Question about Garden
Looking for owners manual for a Murray select 40" lawn tractor model 40507X8A
4 Suggested Answers
  • 246 Answers
SOURCE: owners manual for a craftsman model 917255812 lawn tractor
Hello:
>>You can Use the Site Addys at this Site Addy; http://www.yetmans.mb.ca/antiques.html to Search and Locate New/Used Parts or for Manuals for this Unit.
Respectfully
John
Posted on Apr 21, 2009
SOURCE: Murray Lawn Tractor won't go up hill
Your drive belt is worn/slipping
Posted on May 31, 2009
  • 35 Answers
SOURCE: i need an owners manual for a murray riding mower.
First off, confirm that the tractor is in Neutral and the deck is not engaged. You also need to be on the seat, and in some cases your foot must be on the brake. Then try it.
If by "jump" you mean essentially connect one end of a jumper cable to the battery power coming to the solenoid, and the other end of the SAME jumper cable to the 6 gauge (+/-) wire on the other side of the solenoid that goes to the starter, and it cranks, this means one of two things.
More than likely it is the solenoid that is bad, but the only way to confirm this is to make certain that when you turn the key, it sends power to the small (18 gauge) wire on the solenoid. This is easy to check with a test light.
If power is goes to the solenoid when the key is turned, but the engine fails to crank then the solenoid is bad.
If no power is there, then the problem has something to do with either the ignition switch or ignition wiring, or more likely it is a failure of one of the safety switches, under the seat, transmission in gear, sometimes if the deck is engaged, or other.
One way to confirm that the problem is with a safety switch or ignition switch and rule out the solenoid would be to jump a wire directly from the positive terminal to the small wire on the solenoid that comes from the ignition. If this causes the engine to crank, then the solenoid is OK.
Posted on May 09, 2010
Lawn trc murray 17.5 hp 42in cut
my specialty,but,you didnt post what the problem is,so,here goes,if it wont start,it is probably a bad safety switch,take the small black wire off of the coil,if it starts,then its a safety switch,if it doesnt then it is the coil,if it only clicks with a charged battery,it is the solenoid,turn on your key and short between the two big bolts on it if it starts it is bad,if you need a belt,i will need the numbers under the seat,otherwise i will try to find them for you,i will post a user manual for you here, Murray 425607x52A 42 34 Lawn Tractor Parts
Murray 425016x48A 42 34 Lawn Tractor Parts
Murray 425306x48A 42 34 Lawn Tractor Parts
Murray 425600x48A 42 34 Lawn Tractor Parts
Murray 425618x48A 42 34 Lawn Tractor Parts
Murray 42560x52A 2000 42 34 Lawn Tractor Parts
Murray 42820x24A 1996 42 Inch Cut Lawn Tractor Parts
Murray 425619x24A 42 34 Lawn Tractor Parts
a few manuals,find yours here or go here to find it by the numbers under the seat,all part numbers are in them, Search eReplacementParts com
Apr 24, 2015 | Murray Garden
I am looking for an owners manual for 425000X8 Murray riding lawn mower
andrew?so you need a manual for 425000x8A this is a 2003 model I found this manual for free at murray.lawnmowerguides.com/murray-lawn-mower-manual.html when you see your model number on your mower it look like this 425000x8 the A tell you the year it was made the 2004 model is 425000x8B BOTH MOWERS LOOKS THE SAME AND THEY HAVE THE SAME FRONT GRILLE.
Sep 17, 2011 | Briggs & Stratton Garden
How to install drive belt murray lawn mower
You can go to www.murray.com , enter your model number and download an owners manual which will have the instructions and diagram on how to do it
Sep 19, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Model 40601B riding lawn mower-need tension pulley spring
Your owner's manual has a parts breakdown with all parts listed. Find the part # and order from local Sears store. No manual? Try the Murray website (www.Murray.com) and download the manual for model 425001x8D lawn tractor. Good luck!
Sep 15, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
May 31, 2009 | Garden
Garden Logo
99 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
