Question about Virtual Reality VRCD500-SDU CD Player
No sound. Tried all solutions posted.
I have a '97 pathfinder. I bought a Car Stereo wire harness at Best Buy that fit my car so I didn't cut into the factory harness
. The harness fit, I installed the wires as directed (all clearly labeled) and I have no sound at all in any mode.
I looked up trouble shooting on the VRCD500-SDU and checked all the solutions that were given and none seemed to change anthing.
Would the ground have anything to do with the problem? I am grounded to the steering braces that are bolted to the frame.
What is the red flashing light? I pushed the reset and nothing changed.
What is the A/E switch do?
Thank you for your help, Chris
  • Anonymous May 13, 2009
    The unit turns on, both the sub and rca outputs have "output", but the speaker wires are not giving any output.
  • 86 Answers
Are you using the speaker outputs? If you are using the rca pre-outs for an amplifier they are mislabeled. The subwoofer out is labeled as the front output and it is off when shipped. Connect to rca out labeled as the sub and you should get sound. The sub out can be turned on from the front panel by pressing and holding the "band/sub" button. The flashing light intended to mimic an alarm, it has no other purpose.
Posted on Jul 13, 2008
I have a Nissan Pathfinder 2006 I took out the stereo and I want to install my own . the harness connector I cut I need to know what wire is what on the Pathfinder 2006 so I can install my stereo
Reattach the wires and buy a wiring kit you can pick one up at Walmart now or any car part store for about $20. They're color coded and let's you wire up any radio in 5 min. Worth the money and keeps you from shorting out your radio or other circuits.
I haven't cut a radio harness since the early 90s no need to anymore. Good luck
May 29, 2015 | 2006 Nissan Pathfinder
Can I buy a VR500CSBT connecter to female ISO connecter to fit VR500CSBT in my Vauxhall Corsa as I don't want to cut the indvidual wires of the conecter that came with the stereo and join it to an
they sell wiring harnesses that connect to the car manufacturers radio/player harness with wires to connect to after market players, do they sell one for your car? not sure
Mar 10, 2013 | Roadmaster (VR500CSBT)
Tried installing a new stereo system and had it in and going but the speedo wouldnt work so took out the stereo and it would work again then tired replacing fuse in stereo as it had blown and tried once...
your best bet is to buy a chiltons book for your car from an auto parts store. also i might add: reconnect your wires to the factory plugg you cut off and buy a wiring harness from a car stero installer or radio shack for your car it will automaticaly adapt your original harness (which your having trouble with) to a standard wiring setup for an aftermarket stereo. then its all about maching colors :)
Jan 31, 2011 | Car Audio & Video
97 lexus stereo has no read out cannot tell what
best buy sells a kit where u can install a aftermarket stereo in your car youll need a mount kit and a wiring harness
Jan 18, 2010 | Car Audio & Video
I need to know which colour wire from the radio is for what, so i can fit a non standard stereo
My best advise is not to cut the stock wire harness plug. Go online or to your local best buy and buy a wiring harness that will plug into your stock plug and into the radio. then you don't need to know what any wires are. cutting the stock harness is opening a can of worms.
Dec 23, 2009 | Car Audio & Video
How to hook up the pioneer stereo to wire harness?
Not real clear on question, but you can buy a direct fit wire harness and the wires are color coded so you don't have to cut and splice your wires on your factory harness.The harness hooks to your factory plug and you wire it to your pioneer stereo wires. Harness is about 7.99 up at most stores.
Nov 03, 2009 | Boss RT-6CK Car Component System
Car stereo switch out
Ok, first off, NEVER CUT WIRES!!!! what you need to do is go to your local audio store ie. best buy etc. buy a wire harness. It makes everything so simple, just match colors. If your wires are already cut, then you need a haynes manual about $15.
Feb 10, 2009 | Alpine CDA-D855
Wiring harness
you should never cut the wires on your factory harness... metra and other companys have harnesses that fit your car and would provide you with a correct wire color code you need to hook up a aftermarket stereo keep that in mind but i will post the wire diagram u are looking for
Aug 08, 2008 | 2002 Honda Civic
I am having trouble trying to install a stereo to my 1994 lincoln town car because i dont now the color code to the radio harnes so i can install it
Best thing to do is purchase a Radio Wiring Harness. These can be purchased at a Store like Circuit City, Best Buy, WalMart (not sure of your location) or a 12 Volt Specialty shop.
This harness will connect to your new radio harness and plug directly into the vehicle harness without having to cut wires. The Radio Wiring Harness will come with color identification to match to your radio harness.
FYI http://www.installdr.com/QuickWiring.html
Jan 12, 2008 | Car Audio & Video
Virtual Reality VRCD500-SDU CD Player Logo
171 people viewed this question
Top Virtual Reality Car Audio & Video Experts
Mark Skinner
Are you a Virtual Reality Car Audio and Video Expert? Answer questions, earn points and help others
