Question about Hotpoint Refrigerators
Freezer not working red light on indicating high temperature and fridge is starting to ice over, drinks forming ice in them
  • Hotpoint Master
  • 17,130 Answers
Top of Form
If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. If compressor is running check the pressure, get help to test gas pressure. If not you will need to fill up ,If gas pressure is good the possibility of the compressor being inefficient is high. In such a case you must take consensus to estimate and decide, if RPM of motor is low check capacitor.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test from the outside and make your observations so that we come to the solution.
Posted on Oct 11, 2010
The light inside the freezer compartment on the ice maker control is flashing red.
Hi Greg.
I'll have to stay general in answers since I don't know your particular make/model. Lights on the ice maker/cold water dispenser can indicate clogs, blockage, jams, or other things awry. A few things to consider:
  1. If the fridge has it's own water filter, has it been replaced anytime recently? If the filter is clogged, it may not be letting enough water flow through for the ice maker to think it's working properly.
  2. Chilled water is usually created by having a mondo coil of plastic tubing under the vegetable bin on the fridge side. It keeps half a gallon or so of water chilling as you get drinks, or as the ice maker draws on it (less heat in the freezer to start off with that way). That tubing also can get pretty rank, especially if the fridge has ever sat unused/unplugged for an extended period of time.
  3. You may have a jam or issue with the ice maker or ice delivery system. Ice delivery is usually a spiral piece of metal that extends to the back of the freezer compartment, comes out with the ice bin, and spins to feed ice to the dispenser. If it got wet and then froze, the bearing/bushing on it may be frozen, and triggering an alarm that the motor is having to work too hard to turn it (or giving up). pull the ice tray and make sure you can spin the shaft. if not, transfer the ice elsewhere and either let the bin come to room temp to melt the ice jam, or, if you're impatient, run warm water through it until it frees up. Make sure you dry it thoroughly before putting it back in the freezer, regardless of how you do that.
  4. The freezer could be over-temperature. You may want to look at the freezer thermostat setting, and whether it's getting there (you'll need a fridge thermometer to check). If it's way off, you may need to get the thermostat fixed.
  5. If there is an ice crusher, a jam there might also be the cause of the light. Harder to disengage than the ice bin probably, the particulars of checking it will depend on the model.
    I hope this gives you some useful ways to diagnose the issue!
    D
Dec 01, 2015 | Refrigerators
Frigidaire elite, red alarm light on,freezer defrosted, fridge icing up
Sounds like your heater is either out or the connectors are loose causing it not to be able to cool properly from ice build up
May 08, 2014 | Frigidaire Refrigerators
My fridge temp is at 64 but my freezer temperature keeps dropping
If the freezer is not cooling as desired it is possible that the blower is blocked.
Now Shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
Oct 28, 2010 | Frigidaire FRS-26DR7D Side by Side...
Freezer switching off on Hotpoint Iced Diamond Fridge Freezer
home refrigerators are not dsigned to work in areas where the temps will drop below about 45 f to my knowledge there is no way to help wiht this problem. Thx peyton
Jan 29, 2009 | Refrigerators
Hotpoint fridge freezer green and red light on, switch offering 0
It could be a few problems to do with electrics, but try this first:
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Dec 04, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Red light on Hotpoint Iced Diamond freezer
got a hot point iced diamond fridge/freezer, just got back off hols and red light on, all food defrosted with water running out of bottom. whats wrong?
Aug 27, 2008 | Refrigerators
Have a hotpoint rsf60 fridge/freezer,noticed over temp red light on, defrosted as ice buid up on top shelf of freezer.light still on red temp set at 3/4 ?
The red warning light will not go out?
1. Has the fridge freezer just been
installed? If so, this is normal and the
light will go out when the correct
temperature has been reached.
2. Has the fridge freezer been loaded
with a large quantity of food? If so,
the light will go out when the correct
3. Have the doors been closed
properly?
Jul 01, 2008 | Hotpoint Refrigerators
Layer of ice forming on bottom inside of freezer - Samsung fridge freezer
might have the temperature too high .. buy a freezer thermometer and place in freezer
Jan 20, 2008 | Freezers
Refrigerators Logo
113 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
