Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9100 LW1 Front Loading
In the middle of the washing cycle, I get a "H F" signal. I unplugged the machine and turned off the breaker for 20 minutes, according to the directions. No luck. I had a service man out who told me I need a new water inlet valve. Does that sound correct?
Thank you.
  • 5,911 Answers
It could very well be a water inlet valve, but there are several other things that may cause your problem. Please read the information I have about the "FH" error on the following link:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
As you can see, you may need to rule out some other possibilities. Did your service man check all the other options? The easiest things you need to check is to make sure you don't have a siphoning issue, something clogged in the drain pump or lines, and dirty water inlet screens. These are the more common contributors to this problem. The pressure switch and flowmeter are less likely, but still should be checked. If need further assistance, please go to my profile and use the "Ask Me" feature for a quicker response. I hope this sheds some light on the problem and helps resolve it for you.
Posted on May 31, 2008
I need a parts manual for a whirlpool front loader washing machine
Please go to the following link and download the manual. It is for GHW9100 and quite exhaustive showing all the pars and their assembly.
http://applianceassistant.com/pdf/duet.pdf
Sep 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Just want to know cubic feet of the whirlpool ghw9100
The volume capacity of Whirlpool Duet GHW9100 is 3.7 cubic feet. Refer to the specifications below for other details.
Jul 19, 2011 | Whirlpool GHW9100L Front Load Washer
I own a whirlpool duet ghw9100 lw1 and i have two problems...fabric softener wont dispense and the drum fills and overfows with water on occasion
The overfilling problem is due to the water valve allowing water to slowly seep into the machine when not in use. You simply need to replace the water valve. The first thing to do for the fabric softener is to clean the dispenser. Failing that you can remove the top of the machine to observe the correct movement of the zone valve for the dispenser.
Jan 11, 2011 | Whirlpool GHW9100L Front Load Washer
No spin cycle on Whirlpool duet model ghw9100
If front loader, take top off (dissconnect plug) check the beltmay be broken- the motor may be spinning on its own
Also spin the drum round to make it has'nt seized
Jul 22, 2009 | Whirlpool GHW9100L Front Load Washer
I have a whirlpool duet sport front load washer. It was running in the wash cycle. I had to cancel the cycle. Now the machine will power on, but when I put the start button it turns itself off. I've t
make sure you havent locked the console by accident it is in small print on the front right of the console other than that you will probably need a technician
May 30, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Control lock on model ghw9100
Try pressing and holding the "End of Cycle Signal" button in for 3 seconds. This button is used to lock/unlock the control panel as a safety feature to prevent small children from manipulating the controls. The instructions should be printed on the front panel near the button.
May 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Probably a good assessment. I wasn't trying to second guess your repairman. I just wanted to make sure you were able to have the knowledge to eliminate some of the possibilities yourself. That way, you feel a little more confident that you're getting the correct repair. It sounds like the solenoid is probably clogged or scaled up from sediment. Let me know how things turn out for you.
May 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Front Load Duet Dryer
Holding the End Cycle button for a few seconds worked! Yes
Aug 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
102 people viewed this question
Dan Webster
Dan Webster
Sal De
