Question about Microsoft Xbox 360 Console
When i turn my xbox on it say on the screen e74 an one red light is on
Code e74
    Scholar:
  • 85 Answers
E74 is an error with your AV cable and or your GPU / Scaler chip. If you can swap out your AV cable to see if that works if not you will have to contact MS, as there is no quick fix for this error if your cables dont work. Hope this helps.
Posted on Jun 02, 2008
How do i fix an error 74 on an xbox360
The E74/E6x/E4x/E8x are famous error codes that have plagued many Xbox 360 gamers. This error codes will be displayed on your screen, each indicating different problem with your Xbox 360. It's usually defined by the single red light or 1 Red Light Error lit up at lower right quadrant on the Red Ring of Light on your Xbox 360 console.
E74: There is high chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. In some cases it is a problem with the GPU and may be repairable by using the Xbox 360 Repair Guide. Xbox 360 E74 error has reported to increasing a lot for the newer Xbox 360 version.
Hope this was helpful?
Feb 26, 2011 | Microsoft Xbox 360 Console
My xbox 360 was saying error e74 now it will just turn on but screen is blank.pls help me
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
Nov 15, 2010 | Microsoft Xbox 360 Console
The bottom right light is blinking red everytime i turn it on
e74 at the bottom of the screen?if your xbox is less than 3 years old send it back to microsoft as they have extended the warrenty period to 3 years, e74 is code for graphical issues could be the graphics card. hope this helps.
Nov 17, 2009 | Microsoft Xbox 360 Console
The flashing red light comes on with message E74
you are seeing one red light on the powerbutton and E74 on the screen?
E74 can only be caused by either the HDD or the console itself,so you might wanna try using a different HDD with your console, if the issue still persists, then most probably, the console is having a hardware failure,there is a possibility that the HDD PORT is not properly woking w/c is causing the e74 error.
if thats the case, try calling xbox support hotline(1-800-4-MYXBOX) to process a repair for the console,it will be free,because Microsoft is extending the warranty of the consoles for 3yrs from the date of purchase for e74 and 3red light issues.
or you can also process a repair online,that is available at service.xbox.com,just click on "repair my console"
hope i'll help you..:-)
May 17, 2009 | Microsoft Halo 3 for Xbox 360
Xbox 360 e74 error
Having the e-74 code is when the video chip on the 360 over heats and becomes un soldered your best bet is to turn the 360 on with a towel over it and wait for 3 red lights the call microsoft and tell them the 3 lights issue dont mention the 1 light or it will cost you dearly around 150$
Mar 17, 2009 | Microsoft Xbox 360 Console
1flashing red light
one red light is also the E71 error as well.
Aug 04, 2008 | Microsoft Xbox 360 Console
If everytime you turn on your XBOX 360 and it displays this message it could mean a hardware failure :
E74 Means : There is high chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. In some cases it is a problem with the GPU and may be repairable by doing the x-clamp replacement
I would advise you call customer support
They are very helpfull and if your XBOX 360 is under warranty they will offer a pre-paid postal service to pick your XBOX 360 up , and will diagnose the problem .
If your based in the uk , the number is : 0800 587 1102
I hope this helps everyone
X
Jul 31, 2008 | Microsoft Xbox 360 Console
Xbox 360
What is the error code at the bottom of the screen & check for flashing red lights on the power button if 3 illuminate it the infamous RROD(Red Ring of Death-google it) which you will get a free repair for if its the bottom right quadrant flashing red then its most probably E74 or E61. E61 is a hard drive related problem so try playing without it, & E74 is the AV cable snapped inside or the GPU/CPU inside the xbox 360 has weak solders on it, I suggest MS support ASAP.
Jul 22, 2008 | Microsoft Xbox 360 Console
Xbox 360 e74
You have to have it repaired.
May 19, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
59 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
