Question about Ariston Technologies LL64WNA Built-in Dishwasher
I have an LSv66 Ariston dishwasher. When it is switched on, no matter what program, the knob just stays in the same position. It sounds as if the dump pump is running constantly.
  • Ariston Tech... Master
  • 3,247 Answers
The dishwasher overflow detection may have triggered. This causes the drain pump to operate.
The overflow float is located at the base of the diswasher and maybe faulty. It is spring loaded float and should move down and up when pressed. If you cannot find this in your model, then water has leaked into the overflow cavity where the motors are located. This could also trigger the overflow protection circuit.
You have to replace the overflow float if it exists or empty the overflow water in the overflow cavity and dry it out. If leak is taking place then the gasket needs replacement.
Hope you are able to fix the problem with some of the suggestions I have made.
Please rate the solution if you find it helpful otherwise post a comment.
Posted on Oct 11, 2010
Ariston aq9l 29 u Wash cycle selector knob free-wheels?
Either the knob or the switch is faulty. Can you pull the knob off and see if you can set the program with pliers on the shaft?
Dec 05, 2014 | Ariston Technologies Washing Machines
Program knob
Maybe replacing the knob will be the answer.
Mar 19, 2014 | Ariston Technologies Ariston AWD12 Front...
The 4th green light on my Ariston dishwasher flashes. What does this mean?
You did not mention what model number that you had but this is what I found after a little digging:
From http://servicetechhelp.com/discus/messages/2801/6823.html?1205974228 :
For future reference, the technician who replaced the control board for me gave me a complete list of flashing LED fault codes for the Ariston LL65 (which are same as Ariston LL64):
001000 Float Switch: Water in Base Pan
001100 No Drain: Dranin Motor Disabled, Filters Clogged, Dramin Hose Blocked
001010 Main Motor Presure Switch Blocked Filter
100100 Control Board: Software of Control Board not Recognized.
000100 Water Valve: Water Valve Diabled <--- This one sounds like your error
000110 Fill Fault: Water Valve Disabled, Turbine Disabled or Control Board
000101 Heating Element disabled or High Limit Open or Control Board
000010 NTC defective or not positioned or control board
000001 NTC defective or not positioned or control board
KEY: 0 = LED off
1 = LED flashing
I also found this for a different model:
http://www.diybanter.com/home-ownership/89945-resetting-controller-ariston-dishwasher.html
No Program Code Fault condition
1 Heavy wash 1000 Operation of flood
protection system
2 Normal wash 0100 Heating
element/Thermistor/Thermostat fault
3 Rapid wash 0010 Drain pump fault or drain
blockage
4 Soak wash 0001 Not filling to correct
level within 6 minutes
Mar 02, 2011 | Dishwashers
I have an ariston dishwasher. it trips out the circut breaker every time i turn it on. all the motor, heating element etc are fine, so what could it be? im also after a wiring diagram. i think its an L65?...
When you say the motor and heater are fine have you applied an insulation resistance test to these components and to the whole machine for that matter. To trace a 'tripping' fault you need a megger, not just visual or a meter. You might go looking in the wrong place if you haven't megger tested the machine. Good Luck Tony
Feb 26, 2011 | Ariston Technologies LL65 Built-in...
Dishwasher Model LSV66 - door will not open
There is probably something broken with the latch mechanism as it is mostly made of plastic.
Safety first, ensure mains is off to dishwasher!
Your best chance of opening - Method one - first you need to understand how the latch works. In LSV66, the latch is right at the top, centre above the door handle and the ariston logo; you cant see any of these unless you have it opened - so try to imagine the mechanism as I describe; the door side is a tongue while on the dishwasher side it is a D-shape loop - at locked position, the tongue is inserted into the loop from below. So to pick it, use a coat hanger wire, bend it into L-shape. The problem is you need to slide this between the door and presumedly your worktop and slide it to the middle, learn where the latch is initially - the hard part is you need to slide the L-shape tip as close as possible the the door side, the tip should come in from sideway sp that you are trying to slide the tip arm of the L-shape underneath the d-loop and to unhook it is to flick the d-loop with upward turn and NOT downward since it loops over the tongue from top. Method two - assume you are confused about method one or simply cant slide the L-shape between the tongue and d-loop, the next best way is to pry the latch open, here you run a small risk of breaking the d-loop but you can easily buy a replacement spare - to pry open the door, use a sturdy tool if you dont have a suitable size crow bar - a robust screwdriver could do. You need to pry it close to the latch to get good fulcrum power, so approach middle above the logo between door and worktop - you are likely to scratch the top edge of the door but again this part is concealable when the door is shut so wont be too cosmetically bad.
Once opened, unscrew the top panel from inner door, you will find the latch mechanism which I assume something is broken - replace this by buying a spare - usually cost around £20.
Good luck.
Dec 29, 2010 | Ariston Technologies Dishwashers
Ariston dishwasher LS609 the cycle nob does not
Had the same problem with my 12 year old LS609. The cycle knob sits on top of what Ariston calls the control board. This control board is most likely to be your problem. It was in my case.
May 14, 2010 | Ariston Technologies LL64WNA Built-in...
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
Ariston L63 dishwasher stopped mid cycle with water in base.
1) Ensure the dishwasher is turned off. 2) (may not apply) Turn the plastic blue lever located under the sink to the vertical position (this opens the valve, so water can go into the dishwasher) 3) Pour powder indo the dishwasher 4) Turn the dishwasher controller to the top position (the 12 o?clock position) ? this is the eco-setting. 5) Press the on/power button on the dishwasher, so that it now turned on (a light will display) 6) Move the dishwasher controller to the ?R? position (it?s on the very left), and leave it there a second or two. 7) Move the dishwasher controller back to the eco-setting (the 12 o?clock position
Jun 16, 2009 | Ariston Technologies L63 Free-Standing...
Asko D1706
I also had this problem. Support person couldn't tell me if the pump was supposed to run even when setting the control knob to 'off' (bar before (1)). After draining the pan, the control knob functioned normally. So apparently any power to the unit will run the pump when the overflow pan is filled, no matter the position of the knob.
Sep 10, 2008 | Asko D1706 Built-in Dishwasher
Ariston LL64 doesn't start
4) Turn the dishwasher controller to the top position (the 12 o’clock position) – this is the eco-setting.
6) Move the dishwasher controller to the “R” position (it’s on the very left), and leave it there a second or two.
7) Move the dishwasher controller back to the eco-setting (the 12 o’clock position).
Jun 23, 2007 | Ariston Technologies LL64WNA Built-in...
Ariston Technologies LL64WNA Built-in Dishwasher Logo
679 people viewed this question
Top Ariston Technologies Dishwashers Experts
Electro Med Services...
Renee Knafel-Bullock
Are you an Ariston Technologies Dishwasher Expert? Answer questions, earn points and help others
