Question about Maytag 19 cu.ft. Top Freezer Refrigerator MTB1954
My MTB1954DRW Maytag Refrigerator is running, however both the freezer and refrigerator are at max temp ( 9 ) however are not as cold as they should be, it is barely keeping the produce, dairy safe to drink etc., please help
aborcass
  • 2651 Answers
SOURCE: Refrigerator is freezing on the produce side
if you get frozen fresh food the air damper is not closing allowing too much freezer air to enter ff section, looks like an electronic controlled wide by side you have, ther should be a tch sheet with a troubleshooting guide behind the kickplate or pasted in an envelope under the front of refrig behind kickplate.
Posted on Feb 27, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Food and drinks freezing in my refrigerator. How do I adjust?
Inside your refrigerator is a control on left side of the panel. Try to adjust there and try to close the dampers near the lower drawer bins. If that don't work change the temp a little higher in the fresh food compartment. But closing the ducts should do the thing. Let me know, Thanks Sea Breeze
#27 below in pic try ajusting the air coming into fresh food compartment.
seabreezehvac@yahoo.com
http://servicepartstec.blogspot.com/
Posted on Apr 21, 2009
  • 1214 Answers
SOURCE: RIGHT SIDE REFRIGERATOR DOES NOT KEEP FOOD &
Sounds like something has failed in the defrost control.
Check the freezer back, behind the panel. Looking through the louvers, do you see a heavy buildup of frost/ice? If so, then the defrost circuit needs to be checked out.
Let me know what you find, and if you are comfortable with diagnostic troubleshooting techniques, have a volt-ohm meter and know how to use it, and are comfortable with electrical troubleshooting and mechanical dis-assembly/assembly.
Posted on Dec 17, 2009
SOURCE: The freeze of my Maytag plus refrigerator is still
if the refrig.is old you must call a local refrig.repairman to refill it with freon,nothing you can do your self,needed special tools.
Posted on Apr 04, 2010
  • 2468 Answers
SOURCE: Helloi have a Maytag Plus side by side
remove the rear panel inside the freezer,your evaporator coil is iced over and cant transfer cold anywhere,deice it,then check the defrost heater under this coil,its probably open and cant heat to defrost the unit
Posted on Jul 28, 2010
Refrigerator warming (50 deg) while Freezer Temp OK or Colder than normal
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 24, 2010 | Maytag MBF2556HEW / MBF2556HEB /...
Refrigerator not cooling it is a maytag with freeser at the bottom freeser is maintaining temp
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Aug 02, 2010 | Maytag MFD2560HES Bottom Freezer French...
Maytag refrigerator isn't cold.
if freezer is working and ice mker is working . and fan / then only other is the damper in top center is not working . very common . mm
Apr 18, 2010 | Maytag MFD2560HES Bottom Freezer French...
Freezer is very cold, refrigerator not cooling on Maytag side-by-
heatman101
s
Nov 25, 2009 | Maytag MZD2766GES Side by Side...
Stuff in the freezer is melting, motor is running, no cold
turn your freezer temp dial to off and wait 30 seconds, then turn it back on to max setting. if you have temp gauage you can try to check temp inside freezer, if not cold enough (less than 30 degrees) you could be losing freon gas. you need to call technician.
Sep 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Upper freezer temp. alright Lower refrigerator to
Sounds like the airflow balance is off. When you turn the aircontrol to max what you are actually doing is starving the frig compartment of cold air, cold freezer, warmer frig. It is recommended to set both controls to middle and see if it helps the problem.
Jul 30, 2009 | Whirlpool Refrigerators
Refrigerator side temp keeps dropping below freezing.
Set the freezer temp control to MAX cold and see if it improves.
If not replace the off/on thermostat.(cold control)
May 24, 2009 | Kenmore Refrigerators
Refrigerator not getting cold enough
IF THE COMPRESSOR IS RUNNING ALL THE TIME IT CAN ONLY BE THE FREEZER IS NOT MAKING TEMP.OR YOU HAVE A AIR LEAK SOMEWHERE ON THE DOOR GASKETS OR WATER ICE DISPENSER,LET ME KNOW-MIKE
Dec 06, 2008 | Maytag MSD2656G Side by Side Refrigerator
Refrigerators Logo
207 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
