Question about Statpower PORTAWATTZ 1000 Watt Power Inverter Car Speaker
My 1000 watt inverter has stop from supplying AC power
  • 17,130 Answers
Unless the set is checked into , it cannot be confirmed if the fault is due to :
Failure of the switching semiconductors- drivers- Mosfets
Failure of the transformer
Failure of the switching frequency generator-IC
Failure of the in voltage detect or relays.
Posted on Oct 11, 2010
My inverter keeps going to falt even though i only use it for a few seconds its only a few months old and has not been used mush its a 1000 2000 max
What are you trying to power with the inverter? Do you know how many watts your appliance need to run? Your 1000 watt inverter needs 83 amps from your battery to drive a 1000 Watt appliance. The minimum size wire you need to hook up the battery to the inverter is a size 6 as short as possible but no more than 25 ft.
Jul 28, 2011 | Inverter 1000-2000w Peak Surge Power
I have a 800 watt inverter an i use a 1500 watt kettle the inverter 15 amp fuse blew
The kettle is 1500 watt 800watt inverter is not big enough you'll blow fuse every time
May 25, 2011 | Inverter 1000-2000w Peak Surge Power
With 13.3 volts dc input only putting out 94 volts ac
AT 10.64 AMPS THIS WOULD EQUAL 1000 WATTS BECAUSE VOLTS TIMES AMPS IS EQUAL TO WATTS.
There may be a regulator that boosts the voltage when the inverter is in use. you might check in line voltage while in use and see what you get. Operating amperage should be around 10amps.
good luck and feel free to reply and vote. Joe
Feb 16, 2011 | Duracell Portable Inverter 1000 Watts
M/n cpi 1575 I've had my inverter installed in my
it indicates an overload situation
not enough information provided as to voltage supplied to the inverter and the voltage of the grinder
examples are for 110 volts ac with a current draw of 4.2 amps the wattage is 462 watts or for 240 v ac with 4.2 amps the wattage is 1008 watts assuming that it is 240 volts and the inverter has a maximum ate of 1000 watts then it is overloaded and circuit protection is cutting in
check the wattage of the inverter and the wattage of the ac units you use and if there is not a 25% difference in favour of the inverter then it is an overload situation
Jul 27, 2017 | Cobra ® Power Inverters
Suddenly my inverter connected lights stopped working, i went and saw what happened to my inverter, everything was fine in terms of lights that it indicates in normal conditions, only i saw a fuse was...
The most likely reason is that you tried to draw more power than it was capable of supplying. The maximum amount the inverter can supply is usually measured in watts and should be written on it. If the inverter can supply 60 watts it should in theory be able to operate a 60 watt bulb. In practice however if you draw the maximum that the inverter can supply it will cause something to give. You should use no more than 45 watts from a 60 watt inverter i.e. approx three quarters of the rated watts.
Jan 10, 2011 | Electronics - Others
I buy a new power inverter ERP 2300 12v/220Volts
What does the inverter over 600 Watt.
By what type of battery is the inverter supplied? How many Ah? What is its state?
In order to achieve 1000 Watt for 1 hour you need a fully charged 12 V / 100 Ah lead-acid battery.
If your battery is less then 100 Ah and is not very well charged or old (bad) you may not have over 600 W, but not bacause of the inverter, but the battery.
If your inverter stops due to low input voltage (you can see it in the digital display during operation).
If you want to check the real output power of the inverter you should connect it to a big (more than 200 Ah) well charged battery.
Jul 22, 2010 | PowerBright Power Bright ERP2300-12...
Need small microwave for inverter on houseboat
Look at the rating sticker on the oven and use the AC power rating as your guide. The cooking power of the oven is not important, but the power it needs from the AC supply is. Voltage times current is the supply power needed (watts), and you want an oven that will draw less than the inverter's continuous rating, less any power being used by other appliances.
For instance, a microwave rated for 120 volts AC at 10 amps needs 1200 watts. Your inverter would be OK with this as long as other devices aren't using more than another 1000 watts. You can't use the inverter's peak rating. That's only for brief bursts, like when the microwave first kicks on and draws some extra current.
Any mid-power (600 watts or so) oven should be OK.
Apr 16, 2009 | Emerson MW8627W Microwave Oven
2000 watt cobra inverter keeps saing olp, overload
2000w means is out off rang load 2000w plus then alarm beep have running.
Mar 24, 2009 | Cobra CPI 1000 DC to AC Power Inverter
Samsung CLX-216ON
The power requirement is AC 110-127 Power consumption is 300W. There is a Rating label on the unit. The Inverter may not be giving you enough current and/or frequency (hertz).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Aug 06, 2008 | Samsung CLX-2160N All-In-One Printer
Statpower PORTAWATTZ 1000 Watt Power Inverter Car Speaker Logo
128 people viewed this question
Top Statpower Car Audio & Video Experts
xxxxxx xxx
Are you a Statpower Car Audio and Video Expert? Answer questions, earn points and help others
