Question about GE Refrigerators
I have a PIT233GRD GE refrigerator and the board was trying to start but disconected inmediately, I took out the fan motor condenser and the board was able to start everything. I change the motor, conected and start doing the same. Could be that the board (the relay for the motor condenser) is bad or could be another thing. The board is expensive and want to be sure. Please help Max maxmejia2003@hotmail.com
  • GE Master
  • 17,130 Answers
If the board was trying to start without any response from the motor then it is possible you have a faulty capacitor- for starting motor- or a faulty relay where the contact points are dirty or burned.
make sure you get these two right and tested before thinking of the board as it is outputting the action.
Posted on Oct 11, 2010
I have no cold air in my refrigerator or Freezer. It defrosted everything.
Condenser Coils are Dirty
If the refrigerator is not cold enough the condenser coils may be dirty. The condenser is like a radiator and must stay clean in order to dissipate the heat which was removed from the inside of the refrigerator. As the coils get dirtier the refrigerator becomes less efficient, which makes it work harder to cool down. If the coils are dirty enough, the unit will never be cold enough and will not be able to cool the inside of the refrigerator to the proper temperature.
Evaporator Fan Motor
If the refrigerator is not cold enough, the evaporator fan motor might have failed. Every refrigerator has a set of coils called an evaporator. The refrigerator may have one or more evaporator fan motor(s) depending on the model and evaporator locations. The evaporator fan motor circulates the cold air from the coils thru the compartment. If there is only one evaporator it is in the freezer side. If the fan is not working, no cold air will get to the refrigerator compartment. The freezer may still get cold.
Condenser Fan Motor
If the refrigerator is not cold enough there might be something caught in the condenser fan motor blade, or the condenser fan motor might be defective. The condenser fan motor draws air over the condenser coils to cool them. The condenser fan motor is located underneath the refrigerator near the back. Pull the refrigerator out from the wall and remove the access panel to access it.
Start Relay
If the refrigerator is not cold enough, the start relay may be defective. The start relay is a small device mounted to the side of the compressor. It provides power to the run winding along with the start winding for a split second at start-up to help get the compressor started. If the start relay is defective the compressor may run intermittently or not at all and the refrigerator will not get cold enough. The start relay should be replaced if defective.
Temperature Control Thermostat
If the refrigerator does not get cold enough the temperature control thermostat might be defective. The thermostat allows power to flow through to the compressor, evaporator fan and condenser fan. If the cooling system fans and compressor are running, but the refrigerator or freezer is not cooling correctly check for an airflow or defrost system problem.
Start Capacitor
If the refrigerator isn't cold enough the compressor might be having difficulty starting. The start capacitor serves as a battery to give the compressor a little boost during start-up. If the start capacitor is burned out the compressor might not be able to start and run as often as it should. Test the start capacitor first with a capacitance meter, they don't fail often. If it's defective, replace it.
Thermistor
If the refrigerator is not cold enough the thermistor might be defective. The thermistor is a sensor which monitors the air temperature. It is connected to the control board. If the thermistor is defective the refrigerator does not cool or may cool continuously.
Temperature Control Board
If the refrigerator is not cold enough the temperature control board might be defective. The temperature control board provides the voltage to the fan motors and compressor. These boards are often misdiagnosed. Check all other components to be certain this is the cause of the problem.
Compressor
If the refrigerator is not cold enough, the compressor might be defective. The compressor is a motor which compresses the refrigerant and circulates the refrigerant through the evaporator and condenser coils. There are several other components which are more likely to be defective if the compressor doesn't work. If the compressor itself is defective a licensed professional will need to replace it.
Main Control Board
If the refrigerator is not cold enough the main control board might be defective. This is not common. Check the defrost system, cooling fans, and cooling controls first.
