Question about Sharp XR-10X Multimedia Projector
Projector shuts off sporadically
I have owned my sharp xr-10x for 2 1/2 years now, and for the most part, it has worked well. My current remaining lamp life is 76%. However, recently the projector lamp dims, then turns off at irregular intervals (10 mins-over an hr). The fan remains on and, after a couple of minutes, the lamp turns on again. The standby/on light remains on through this, and the lamp light blinks green while warming up again. I am afraid my lamp life has diminished due to the frequent shut-off and back on periods. Any suggestions?
  • 2,237 Answers
Need to replace the lamp. i could have diminished not as much to frequent on and offs, but excessive dust. it's heating up too much and shutting down.
Posted on Aug 03, 2009
My Sharp XR-10x has no power or lights. Has worked and now does not.
if there are no leds lit, the bimetal breaker has probably tripped. remove the top case (6 screws on the bottom and the top 2 on the back). find the red button on the front of the lamp housing and press it. if it clicked, it has reset and will now work. if it didn't, you have a bad power supply. while you have the projector open, blow the dust out of it with canned air.
Dec 28, 2009 | Sharp XR-10X Multimedia Projector
New bulb in now wont work - no power - wont turn on to reset lamp
first, make sure you have the correct lamp. the lamp for the xr-10x-l looks like the xr-10x, but the plugs are different (common mistake). make sure you have the AN-XR10L2/1, not the AN-XR10LP/1. to reset the lamp timer (with the projector plugged in but off), hold down the enter, down arrow, and menu buttons and press the power.
May 30, 2009 | Sharp XR-10X Multimedia Projector
After 20 minutes of use picture shuts down. (Sharp XR-10X)
use canned air and blow every bit of dust out of every vent and hole. if you want to, you can remove the top (6 screws on the bottom, and the 2 top screws on the back) and blow dust out that way. i could also be a power supply problem. from excessive heat, the capacitors on the ps dry up and don't work as they should, causing shutdown.
May 24, 2009 | Sharp XR-10X Multimedia Projector
Sharp XR-10X projector, but missing the projector bulb.
if you plug it in and turn it on, you should at least hear fans running, then it'll shut down because there is no lamp. that's about it.
Apr 01, 2009 | Sharp XR-10X Multimedia Projector
Sharp XR-10X Bulb works once then nothing
this is something which sharp didnt foresee!!!!!!!!!!
sharp has two identical models
sharp xr10x & the newer model xr10xl.both the lamps look alike , however both have a different rating & reverse connector!!
i.e both cannot be interchanged!however if u have the old xr10x & if u try to fit the new bulb which is lower in wattage, it will explode in 20 mins
if you have bought a used projector , then u wont know if someone has interchanged the ballast!!
as this model was discontinued 2 years back!!!!
so confirm the model , it is mentioned under sharp name or at the bottom
good luck
Feb 05, 2009 | Sharp XR-10X Multimedia Projector
1. Pls check the airflow of the cooling of the projector, or just service the all unit.
2. As you told that the lamp life is 76%, Check the inner
reflector have shiny surface of dimmy, If not shiny, then replace
the lamp unit.
Enjoy
Viren
Jul 20, 2008 | Sharp XR-10X Multimedia Projector
Unit shuts off sporadically
Hello dear
You have not mentioned the lamp condition. Pls check the Lamp unit. If the unit has crossed over 2000 hrs then the problem is with SMPS.
I have solved one same problem by replacing the DMD module.
Pls clarify.
Viren
May 31, 2008 | Sharp XR-10X Multimedia Projector
Sharp xr 10x
You will need to open it up and flip this little breaker switch. It has gotten to hot and tripped itself. Dust it out while you are in there.
Apr 26, 2008 | Sharp XR-10X Multimedia Projector
Sharp XR-10X Multimedia Projector Logo
301 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
