RESTART WHEN NOKIA'S LOGO APPEAR) I WANT TO FORMAT MY CELL PHONE WITHOUT STARTING MY CELL
Anonymous
Level 2:
Sergeant:
  • Expert 172 Answers
  • Posted on Oct 11, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
172
Questions
0
Helped
20157
Points
548
It can only be formatted using a gadget for cellphone connected to a pc
1helpful
2answers
My nokia 7510 mobile isn't openeing it's just flashing (the screen) i wanna format it while it is closed,,how??
SOLUTION FOR NOKIA 7510 (won't turn on/flashing black and white screen)
Remove the battery
Press the power button for few seconds
Install the battery back on
Turn the phone back on
it should work that how i did to my phone
2helpful
Format nokia 7510 supernova
hi :) format n7510 by yourself just key in *#7780# key in code 12345.
goo luck
I have a nokia 7510 that the screen quit working is there a fix for this?
white screen appear? check first the flex connected to the LCD
I cant start my phone, only the Nokia logo will appear.
you must format your phone...press GREEN,* and 3 simultaneously while turning it on..do not let go until hands appear..
Nokia Logo and Restart
take it to the near shop and reinstall new software
My phone just went dead. . . and formatting codes doesnt work. . .
i had the same problem, i updated the firmware on the phone, if you go to the nokia website it will say how to do this.
basicaly you download the nokia updater but you have to have the data cable and nokia pc suite it backup your phone.
i have done it a few days ago and instead of starting up after 5-20mins, it starts up straight away and doesnt stay on the white background, i hope this helps
2helpful
2answers
N73 hangs while starting up
The method of performing a hard-format, i.e resetting it completely to factory defaults and removing all data, is as follows:
  1. Switch off the phone.
  2. Hold down the following three buttons: Green (call answer) button, * button, and '3' button
  3. While holding these buttons, press the power button and switch on the phone
  4. When the message 'Formatting' appears on the screen, release all of the buttons
Note that you shouldn't switch the phone off or remove the battery when performing either of these operations, and it's advised that the handset has a reasonable amount of battery charge before performing a format/reset.
Problem with nokia 6600 startup
I the 3button format failed, the only solution left is to format/SW flashing through a flasher.
Apr 02, 2008 • Nokia 6600
6helpful
2answers
Nokia N70 phone white screen and Hangout problem
hi there you've go a software problem there try this manual formating somtimes it works but if not must go now to any nearest service center to reprogram your phone. ok!
so here's the tricks to format....
power off the phone first then PRESS and HOLD
"CALL KEY" + "* KEY" + "3 KEY" then power on the phone just hold and wait till NOKIA LOGO appears then release. finish, phone will be ok. you will know that you successfully format the phone cuz' all your data form the phone will be back to normal.
ok!
peace!
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
