Question about Sony FD Trinitron WEGA KV-32XBR400 32" TV
Sony trinitron 32 " purple area on screen
On the bottom r. hamd corner ther's an area that shows image but is usually purple in colour! Is there anything I can do about this/
  • prykeyboy8 May 31, 2008
    Thanx so much for your reply. I thought TV was ready to die but you'ved restored it! We'd just relocated it to different room and yes- we'd placed it right next to a speaker.
  • 10,594 Answers
Check any magnatic device near TV which causes purple color on screen. That device can be Speaker, Electronic toy, Watch like that carring piece of magnet inside. Remove that device and turn OFF your TV for half a hour, then power again. Hope the color will be fine n normal on entire screen.
Posted on May 31, 2008
Im not too sure on the serial number of my sony trinitron but iv gone off what looks most like mine! the problem i have is that the four corners of my tv set have changed colour when i turned it on at...
Hello
Your TV has degaussing problem I thinks. There is a coil fitted around the screen, through which an AC supply is fed each time when you switch on the set, and it will last only for about 3 microseconds or so, to demagnatize your picture tube. In specific timing is accieved by the help of a "Posistor" usually called as degassing posistor. If it fails to work, the fault you have mentioned will occur. If you turn your TV in an other direction, say if it is paced east-west, turn it to south-north, the colour change now you see will be in an other state.
You just open your TV. The said posistor can be located on the power section of your TV. It will be normally black in color, looks very like a small chocolate. There are two types of posistors are used by Sony. One type has only two connections, and the other have three. You just replace it, it is very easy job. Just desolder it out, and go for a same type of posistor. It is quite normal fault in all TVs. OK.
Nov 12, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Picture shifted to left 1/3 and left portion shows on right side 32" sony trinitron (not flat screen)
Probably caused by a failure of certain bipolar electrolytic capacitor(s) in the area of the high voltage circuit.
May 20, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Green corners of sony crt tv
thats kind of degaussing coil not function, try to replace that one and lest see what the re action of your tv.
Apr 16, 2009 | Sony FD Trinitron KV-28FQ75 28" TV
Intermitant color bursts of red, green, purple
Kevin,
for the color problem,most likely you do have problem with loose contact of components from C-board ( small board connected at the back of CRT "picture tube" which drives every color and size of the screen)if you have knowledge with soldering electronic component parts, resolder this board and also check main board for possible loose contact.
cheers,
mark
Feb 04, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
GREEN AND PURPLE LINES ACROSS THE SCREEN
This is a symptom of the circuit failing.
it will soon be much worse.
You need a tech.
you can verify it is the tv circuit.
remove cable or input another signal such as dvd
bring up the TV' menu. does it have the lines.
Jan 15, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron 32 tv
1) Could be bad CRT ( picture tube )===no green==purple.
 2) Might be lack of green drive to CRT==bad transistor.
 Recommend analysis by technician--usually worth it if CRT ok.
Oct 22, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony FD Trinitron WEGA kv32fs120 32" picture too big/vertical arch...
Sounds like you have a problem with the high voltage regulation or the power supply. This condition is called "blooming" Stargazer
Aug 18, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Monitor colours are only fluro purple & green!
use a 10 ins, speaker magnet to front of picture tube degussing color
Nov 29, 2006 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Screen Image is Concave
sony trinitron colour 29ins tv its black and white not colour but the teletext is colour
Sep 01, 2006 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony FD Trinitron WEGA KV-32XBR400 32" TV Logo
283 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
