Question about Haier 5.3 cu. ft. Chest Freezer HNCM053E
I need a replacement hinge for my freezer - Haier 5.3 cu. ft. Chest Freezer HNCM053E
Does anyone know how to replace the hinge DA61-04866A on a Samsung french door vertical panel
unclip the plastic cover off your door hinge and unscrew the screws on your door make sure you leave the top screw in just a bit so you can take it out with your fingers before you drop the door ok same for both sides
Jan 22, 2015 | Samsung RF263AERS - 26 cu. ft. French Door...
I have 2 big old chest freezers--Kenmore 122 and Coronado 193. The doors on both of them will not stay open whenever I put in/take out items. I assume it is in the hinges but how do I fix them?
These models have a spring built into the hinges. You can remove a hinge and take the spring out and try a local hardware store or online @ Graingers
Because replacement parts are hard to find for these I have seen folks us the hydraulic hatchback shocks to assist in opening the lids and holding them open. Other have just made a prop rod similar to a car hood support.
Sorry I couldn't give you a direct link to replacement parts, But I tried my best to find these springs.
Best of luck!
Oct 11, 2013 | Freezers
I have a kenmore upright freezer model 970-254326 bought in 2011 from sears. The door opens left to right but in my tiny apartment I NEED it to open from right to left just to put things in and get th
You should see some plastic plugs or holes for mounting bolts on the opposite side of the freezer case. The latch mechanism should adapt from one side to another.
You would remove the top hinge and then lift the door off of the bottom hinge. Then you would remove the bottom hinge and switch it to the other side. Place the door onto the bottom hinge and then install the top hinge on the other corner of the case to match.
You should be able to move the handle from one side to the other. The magnets in the doorseal should work as before to keep the door closed. The interior light is usually centered on the bottom to aid in reversing the door opening.
Dec 30, 2011 | Kenmore Freezers
Change doors of fridge freezer from right opening to left opening needless to say cannot find instructions after 10 years
tilt unit backwards,and under hinge side you will see a bracket,undo bolts and transfer to opposite side leaving loose,slide door down ,then on top of door transfer plug to opposite side(if needed)slide door back up and refit bottom hinges/tighten bolts.
handle is just a matter of prising plastic cover of and unscrewing,then refitting to other side.
once you tip it backward its pretty obvious really.
Mar 13, 2010 | Engel Freezer 22 Qt. Fridge/Freezer
Chest freezer lid wont stay open without holding it open, its a Westinghouse 25 to 30 years, is there any adjustment that would solve the problem?
the hinges are bad and need to be replace
go to sears.com and click on the parts link
there enter the complete model number or call them if you want 1-800-252-1698
check to see if hinges are still available
hope this was helpful
Mar 07, 2010 | Kenmore 12.8 cu. ft. / 362 liter Chest...
How do i change my freezer door to open the other way
you will need to take the upper hinge off first, then the door will lift off the bottom hinge. Then take off bot hinge and move both hinges to the holes on the other side. As far as the handel goes, you may need to flip it over or switch the handel to the other side
Oct 27, 2009 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
Coldtech freezer door reversal
http://www.ascendmfg.com/PDFs/CT/hdmanual.pdf
start at this web site and see if this manual will help. It has phone number on last page if you need to call them.
ColdTech is now Jimes Corp. Just Google you unit if what I have does not help enough.
Good luck to you.
Oct 21, 2009 | Coldtech 21 cu. ft. / 595 liter Commercial...
Door doesn't close properly, leaks water
If the door seals are still pliable and intact there are two possible causes.
1/ The upper door hinge on the top of freezer unit has two adjusting screws under a plastic cover/cap which allows the upper hinge to be set forward or back altering/adjusting the spacing of the door seal to the freezer body. Moving the hinge outward at the top will cause the door to seal tighter at the bottom and lessen escaping cold air and condensation to form (water droplets). Adjust carefully so as not to create a weak seal (air gap) along other sealing edges of the door frame.
2/ Many United Refrigeration Commercial Freezers are manual defrosting. Moisture from inside the freezer can condense between the inner molded door panel (door shelves) and the exterior metal door. Usually ice buildup will occur in this space, but when defrosting or during high ambient temps the ice will melt and drip out along the bottom door edge/seal. Screws alomg the door frame (hidden by the door seal) hold the seal in place and also the inner molded door panel. The inner panel can be removed to replace the seal or to remove the ice buildup.
Jun 04, 2009 | Freezers
Chest freezer lid repair
if your freezer has the sping etc in each of the hinges, then yes take them off. If your freezer has a torshon bar type spring, DO NOT take the hinges off, as you will not get it back together
i have always replaced liners with the door attached. The lid of the freezer is going to bow out of shape when you remove all the screws and take the old lining off, so you need to replace the lining and leave the screws loose so you can realine the door bit by bit.
it is a bastard of a job, and i wish you all the best.
May 01, 2009 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Older Danby Freezer Lid will not stay open on its own
Hello ddelahay
Welcome to Fixya
My name is Huum,
At this site you can enter your model number and get diagrams and order hinges to replace your broken ones
This should allow you to fix your problem.
http://www.pcappliancerepair.com/
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Feb 02, 2009 | Danby 7 cu. ft. / 198 liter Chest Freezer...
Haier 5.3 cu. ft. Chest Freezer HNCM053E Logo
59 people viewed this question
Top Haier Freezers Experts
Victor Nwachukwu
Victor Nwachukwu
Charles T Nevin
Charles T Nevin
christian nielsen
Are you a Haier Freezer Expert? Answer questions, earn points and help others
