Question about Brother HL 1250 Laser Printer
I have a sheet of paper jammed solidly in the printer - how do I get it out - help, please!
    Champion:
  • 312 Answers
Janet, have you tryed removing the printer cartridge? The paper is usually underneath the toner assembly. Be real careful and use steady pressure and pull gently to get teh paper out. You don't want to **** on it, creating more jams. Look around each roller with a flashlight for small pieces that may have come off also.
Posted on Oct 22, 2011
Paper jam - I can see the jam, but don't know how to remove the paper.
Hello
Open the top cover of the printer.
If you can see the jammed paper, take one or more sheets of paper and pull them toward you.
While pulling the paper, press the RESUME button to turn the paper feed rollers.
If the paper needs to be fed in the opposite direction, release the RESUME button and then press it again.
If the paper is still jammed, turn the printer off or remove the power cord from the printer. Then turn the printer back on or plug the power cord in.
The printer will run through a reset cycle, which may clear the paper jam.
If the paper is still jammed or if several (8 to 10) sheets are jammed, take hold of a sheet in the middle of the stack using both hands.
With firm, even pressure, pull the sheet toward you.
Usually, removing one or two sheets from the middle of the stack will release the pressure and the rest of the stack can be removed.
Make sure no scraps of paper are left in the printer.
Close the top cover of the printer.
Try printing again.
Apr 16, 2011 | HP PSC 750 All-In-One InkJet Printer
My 1900 printer power is on and flashing slowly and the paper/garbage light is on and not flashing.
Hello.
You most likely have a paper jam or a paper feeding problem. Paper may have jammed in the sheet feeder, manual feed slot, or roll paper slot.
Sheet Feeder or Manual Feed Slot: Press the
paper button to eject any jammed sheets, then open
the printer cover and remove any paper jammed inside.
Press the paper button again to clear the error.
Hope this helps.
May 31, 2010 | Office Equipment & Supplies
Error message says"out of paper" when paper tray is fully loaded
check and make sure that the paper is in near the rollers enough that it senses the paper and picks it up. try lightly pushing the paper down toward the rollers as it is suppose to pull one sheet through the feeder. hopefully, you didnt pull too hard on getting the 'jammed' paper out that it may have caused a misalignment in the feeder. try assisting the paper, that usually fixes it. hope this helps!
Aug 16, 2009 | HP PSC 1210 All-In-One InkJet Printer
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
When printing paper continues to jam.
  1. Take out paper tray 1.
  2. Remove any jammed sheets of paper you find there.
  3. Once you have done this, reinstall the paper tray and try printing again.
    Note: You may receive a message informing you that another sheet of paper is jammed elsewhere in the printer. If so, please open the front door and remove the toner cartridge. Also open the rear door of the printer (and the duplex option if a duplex unit is installed). Remove any and all jammed sheets of paper you find. Then try printing again.
  4. If the printer jams again with a 241 Paper Jam error message, look to see if it has tried to feed a sheet of paper out of the tray.
Dec 16, 2008 | Office Equipment & Supplies
Printer keeps jamming paper
without some information about the kind of printer and the weight/thickness of the paper, try to supply more information in a comment if you can, this is a generic answer.
many printers have a paper thickness adjustment that helps ensure that only one sheet is picked up at a time, and that the sheet feeds accurately,
if two or more sheets are picked up there are jams as multiple sheets do not feed well, and may not even get out of the paper tray. If the printer is set for a thicker paper, the lead edge of thinner sheets may miss its aimed path and wrap around guides or rollers, jamming.
The makers web page, or the user guide if you still have it, often have FAQ on paper jams,
Jul 02, 2008 | Office Equipment & Supplies
Paper feed/jamming problem
suggest you bring your orinter to the nearest authorised repair center. There might be parts to be replace
Mar 23, 2008 | Brother HL-2040 Laser Printer
Problem
Paper jams can be real or false. The all-in-one may report a paper jam when there is not any jammed paper, however, the solution to a real paper jam or a false paper jam is the same.
To fix the paper Jam errors please try the following steps:
1. Confirm that no foreign materials are inside the machine.
2. Confirm that usable paper is set.
3. Confirm that the paper is set properly.
4. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
5. Disconnect the printer power cord as well as the printer cable form the printer.
6. Turn the printer upside down and shake the printer in order to remove any obstacle which is stuck inside the printer causing the paper jam error.
Open the printer cover and remove the cartridges and check carefully if there is any small piece of paper which is stuck inside, if so carefully remove it.
7. Disconnect the printer power cord and press and hold the power button on the printer for about 15 to 20 seconds( this will release the flee power) and reconnect the printer and check.
Regards
Malik Khan
Jan 26, 2008 | Canon PIXMA MP160 All-In-One Printer
Brother HL 1250 Laser Printer Logo
26 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
