Question about Yamaha RX-V2700 Receiver
I have a yam rxv2700 that was in the box until last weekend that was purchased 3 1/2 years ago it says in the gui that its highest resolution is 1080i. i tried to plug a ps3 in and it would not pass video through HDMI via monitor out. I changed resolution on the ps 3 to 1080i as well and it sti, ll woul nt pas video. is there software to fix this or do i send receiver to service to upgrade this and is there hardware upgrade for this? this was a very expensive receiver.
RX-V2700 YAMAHA CHANNELS SOFTWARE UPGRADE REQ
Posted on Oct 17, 2010
I have kodak 6850 print,i replace head 3 years ago,now my printer make at funktion like blurry print,than it okey for some time,now it start again, and now it onley make blurry pics
Can we assume you have checked the printers settings ?
Ie set it to the highest resolution, set it to photo mode (as opposed to text), set the paper type to glossy .Still having Problem Then follow Us For
Kodak Printer Support
Mar 12, 2014 | Kodak Photo Printer 6850 Thermal
Good day, I have an Acer AL2423W monitor. When I turn it on, for the first few minutes all I get are vertical coloured lines. After a few more minutes the screen images start to become visible, but...
Hi Friend, In this case what I would recommend you is to connect any external monitor to the system to check if you have the same issue with the external monitor as well or not.
If yes, then it might be the issue with the video card so, you can try updating the video drivers for the system.
If no, it means that the original monitor has some issues with itself..
Also what I would recommend is try to lessen the screen resolution instead of 1920 x 1200 to lower resolution and restart the system and check if it makes any difference..
Also update the video drivers for the system.
Jan 04, 2011 | Acer AL2423W LCD Monitor
Monitor screen is almost completely black - i can only see the desktop very slightly. is there a light bulb that can be replaced to fix this?
Change the display resolution in Windows To change the display resolution to the highest resolution, use the following actions.
  • In Windows 7 , click Start , click Control Panel , find the Appearance and Personalization area , and click Adjust Screen Resolution . Move the slider bar until the highest resolution for the monitor is set, and click OK .
  • In Windows Vista , click Start , click Control Panel , find the Appearance and Personalization area , and click Adjust Screen Resolution . Move the slider bar until the highest resolution for the monitor is set, and click OK .
  • In Windows XP , click Start , click Settings , and then click Control Panel . Double-click the Display icon, and select the Settings tab. Move the slider bar until the highest resolution is set, and click OK .
If the screen is still blurry, please contact an HP support technician for further assistance.
Also see To troubleshoot this problem, make sure the AC adapter is connected. For specific steps, see HP Notebook PCs - Troubleshooting Black Screen Displays with No Error Messages During Startup or Boot .
Nov 02, 2010 | HP G60-127NR Notebook
Screen will flicker a few times at random periods
Change the display resolution in Windows Change the display resolution to the highest resolution using the following actions:
If the screen is still blurry, the notebook display might need servicing.
Feb 13, 2010 | HP Pavilion dv4000 Notebook
How do I connect the tv to a satillite receiver?
You have multiple options here depending on the type of interconnect cables you currently physically have or are willing to purchase.
Below is a web site with a review of your monitor.
http://us.sanyo.com/LCD-Televisions/720p-31-5-HDTV
The best way is for you to have a HDMI cable. This carries your High Definition Video and digital audio from your Satelite Reciever all in one. The satelite box will also know that your monitor is only able to display the lower 720P resolution than the current 1080P resolution and will automaticly display images correctly.
HDMI is the highest and best way to connect your satelite box to your monitor.
Component - three wire cable 'Red, Green & Blue' is then the next best - note you will still need to have a stereo Audio cable also Red and White dual cable to connect also. This connection doesn't communicate with your monitor and you will have some set up to do on the mointor itself to display the resolution you would like. Between 720P, 'Highest resolution' , 720i ''next highest resolution' then 480p ' next in line' and then worse case 480i 'lowest resolution'.
If you don't have a HDMI cable - and go to by one. Don't go and buy the most expensive. It is best to keep the cable short as possible. HDMI doesn't effectly travel over long cables more than 8'. You will get color shifts in your images. Monstor cable is very expensive and not needed. Anything your local Wallmart and or Target have will be fine under 8 feet.
Blessings,
A/V Media Guy
Nov 21, 2009 | Sanyo DP32648 32 in. LCD TV
Battery life sucks, dont last a weekend?
If you purchased it less than two years ago...Its still under warranty. send it to them. They will replace it for free. <you need a copy of the receipt!!< if not bushnell will sell you a newer one for about 70 dollars....
mtg
Jul 15, 2009 | Bushnell Trail Sentry 11-9200 Digital...
TV picture is not good
from what your describing it sounds like a resolution or ratio setting on your t.v. you can change these setting on your cable box and t.v as well this seems to be the setting on your t.v. since you have already unhooked the cable box. if changing the settings doesnt resolve your issue you may have some failed components on the pc board that could be repaired by a repairman v/s purchasing a new one. hope this was helpful....
Dec 16, 2008 | Sylvania 6427TE 27" TV
Yamaha RX-V2700 skipping when playing a DVD on Toshiba D-R400
Sounds like a poor grounding issue between the units OR maybe they're not as compatible as the Mfg's say.
Could be a bad HDMI cable also. Most are made in the land of Nanking
Jan 18, 2008 | Yamaha RX-V2700 Receiver
Yamaha RX-V2700 Receiver Logo
225 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
