Question about Whirlpool LER5636P Electric Dryer
Whirlpool Dryer - LER4634EQ1
Dryer is working but - hearing a squeaking noise which gets louder - is it the motor?
  • shawpanther Apr 26, 2009
    I have whirlpool electric dryer ler4634eq1, Had a terrible sqeaking sound I oiled the motor shaft and and bearing block assy. squeaking has seamed to stop ,but now when i go toturn on the dryer it will run about 10 minute and shut down. if i wait a couple of hours it will start up but makes a loud buzzing sound when started.
  • Anonymous Mar 28, 2014
    how do I stop the squeak
    Genius:
  • 1,073 Answers
Check the idler pulley and the rear tub rollers first
Posted on May 31, 2008
Dryer Model # LER4634EQ1 As the drum turn's the
What the most probable things thats causing that noise is the rear drum support rollers.
This youtube video will show ya how to take apart the dryer and replace those rollers
http://www.youtube.com/watch?v=wBf_vwvlFGM
The part number for the rollers is 349241T that part number is a kit for both of the rollers in one kit plus the plastic triangle clips that hold them to the shaft they fit on.
That part can be purchased at your local appliance parts store or also online at;
searspartsdirect.com
apdepot.com
partselect.com
apwagner.com
repairclinic.com
GENE
Sep 12, 2011 | Whirlpool Dryers
I have a gas dryer Maytag Dependable Care Model 6 cycle about 11 yrs old...Has a steady squeak as it runs , seems to be getting louder . Everything on the dryer seems to work fine other than this...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 14, 2011 | Dryers
Loud squeaking noise when you start up the dryer could it be a bearing dull squeak not high pitched a little bit of a grind sound
It does sound like a bearing or at least a lack of lubrication. But it could also be belt slippage if it only happens at the start. If it is the bearing it would be continuous and slowly get louder and louder.
Jun 18, 2011 | Whirlpool LER7646E Dryer
Our whirlpoole gold dryer has a vibration that is getting louder. When you turn the tub there id one spot where you can feel the tub virate. what could be causing this vibration.
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 19, 2010 | Whirlpool GEQ9800P Electric Dryer
Loud vibrating noise after warming up
heatman101
May 10, 2010 | GE Profile Harmony DPGT750EC Electric...
When we turn on our Whirlpool Supreme electric dryer, it heats up and dries clothes, but it is making a loud squeaking noise throughout the cycle...sometimes louder than others.
The squeaking noise can be caused by any of the following.
Location High:
Belt slipping on the dryer drum
Worn Drum seals but would sound more like a dragging noise
Location Low:
Belt tensioner pulley bearing frozen and the idler pulley shaft is spinning inside the belt tensioner assy.
Belt slipping on the motor bearing
Motor bearing is dry
Thanks for using FixYa!
Kelly
Mar 04, 2010 | Whirlpool LER5636P Electric Dryer
Ticking getting worse!
heatman101
edgfd
Sep 30, 2009 | Bosch Nexxt 500 Dryer
Dryer turns and heats, but makes a very loud squeaking (or should I say, SCREECHING) noise. The heavier the load, the louder the squeaking.
Does it sound like a belt ?
Or does it sound like metal ?
Might need to replace the drive belt..
Or - it could be the bearings..
Hope this helps !!
Rate me good ;o)
Jul 13, 2009 | Whirlpool LEQ8000JQ Electric Dryer
Real bad squeaking noise in dryer
Yes check the brake. Just open the back panel and look under the machine. Check the brake latch and make sure that when the unit starts to spin that the brake backs itself off and also make sure that the bad is not worn down. If it is then replace it. A few screws and off it comes. To check the pulley and the belt there is really no wrong way to do it. First look at the belt and make sure that it is not cracked or really smooth. If that checks out ok then make sure that it is attached to the pulley fully and that the pulley is not bent
Feb 13, 2009 | Maytag Performa PAV2200
GE Dryer makes deep sounds when hot and tumbling
heatman101
wrytrtrs
Jan 28, 2009 | General Electric GE 7 0 Cu Ft Super...
Whirlpool LER5636P Electric Dryer Logo
326 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
