Question about Microsoft Office Professional 2007 Full Version for PC
ETHERNET Problem ya actually i dont have wireless router
    Scholar:
  • 47 Answers
Hmmm so you have a wired router? or you are plugging your laptop directly into your cable/dsl modem and when it doesnt work you are trying the desktop which does work?
If this is the case are you powercycling the modem (unplug power to modem wait 30 seconds and plug it back in...btw if you are using a mta or the modem has a backup battery you will want to find and press the reset button) when you switch devices? (make sure you have the laptop conected before you powercyle)
The folowing directions are if you are using a microsoft operating system:
Does your laptop pull an ip?(if so what is it?) If not then go to start then run enter the command "cmd" then type "ipconfig /release" hit enter the command will reset your ip to 0.0.0.0 then type "ipconfig /renew" and press enter if it takes a while and does not pull a new ip address then you may have a nic card or protocol issue. You can resolve this by uninstalling the network card in add remove hardware and then restarting the laptop. The system will automatically remove and reinstal the tcp ip protocol and all that goes along with it.
BTW if you get a 192.x.x.x for an ip then i am sorry to say but you are plugging into something similar to a router and then another approach must be taken.
p.s. a wireless router is a good investment if you have more than one system in the home. And may be a easy work-around to a NIC(network interface card) issue.
Hope this helps Good luck!!!!
Posted on May 31, 2008
No wireless single form router
Hi, according to the manufacturer information this router does not have a WiFi functionality
Dynex 4 Port Ethernet Broadband Router
Mar 16, 2014 | Dynex 4-Port Ethernet Broadband Router...
Want to connect aDI-604UP wired router to a DIR-615 wireless router to use as a printer port wirelessly
Hello Richard.
For this, you have two types of connection
1. LAN_LAN (ethernet to ethernet) -->wireless router is acting as a switch
2. LAN_WAN (ethernet to internet)-->wireless router is acting as a wireless router
in this case, you need the LAN_LAN connection
Physical connection:
plug an ethernet cable from the ethernet port on the wired router and connect the other end of that cabl to the ethernet port on the wireless router
Configuration:
log-on to the setup page of the wireless router, do this while the wired router is turned off.
-open your internet browser, type 192.168.0.1 on the address bar. Then type the username & password for the router ( default admin as the username, password : ).
Under the setup tab, click manual configuration. Then click network settings, change the router ip address to 192.168.0.5 & disable the DHCP server. save the settings. Just personalize the wireless network.
Hope this helps.
Sep 15, 2010 | D-Link DI-604 4-Port Cable/DSL Router...
How do i hook my xbox up to my computer to get on xbox live?
hi,
just to elaborate on zombies post.....
Zombie is correct in what she says...but in 'Laymans' terms.........
you dont need to hook up your xbox to ur computer to get 'On Live' .
The easiest way is a direct 'Ethernet' lead (plugged into the back of ur 360....(dont worry....u cant put it in the wrong slot....an ethernet lead will only fit an ethernet slot)) & the other end into an empty Ethernet slot on your broadband suppliers router (the little box they sent you which is plugged into ur fone line)....there are usually '4' ethernet slots on most routers ! once the ethernet lead is plugged in just follow on screen instructions (xbox) for 'signing' up to 'Xbox Live' :-)
hope this is a little easier to understand ??
p.s. Dont get ripped off buying an ethernet lead if u havnt got one long enuf ! dont let the shops tell you ur better off with 'Gold' plated ones !! its rubbish !! u dont need gold plated !
the usual 'bay' shop (u know who i mean??) have numerous suppliers....u dont want to be paying more than £5 for at least a 5 metre one !
p.p.s dont bother with the wireless adapters !! there pants !
good luck :-)
Feb 13, 2010 | Microsoft Xbox 360 Console
When i disconnect the ethernet from router to pc i loose internet, but get it right back when plug ethernet back in. I am not getting wireless however all equiptment says it is working properly.
I dont quite understand.
If you take away ethernet cable you will loose internet.
If your trying to make pc wireless you need a wireless ethernet adaptor,installed on the pc.
Jan 14, 2010 | NetGear WGR614 Wireless Router
I have 4 pots and 1 yellow where do i put my
Well you have netgear wireless router.On the back side you have 4 ethernet port where you can plug a cable which is coming from telephone.Its up to you if you want a wireless and your computer don't have a wireless adapter then to get a wireless connection you required a wireless adapter.Ya you can use internet connection with erthernet cable also
Hope this will resolve your issue
Nov 02, 2009 | NetGear WGR614 Wireless Router
WRT55AG router- wireless lights blink on and off and no ethernet?
If you plug in computers on the ethernet ports and they dont light up at all but you are sure that the cables that you are using works as well as the ethernet port on your computer that means that the unit is already defective. You can contact 8003267114 for replacement if its under warranty
Mar 06, 2009 | Linksys A+G WRT55AG Wireless Router
I unplugged the cable connected to my desktop and the wireless function stopped working
You must always have a 'host' adaptor whether you want a LAN or a WAN. Go to your configuration utility or control panel via your Run command to set or view your options. Steve Medley
Nov 07, 2008 | Belkin (F5D8231-4) Wireless Router...
Router Not Working
OK, check which address ya on... see there are a couple of sets... there is 192.168.0.*, and 10.1.1.* ... or the like sometimes the settings get screwed up..I suggest that ya reset it up all again using the Wizard... then go to each client and run Internet connection manager to establish the connection... Think of the router as a stand alone little PC... that "hands out" the address, to the clients... work methodically thru it & hopefully ya be all good to go?
Feb 12, 2008 | Hawking Wireless-G HWR54G (603992506064)...
Internet connection
Ok I have done it a little different sometimes... try this approach... First connect up the DSL Modem to the PC via Ethernet.. Configure the modem from the PC using the Connect to the Internet Wizard... enter all ya ISP details Logon, Password etc. Once this is going OK.. Disconnect the Modem... and then connect it up to the "Router" using the "Uplink" port and when connect ya Modem to the router... then connect another Ethernet cable from Router to same port on ya PC. Then simply use the network setup Wizard to set up an Internet Connection and connect up via ya router thru ya modem... generally works for me....
Aug 31, 2007 | Dell TrueMobile 1184 Wireless Broadband...
No Signal
hey i hope this issue has been resolved by now... ami i right .. if its not then jus lemme know n i l post ya the exact solution for this one ,,, i think its a very minor issue,,, plz respond
Aug 18, 2006 | Compaq iPAQ Connection Point CP-2W...
Microsoft Office Professional 2007 Full Version for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
