Question about Baby Gear
The straps on my maxi cosi tobi car seat wont adjust they are really tight and i cant slacking it where do you adjust the straps about?
  • 286 Answers
Hi
you have to pull the buckle towards you if they are still jammed check where the bottom buckle join the seat body to see if there is anything stuck in there if not i would recommend taking it back to the shop and get a replacement,
i had to do this just 4 weeks after buying mine the straps got jammed and i nearly broke little ones arms trying to get him out!
Posted on Oct 18, 2010
Can you re thread straps on maxi cosi tobi?
Hi
Due to the safety implications of this being incorrectly done it should not be attempted at home. The carseat needs to come in for our engineers to re-thread the harness and ensure it is performing as it should be.
Please visit www.maxi-cosi.com and select the country you're in, then use the "Contact Us" tab for your enquiry to go through to the customer care team in your country who can provide further assistance.
Apr 05, 2013 | Maxi-Cosi Tobi Car Seat - Jet Black
Maxi cosi tobi strap has jammed
It's not possible to loosen the belts of your Tobi?In this case you may need a repair of the quick-adjuster (the part where the buckle is attached to) or it may be appropriate to exchange the quick-adjuster.
Because this part is directly affecting the safety of the seat I would advise you not to try to repair it yourself; please visit a Maxi Cosi dealer to have it serviced.
I hope this helps.
Erwin de Raadwww.babycare.nl
Sep 20, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Need instructions for adjusting straps in maxi cosi tobi car seat also on how to remove covers to wash thanks tracy
Good Afternoon
Please visit www.maxi-cosi.com and select the country you're in, then select the Tobi carseat and download a replacement user manual which will have information on how to adjust straps and remove fabric.
Jul 13, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Is it possible to buy new covers and straps for this seat?
Replacement fabrics can be ordered via your local Maxi Cosi retailer or direct from the customer services department on 01284 413 141 Mon-Fri 8.30-4.30. RRP is 60GBP and if purchased direct there is 3.99GBP p+p
Jun 25, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
How can i make the headress go upto make the carseat bigger??
Good Evening
Take hold of the headrest and lean it forward (toward the front of the carseat) then you can slide it up and down to wherever the harness needs to be for the best fit for your child.
The shoulder straps should be no more than 1 inch above or below the childs shoulders when correctly adjusted.
Jan 04, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Maxi-cosi tobi strap tensioner not working. able to tighten straps when child is in seat but when buckle is pressed to release straps and get child out, unable to loosen straps tensioner will not let go.
Hi, Make sure that when you go to loosen the shoulder straps that the **** strap is pulled toward you, otherwise you cannot make the shoulder straps loosen, this is a safety feature. Hope this helps.
Jul 28, 2010 | Maxi-Cosi Baby Gear
How to alter the straps
how to adjust straps in maxi cosi tobi
Jun 16, 2010 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Can't take off maxi cosi carseat cover, because grey strap at the bottom doesn't come loose.
Slack off the straps as far as possible and recline the seat. Open the strap guard door on the rear of the bit of the seat that reclines (Item 3 on diagram http://www.maxi-cosi.com/media/producthandleidingen/maxicosi/PrioriFix.pdf). The shoulder straps can be released from the metal clasp which is in here.You can now pull the straps through the back of the seatand release the cover.
Oct 20, 2009 | Maxi-Cosi Priori
Maxi-cosi Tobi car seat. When I tried to remove the cover, my son pull out the belt strap from the buckle (adjustment belt- the one wich I normaly pul to tight harness system). And now it just hang at the...
Hi, did you ever solve this issue as I have the same issue. We accidently pulled out this adjustment strap and now can not get it back in (nor can mother care). M_SLATER
Jul 15, 2009 | Maxi-Cosi Baby Gear
Maxi-Cosi Tobi Straps not working
I guess that you have perhaps solved your problem now but if not, have you seen this?
http://maxicosi.com/tobi/default.aspx
Hope this helps.
Chris
Sep 18, 2008 | Baby Gear
Baby Gear Logo
672 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
