I M Using JVC MXS4 Compact System since 1997. I have maintained it so very well that it looks brand new even today. It's sound quality far surpasses to todays hi tech available systems Whoever have heard & owned this product will agree. Today there are lots of choices & sources for good sound. But i haven't found anything close to this system. It is equipped with more then 10 Motors inside Completely Made in Japan System from Technics sounds good but doubt service & availability here My problem is, Suddenly it has stopped working, Systems On / off is normal, all buttons function with full display but no Motor / mechanism movement in CD & Tape Can i get complete circuit of same / any other solution ?? Thanks & Regards Manish Doshi
marsrover
  • 682 Answers
SOURCE: My technics se hd 51
please bring a good contact cleaner from radio shack near you and apply the spray over the socket of the headphone(the place where you put your headphone jack)take headphone jack out and apply spray in and insert the jack in and out many times.-also check your system setup and confirm that all speaker are on- no mute button pressed-no cable is disconnected.
Posted on Jul 13, 2008
djproaudio
  • 515 Answers
SOURCE: JVC AL-E300 Turntable
More than likely your motor might be bad. There is nothing else that controls the speed. Are you sure you purchased the correct size belt? Turn on the unit, without connecting the belt, and touch the motor shaft, and see if it fluctuates. You can also just get a marker, and marker a point on the motor shaft. When you turn it on, it will act as a visual indication as to it's speed.
- Davis
DJ Pro Audio
www.DJPROLAB.com
www.DJPROAUDIO.com
Posted on Aug 08, 2008
SOURCE: JVC TH 53 Dvd surround sound system. System locked
Dear friend,
Press and hold stop+play button on the front panel of the dvd player more than 15 sec the player will be resetting
Posted on Mar 29, 2009
  • 4234 Answers
SOURCE: My Technics stereo system ...the display screen shows nothing
The question is, do you hear any sound? Is just the display off or is the entire unit shutdown? Can you tell?
These displays are known to develope poor solder connections at the power input and ground pins. If you can solder, open up the unit (unplugged of course) and examine the pins for the display. This will be on the PC board attached to the front panel. The pins at either end of a long line of pins will be the power and ground pins. Reasolder those pins, taking care not to short the pins together and try the unit once done. If that does not resolve the problem (assuming it is just a display problem), update this with as many details as you can about the behavior of the unit and we'll look further.
Dan
Posted on Nov 18, 2009
SOURCE: aiwa Z-2300 compact disc stereo system
need to buy the laser for it's CD . where can i buy it from
Posted on Feb 14, 2010
My jvc mx-kc58 compact shelf stereo the aux in mode sounds far away an i can barely hear the words in aux mode only cd player sounds normal
It sounds like whatever is connected to the aux socket has a bad earth connection check and replace the cables to it.
Dec 23, 2016 | JVC MX-KC58 Shelf System
We have an Emmerson LD195EM8 19" tv/dvd combo. Our problem is the sound is way to soft to hear only when playing dvds. It even does it with an outside dvd player hooked up to the tv. This problem is only...
The issue we got here would be with the bypass on the DVD in the unit and outside the unit as far as the amp goes. Rather then spend a huge amount of cash on a repair of this fact you can by a home theater system from like wal-mart for under $100 bucks witch will provide that superor sound your looking forward to. The issue we have here is with the emmerson brand. The brand prduct here was made cheaply. This is why people go to other brands rather then off brands and that simply is for quality.
Now I know that does not help much but I beleave the issue here is with the amp bypass at the tuner/decoder boards was cheaply made and thus is causing this issue.
Remedy: purchase a HT system "home theater system" would cost you under the cost to try and repair or replace this tv and that will prvide the sound your looking to expect.
If its under warranty you might want to check with that as well. Specially if this just started to happen.
please do not shoot the messenger here please leave your positve rating for your free answer today.
Jun 20, 2010 | Emerson LD195EM8 19 in. LCD TV
Microboards DX1 input problems
Microboards' New DX-1 Disc Publisher to Ship Microboards’ New Print & Burn DVD/CD Duplicator Ships
Industrial quality of DX-2 and Print Factory in a Compact Package with the DX-1
Chanhassen, MN, August 17, 2004 —Microboards is shipping a new disc creation system (MSRP $2,995) with a high-speed DVD/CD recorder and industrial printing technology from HP to give users professional publishing in a petit package. Combined with custom label design and recording software, the system makes in-house disc creation easy and inexpensive.
You've got an expensive unit (see below for Press Release), with a built-in CD/DVD reader/writer.
Given that your unit could be six years old, it's possible that the reader/writer has "died".
It seems to be a "stand-alone" unit -- not something that requires either Mac OSx or Windows XP/Vista/7 to operate.
I'm guessing that _ANY_ IDE (not 'SATA') HP-brand reader/writer, provided that it has a "LightScribe" capability, could be purchased, and could be inserted to replace the "dead" reader/writer. For about $100, it's worthwhile to try this "substitution" to revive your unit.
____________________________
Chanhassen, MN, August 17, 2004 — Microboards is shipping a new disc creation system (MSRP $2,995) with a high-speed DVD/CD recorder and industrial printing technology from HP to give users professional publishing in a petit package. Combined with custom label design and recording software, the system makes in-house disc creation easy and inexpensive.
Jun 10, 2010 | MicroBoards DX-1 Publisher Printer
The sound goes out randomly when I'm using my ps3 I have a 42 inch sanyo and am connected with the hdmi cable. It's done it since I got the tv
When one thinks of quality home theater projectors, few brands cometo mind. Sony, JVC and Panasonic are some that do. Sanyo, on the otherhand, may not be on one's short list. However, they've been makinghigh-quality, affordable home theater projectors for years. Theirlatest offering, the PLV-Z3000 reviewed here, is no exception.Retailing for $2,999 - though depending on where you shop, that figuremay be much lower - the PLV-Z3000 is among the most affordablefull-featured 1080p projectors in the marketplace today. The PLV-Z3000 is a full-resolution HD projector (1920x1080p) with areported
Nov 14, 2009 | Sony Playstation 3 (PS3) Console
Need to set clock on jvc compact component stereo amp
How do I set the clock on my jvc compact disc audio system. model # KD-G110
Oct 21, 2009 | JVC MXKC4 360-Watt Compact Component Audio...
Brand new jvc gr-d850 camcorder. Picture quality is great, but cannot get the sound recorded. Complete silence on playback. Manual isn't much help, this problem is not even addressed in the...
Silence on the camera, or when listened on computer? Because some cameras dont have audio playback on camera. Try plugging in headphones....
Aug 04, 2009 | Cameras
P-Error on JVC compact component system FS-GD7 when turned on
1. Unplug the JVC compact component power cord from the power outlet.
2. Unplug any connected devices.
3. Press and hold the JVC compact component power button for five seconds.
4. Plug the JVC compact component power cord back into the power outlet and turn on the JVC compact component
5. Open the menu to confirm that the JVC compact component is responding again.
6. Turn off the JVC compact componentand reconnect the devices.
7. Turn on the JVC compact component...
Jul 23, 2008 | Audio Players & Recorders
312 people viewed this question
 Grubhead
Grubhead
