Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
My startup disk is full and the page is blue...what can i do..?
    Problem Solver:
  • 13 Answers
Start the laptop using the install disk by inserting it and pressing (and holding) the "C" key immediately after you turn on the computer. This will allow you to inspect your hard drive, clear some space and run Disk Utility to verify the internal hard drive.
Once you have a desktop, press command (apple) and "N",
1. Open the Applications folder.
2. Open the Utilities folder.
3. Launch Disk Utility.
4. Select "First Aid" in the bar in the upper middle of the window.
5. Select your laptop's internal hard drive from the list on the left of the window.
6. Select "Repair Permissions" in the lower center of the window. The software will check your permissions files, correcting any errors. This should include the kenell issue that is preventing your laptop from starting.
This may take several minutes, so you can check the capacity of your hard drive to see if it is actually full (simply open the hard drive, the capacity should be listed at the bottom of the window).
If it is full, consider what to remove while permissions repair is underway.
Posted on Mar 10, 2011
I have a imac G5 2005 rev c and when it starts upit goes too a blue screen with a small folder in the middle with two faces on it that flash
Try a safe boot.
Shutdown your machine. Hold down the shift key. Poweron. Wait awhile Wait awhile while you harddrive
is being checked.
http://support.apple.com/kb/ht1455
Could be a corrupt disk. Run Disk Utility.
I suspect disk corruptions.
verify & repair your startup drive
To verify & repair you file system on the startup drive, you will need to run disk utility from you installation DVD.
This article will tell you how to get to disk utility. Once in a disk utility, you can go and attempt to recover the disk.
http://support.apple.com/kb/TS1417
To repair your startup drive, you will need to run disk utility from your startup DVD.
Mac OS X 10.4: About the utilities available on the Mac OS X 10.4 Install DVD
http://support.apple.com/kb/HT2055
Sep 18, 2011 | Apple Computers & Internet
Error 53000921
Your video processor has a problem, seems like it is overheating:
graphic glitches on startup blue screen
Also, my computer would blue screen on me when i tried to run a high end graphical game, in this case Guild Wars.
I ran a full length diagnostic on my video card, and over half the tests failed.
I had many errors in the reading and writing of video memory, and failed tests of whether a page was void of colour errors and such.
I wrote down all the error codes and they are as follows:
5300:0119
5300:031E
5300:051D
5300:0820
5300:0921
5300:0B21
If you're under warranty, call Dell with the error information and they will replace the video card. If you're out of warranty, you can order a card:
Dell Spare Parts 1-800-449-3355 ext 7269937
Nov 23, 2010 | Dell Inspiron 9400 Notebook
Mac book starts with blue screen startup disk full
your disk partition is having problem.if u have not taken backup then boot the system with FW mode with saperate Laptop and backup the data,then repartition the hdd and install freshly
Apr 17, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
The front LED flashes red & blue when I turn it on. What does this mean?
LED Indicators - LaCie 2big Network
The LED indicators above the drive bays and the front LED indicate drive status and activity.
During Startup
  • Front LED – blinks red/blue until both disks are powered on, then turns solid blue.
  • Rear LEDs – blinks red/blue until corresponding disk is powered on, then turns solid blue.
NOTE: If the device is not able to initiate the boot process following disk startup, the front is solid red.
During Bootup
  • Front LED – solid blue
  • Rear LEDs – solid blue
NOTE: If a disk is failing, both the disk’s corresponding rear LED and the front LED will be solid red.
During RAID Synchronization
  • Front LED – solid red
  • Rear LEDs – The LED corresponding to the original disk will be blinking blue and the one being synchronized is blinking red
  • Once both disks are synchronized, their corresponding rear LED and the front LED will be solid blue.
Apr 06, 2010 | LaCie 2 TB 2big Triple Interface External...
I have an HP Pavillion ZE2000 laptop and it will nto boot up, push button to turn it on. goes to windows page then goes black and nothing happens will nto boot all the way up to windows page with icons. is...
press f8 at startup to get to the windows startup menu, choose "last known good configuration" If that fails, you can choose "disable automatic restart" and the BSOD, Blue screen will appear and give you an error, you can also goto safe mode with the f8 key on startup, choose safe mode, and then click yes at the prompt to start the system restore, pick a date and time the PC worked, and try that.If that doesn't work, you need to restore the PC to factory default state, by using or purchasing restore disks, you would have been asked to make them when you 1st powered on the PC, if you don't have the CD's call HP and order them.
Apr 20, 2009 | Computers & Internet
Dell inspiron 1300 stalls at blue welcome page?
It could be a hardware failure. Bad Hard drive maybe. You will have to go to the manufacturers website to get the reinstall disk. A.K.A Recovery Disk. You will have to pay. And they will send it in the mail to you. Good luck.
Mar 05, 2009 | Dell Inspiron 1300 Notebook
I have the R300 error message on my computer for my ATI Drivers it wont let me play Blu Ray movies cause it keeps stopping and making the screen go blank.
This should fix it.
Go to MSConfig
2.) Go to Services Tab
3.) Hit "Hide all Microsoft services"
4.) Go to Startup Tab
5.) Hit Disable All.
6.) Try your disk
It worked? Good. Continue on.
7.) Go to www.sysinfo.org
8.) Under Startup, search all the things you have in startup, and only enable the ones that they suggest.
9.) After you have re-enabled all of these 'good' ones, try your disk
again. Did it work?
10.) Play your disk.
Please rate this solution.
Jan 13, 2009 | Toshiba Satellite A135-S2276 Notebook
What to rebot 2 fact specs
try to use the disk cleanup, check your antivirus updates and then make a full system scan, uninstall the unused programs, clean the startup section by using Start-Run-msconfig-startup and remove the selection about some programs you won't to start with startup!!!
check your disk drives (check disk)
after all this make a defragmentation
Dec 15, 2008 | Acer Aspire 3690-2196 Notebook
Get the blue screen
If your Dell was built after 6/04, you have a recovery partition. Press Ctrl+F11 on startup to restore the system to the way it was when delivered.
Downloadable pdf manual for your machine:
http://support.dell.com/support/edocs/systems/dimc521/en/OM_EN/RP333A00.pdf
See page 56.
Aug 03, 2008 | Dell Dimension 2400 PC Desktop
Packard bell win 98
You need a floppy windows startup disk.
Nov 08, 2007 | Packard Bell Packard-Bell Full Page...
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
138 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
