Question about Sharp XR-10X Multimedia Projector
Unit shuts off sporadically
Lamp shuts off, then back on at irregular intervals
  • 115 Answers
Hello dear
You have not mentioned the lamp condition. Pls check the Lamp unit. If the unit has crossed over 2000 hrs then the problem is with SMPS.
I have solved one same problem by replacing the DMD module.
Pls clarify.
Viren
Posted on Jul 17, 2008
A/C runs fine for 7-8 minutes, then shuts off.
AHX18MEV
4 - 12
[8] SELF-DIAGNOSIS FUNCTION
1. Indoor unit
(AH-X18MEV, AH-X18MEV-1, AH-X24MEV, AH-X24MEV-1)
To display the self-diagnosis, hold down the AUX button for over 5 seconds on the indoor unit when the indoor unit is not operating.
• The operation lamp (red), timer lamp (orange) and Super jet lamp lighter) flash to indicate the information of malfunction.
(Display of self-diagnosis result)
The operation lamp (red) and the Super jet lamp (green) flash in synchronization with the timer lamp (orange).
(AH-XP18MV, AH-XP18MV-1, AH-XP24MV, AH-XP24MV-1)
• The POWER CONSUMPTION indicator indicates the information of malfunction by showing the main category error (number) and the sub-category
error (-number) alternately in 1-second intervals.
Example: Compressor high-temperature error
Remark
May 11, 2013 | Sharp Heating & Cooling
Screen loses brightness at irregular intervals, then eventually returns to normal brightness.
Shut off the whole TV including the cable and the wires. Wait for about an hour and then turn it back on!
Dec 10, 2011 | LG 32LG30 32 in. LCD HDTV
Projector was turned off wrong and now wont turn back on.
if the led flashes once in 2-second intervals and you don't hear a high-pitched whir, the colorwheel needs replacing. if you do, the ballast is bad. if it flashes 2 times, the lamp is past 3000 hours. 4 times, fan error. 5 times, temp too high and it needs to cool.
Nov 07, 2009 | InFocus ScreenPlay 4805 Multimedia...
Serious error
Try opening your computer and cleaning the fans around the CPU and the other fans in your system. Computers have a sensor that shut computers down when they get too hot. Clean all the dirt inside and you should see a little performance boost also.
Jan 05, 2009 | HP Brio BA PC Desktop
Projector shuts off sporadically
1. Pls check the airflow of the cooling of the projector, or just service the all unit.
2. As you told that the lamp life is 76%, Check the inner
reflector have shiny surface of dimmy, If not shiny, then replace
the lamp unit.
Enjoy
Viren
Jul 20, 2008 | Sharp XR-10X Multimedia Projector
need to replace the lamp. i could have diminished not as much to frequent on and offs, but excessive dust. it's heating up too much and shutting down.
May 31, 2008 | Sharp XR-10X Multimedia Projector
Panasonic PT L501U Projector
Hi there
Have you replaced the lamp ?
If you haven't - take out the lamp and chech for any irregularity on it - i.e. - discolouration , vein like looking marks ( black or white ) and also if the shape of the shaft is off.
If there is no visible damage it might be a faulty Ballast ( lamp's powersupply ) - especially if you cannot get it out of stanby once it has shut down.
Apr 15, 2008 | Office Equipment & Supplies
Sanyo PLC-XT16
Hi there
Is there any on screen prompting ?
If not , open up the lamp door at the bottom and take out the lamp. Check on the lamp's shaft for any irregularity ( i.e. vein like looking black marks or bubbles or a white spot , also check that the fillament on the inside is not broken.)
If you spot anything I listed up here , your lamp will need replacement.
If you cannot see any irregularity , check when the unit shuts down which of the LED's on the unit flashes.
It will either be your lamp or the Ballast ( lamp's powersupply ) that is faulty and will need replacement.
Apr 15, 2008 | Sanyo PLC-XT16 Multimedia Projector
Tv turns off at irregular intervals
MOST PROBABLY DRY SOLDER IN THE POWER SUPPLY SECTION OR REPLACED THE HORIZONTAL DRIVER TRANSFORMER . MUKU
Oct 16, 2007 | Durabrand DWT1905 TV
Sharp XR-10X Multimedia Projector Logo
164 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
