Question about Hitachi Heating & Cooling
Which refrigerant gas is used in Hitachi - RAU010HPD model?
Is the R22 gas applicable or does it have an impact to global
r22 gas has been found not to harm the environment and is available at leading hardware shops the sell refrigerant gas
May 06, 2016 | Hitachi A/C Compressor, R22, 12, 829 BTU,...
What type of gas refrigerant does Westpoint model WRD 260g Refrigerator use ?
THIS IS NOT A DIY JOB !!! See your local Refrigeration Mechanic/Engineer who will have the right equipment/knowledge AND correct refrigerant gas to do the job ... ok
Some older units will require MODIFICATION before this can be done !!!
Sep 20, 2014 | Refrigerators
I just want to regas it can you help and hou mutch gas must I put in
You need special equipment to re-gas a fridge as well as a special permit to buy the refrigerant.
Different refrigerant are in use and the volume is specific to a refrigerator model.
Sep 24, 2011 | Refrigerators
Model ec 510 just won't start. Can't find the reset button, unit is only 4 months old
I just looked a the owners manual, did not see a reset, try taking the plastic cover off and see it the motor has a button on it to reset the motor, the motor may be damaged also, always try to use a direct connection to the wall outlet for power, Hitachi air compressors dont like extension cords.
Mar 08, 2011 | Hitachi Air Tools & Compressors
I had a 53 fault on hitachi split ac system and after powering the condenser off and back on system now showing a p7 fault. Is this a refrigerant problem? Model no. Ras-6hrne
I think you should check your compressor manually . And then check the tempreature on discharge point of your compressor if tempreature increases then there is no problem of gas .
Nov 02, 2010 | Heating & Cooling
Haier Model HRT02WNC compact refrigerator not cooling what type of gas does it use?
this model is thermoelectric and has no gas in it.
It uses a peltier junction to provide a temp differential. the fan will run constantly, and it will cool the interior to about 35 degrees F below ambient. theoretically...
May 16, 2010 | Refrigerators
Can i use a impact wrench with my hitachi ec2510e gas air compressor
Yes, but it may drain your air supply quickly and you might have to take little breaks and wait for it to fill up again.
Feb 04, 2010 | Hitachi EC2510E 5.5hp Gas Air Compressor
Refrigerant gas used in Kenmore freezer
Hi: You didn't give me the complete model number. Not to worry though. Look at the model number tag of the freezer. If it's a newer model it will use R134A coolant. The tag will tell you the amount of refrigerant and the type. I hope this helps, Jeff.
Jun 09, 2009 | Kenmore 64802 Top Freezer Refrigerator
Heating & Cooling Logo
47 people viewed this question
Top Hitachi Heating & Cooling Experts
D. E. Hev
rugby prop
Are you a Hitachi Heating and Cooling Expert? Answer questions, earn points and help others