Jun 28, 2017 | Refrigerators
Condensor Motor not working
You either have a faulty condenser fan motor, or bad main board. You should have 24vdc at the motor if not you have a bad board (just make sure that the machine is calling for condenser cooling before deciding on your diagnosis)
Aug 05, 2013 | GE Refrigerators
My GE GSL 25JFPABS Refrigerator failed yesterday. No Comressor no evap or condensor fan
Fan motor starts with the compressor. Sounds like you need a main board and condenser fan motor. Call GE. It might be covered under warranty. A known issue with certain models. You will also need serial # if you call.
Mar 23, 2017 | GE Refrigerators
I have a ge sbs model pcp23shmffbs. the condenser fan motor is running slow, but turning freely. the fan motor is rated at 11.3 volts dc and supply to fan motor is only 6.7 volts. is the condenser fan...
If the motor is running, but running slowly, you will need to replace the motor. If there was a problem with the PCB, (control board) the motor would not run at all and you would see other problems with the refrigerator.
Here is a link to the motor.
Jan 28, 2011 | GE Refrigerators
GE Monogram ZISB36DYB Freezer Not Cold Enough; Burning Center
Pull the refrig out , and remove the panel at the bottom , on the back . Behind this panel , will be the compressor and condenser " roll " coil , and the condenser fan motor . From your description of the problem , the fan motor in not operating , or the coils are extremely clogged with dust . If the fan motor is not operating , the most likely cause , is the main control board . You can try replacing the motor first , but , the board is most likely the cause . This is the electronic board , behind the 8 " X 10 " panel , behind the refrig also . If you remove the panel , and look at the board closely , You may see a burned part ( resistor ) . However , replacing the burnt part , will not solve the problem . The complete board will need to be replaced .
Oct 14, 2009 | GE Refrigerators
RELAY CLICKING ON MOTHERBOARD ,COMP&FANS INOP UNLESS ON OF THE FANS ARE DISCONECTED THEN ALL WORK UNTIL COMP.CYCLES GE SIDE BY SIDE FRIDG. GSH251GRBWW
first unplug fans. on at a time to check if you have a bad fan motor...shorted fan will cause the relay to get stuck...if fans are fine replace control board...3yr Wty on most board
Sep 19, 2009 | Refrigerators
Slow condenser and evaporator fans on SDL20KCSABS
Newer GE refrigerators use variable speed DC fan motors to improve energy efficiency. Fan speed is determined by the electronic control board. Your refrig is working as designed.
Please don't rate solution, as anything but a Fix-Ya lowers my overall score. Thanks.
Mar 03, 2009 | GE Energy Star SDL20KCSBS Bottom Freezer...
GE PROFILE FREEZER PFS 22 SISBSS
hopefully you have a service warranty. I have had me fridge for two years and have replaced the temp control panel twice thus far. serviceman coming AGAIN on Tuesday because now everything in the fridge is freezing. cna't get the temperature in freezer and refrigerator regulated properly. GE knows they have a problem...something in the computer panel board sticks. I'd give anything to be able to put this on the curb and buy a new refrigerator.
Jul 19, 2008 | GE Profile PFS22 33" Artica French Door...
Ge refrigerator model PDS20MBSAWW
gee seems to me if your are getting the proper voltage witch you say you are sounds to me like a bad condensor fan motor. is the compressor running, maybe shut off because it was to hot.and you are right the motor voltage is from the board. we have had alot of mother board failures on the ge line. but that would be the problem if you were not getting power to the motor.on some models the power comes from the relay /overload hooked to the compressor. if the compressor doesnt come on and you hear a clicking from it every few minutes then you could have a bad
overload and relay that is mounted to the compressor.if thats all good then id say order another motor.
ALL BRANDS APPLIANCE REPAIR
5008 W. LINEBAUGH AVE #8
TAMPA FL 33624
OFFICE # 813-908-2002
FAX # 813-908-5559
WEBSITE allbrandsappliancerepair.com
EMAIL customerservice@allbrandsappliancerepair.com
Jul 11, 2008 | GE Hotpoint Top-Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
