Question about Magic Chef MCD1611ST Microwave Oven
The fuse blew out in my microwave so I removed it so I could replace it. However, I have lost the fuse, can't replace. Need a replacement.
jsrock516
  • 5911 Answers
SOURCE: GE JVM1440 Spacesaver Microwave
You can fix it without the aid of a repairman. Simply unplug the microwave and remove the outer casing. There should be a few screws around the bottom edge and back panel. Once you have the unit open, look for where the power cord comes in. There should be a circuit board with a fuse mounted to it. This is your input line filter. The fuse should be a 20 amp appliance fuse that you can pick up at any hardware store (Lowe's and Home Depot both carry them). DO NOT op test with the outer casing removed. Potentials of about 14,000 volts are present in the high voltage network of a microwave oven. Close the unit up BEFORE you power it back up. Let me know if this helps.
Posted on Aug 11, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Location of monitor switch for Sharp R-5A54B microwave
It's usually the one in the center, as opposed to the being near the top or bottom edge of the door.
The entire service manual is available for free download on the Sears parts site (page by page) at http://www3.sears.com/ (the 3 is correct)
Just look for the switch as ref # 1-7 on this diagram:
http://tinyurl.com/yqc9ol
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 31, 2007
SOURCE: Microwave fuse keeps blowing
ckeck your door switches and h.v doides if you know how if do not get serviced by technician
Posted on Mar 21, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: keeps blowing fuses
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
Here is a link you or someone you know can use to test it, but please read the safety info:
http://www.gallawa.com/microtech/cap_test.html
You can order Panasonic parts from Tritronics here or by calling 866-779-5835, but if you don't find what you're looking for there, try here.
Posted on Nov 09, 2008
jmgldsmth
  • 2005 Answers
SOURCE: Kenmore over the range microwave 721.63684300 - nothing works
you must remove the MW take off the cover then look for a large metal can (capacitor) and a white (ceramic) fuse...look and, smell and, you should find the cause
Posted on Apr 22, 2009
My Emerson Microwave MW9117W has lost power and was wondering if there was a fuse or something that needed replacing
There are fuses inside. The big thing is to figure out why the fuse went bad. either something shorted and blew the fuse, or it got hot and went bad due to bad connections at fuse holder. or maybe a bad door switch blew the fuse. I have also had fuses just get old and tired., and just needed to be replaced.
Aug 19, 2017 | Emerson Microwave Ovens
What causes microwave to blow new fuse?
The only thing inside a microwave oven that draws enough current to blow a fuse is the magnetron that generates the microwaves to provide the cooking power. Based on the age of the unit (approx 15 years) it is most likely best to just replace it as repairs at that level are not cost effective. Newer units cook better and faster using less power these days.
Jul 02, 2015 | Sharp Microwave Ovens
GE Advantium 120 SCA1000DWW03 blowing 20amp fuse
Our unit was doing the same thing,
took it into the repair shop, they said there was nothing wrong with the unit, replace the main breaker that supplies power to microwave and try again.
Sure enough the breaker became defective, and we never had issues with it before, but now the unit has not had a single problem.
Feb 13, 2014 | GE Advantium SCA1000H Convection /...
I believe it blew a fuse no wont even light up
I would take the cover off and you be able to locate the fuse then replace it can buy the fuse at lowes or home depot
Nov 10, 2009 | Haier MWG10051TSS Microwave Oven
Microwave doesn't work after house fuse blew
Check the fuse inside the microwave. Unplug the power, remove the case screws on the back of the main case and slide the case toward the back. Remove the outer case and look for a fuse that looks simular to an old automotive fuse, usually near or just above the control panel. Check the fuse to see if it is good, if not replace with the same and reassemble reversing method used to access the fuse. Note: automotive fuses will not work. A replacement will be available at The Shack or a local appliance parts store.
Nov 09, 2009 | Microwave Ovens
Using Convection Oven and lost power Sharp R-7A85
Replace fuse with slo blow from Ace Hardware. Plugged unit in, clock worked. Turned unit on and immediately blew new fuse. Will fix it with a new unit.
Mar 21, 2009 | Sharp R-7A85 Microwave Oven
Goldstar MIcrowave stopped working when light bulb blew out.
when that happen to me i change the bulb and the fuse in of the microwave f the don't work send it to the company that made it and they should tell what wrong.
Mar 11, 2009 | Goldstar MV-1501 Microwave Oven
Blows internal fuses after replacing
Did you use correct fuse??? REMEMBER MICROWAVES CAN KILL EVEN WHEN UNPLUGGED
grandadfixer
Apr 30, 2008 | GE JVM1850 1000 Watts Microwave Oven
Whirlpool microwave oven
The magnetron are short need to replace / look for the old or in junk shop magnetron same serial # and etc
Jan 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Magic Chef MCD1611ST Microwave Oven Logo
93 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
