Question about HP Pavilion DV7-1232nr Notebook
I recently did a clean reinstall of windows 7 on my dv7 1232nr notebook the quick play button and other touch buttons above the keyboard no longer work. How do I get them to work.
    Sergeant:
    Champion:
  • 233 Answers
You can download all hp drivers for your notebook at www.hp.com this should fix your problem.
Posted on Jan 29, 2011
How unlocked my COMPAQ presario 2500
Could be aid this?(crop from the official manual):
To lock your notebook
To protect against unauthorized access while your notebook is running, lock thenotebook before leaving it unattended, or set up a screen saver with a Windowspassword.
You can lock the notebook these ways:
• If a One-Touch button is assigned to Quick Lock, press that button. The fiveOne-Touch buttons are located above the keyboard.
-or-
• Press CTRL+ALT+DEL, then select Lock Computer.To unlock the notebook,
follow your normal logon steps.
Aug 08, 2015 | Compaq Computers & Internet
My dv 3 was originally running Vista-64, however because off the huge number of bugs I was encountering I decided to upgrade the OS to Windows 7 32-bit. It runs like a dream and ha been a nearly flawless...
There are some items that will need to be updated to the new OS. I am including a link to HP's website. I would look at the driver section (there is new drivers for the quick launch), and the software solutions. In fact since these will be the most updated driver and software patchs for Windows 7, I would probably download most of it. Hope this helps and fixes the glitches you seem to be having.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=4062&lc=en&cc=us&dlc=en&sw_lang=&product=3860372
Jul 22, 2011 | HP Pavilion Dv3-1075us Notebook
My computer is automaticlly turning down the volume and the Quick launch button for turning down the volume is flashing, as if you're pressing it.
it sounds as though the quick launch button is stuck down, have a look around the button to see if there is a build up of anydirt around the button which is causing it to stick, if you can get a pin down the edge of the button you may be able to gently lever it up so it no longer being activated.
Hope this helps
May 09, 2011 | HP Compaq 6730b Notebook
I have Asus G73SW and after replacing primary disk with SSD, instaling Windows 7 Ultimate x64 and all the drivers from Asus Drivers CD the keyboard backlight (and also the lighting underneath the display)...
I recommend reinstalling Windows using the original recovery media from Asus. That should have all of the original drivers and software needed. You can alway upgrade to Windows 7 ultimate after that.
Mar 23, 2011 | ASUS G73JW-A1 Notebook
My quick play buttons do not function properly ! example - The mute, volume, wireless, skip track play/pause and stop buttons do not work at all ! I tried installing an update but then my music didnt...
HP Pavilion DV6-1359WM, has a volume control touch pad area located at the top. It's not a driver issue or a setting. This is how you fix it. It worked for me and for some other people....
1. Shut down your laptop.
2. Unplug the power.
3. Remove the battery.
4. Push and hold down the power button for 30 seconds.
5. Reinstall the battery.
6. Plug power back in.
7. Boot
Enjoy :) brought to you by high DanK Inc.
Nov 06, 2010 | Microsoft HP Pavilion DV6276US Notebook PC
Touch Sensitive buttons on Lenovo U330 won't work with Vista...
If you upgraded your OS to win vista you need to download lenovo energy management driver for the touch sensitive buttons to work. All you have to do is to go to http://consumersupport.lenovo.com/en/driversdownloads/drivers.html
enter the serial number of your u330 and hit search. Once you're at the drivers and software page for u330, scroll down until you see the category power management. Then download energy magement. Make sure you are downloading the driver that is compatible with your operating system
Jan 21, 2010 | Lenovo IdeaPad U330 - 22672BU PC Notebook
Hp Pavilion dv2601tx Quick play not working
uninstall with revo uninstaller and install 3.2 back
Oct 25, 2009 | HP Pavilion dv9000z Notebook
Hp laptop touchpad for cd and wireless conet. stopped working
I get it. The multimedia keys above the keyboard is not working. If I'm right, check if you have installed the HP Quick Launch buttons software. If not check in C:/SwSetup and you'll find a folder. Install the application and check if the buttons are working. If not, post back
Jun 24, 2009 | HP Pavilion dv4000 Notebook
Keyboard
From the Dell D620 Users Manual:
You can use the Mouse Properties window to disable the touch pad and track stick or adjust their settings.
  1. Open the Control Panel and click Mouse.
  2. In the Mouse Properties window:
    • Click the Device Select tab to disable the touch pad and track stick.
    • Click the Pointer tab to adjust touch pad and track stick settings.
  3. Click OK to save the settings and close the window.
The Mouse Properties utility is found like this:
Start Button>Control Panel>Printers and Other Hardware>Mouse
or in the Classic View
Start Button->Control Panel-> Mouse
Dec 31, 2008 | Dell Latitude D620 Notebook
Quick play starts automatically
he he he he... dont move your fingers accidentally on the quicklaunch buttons above the keyboard.
Oct 13, 2007 | Avermedia QUICKPLAY (pquickplay)
HP Pavilion DV7-1232nr Notebook Logo
142 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
