Question about Globe AUBURN TIGERS MUSICAL GLOBE - TERRAPINS MASCOT REPLICA IN MUSICAL GOBE
The glass that holds the water and snow has broken,can this be repaired
  • 490 Answers
If you have all the pieces, it can be repaired. the tricky part is getting it refilled and sealed. If the globe is glass, you can use any cyanoacrylate glue (crazy or super). If it is synthetic, it is important to get an adhesive that is compatible with the material of the globe.
Posted on Oct 11, 2010
I DROP MY WATCH CODE REF IS 1142 I BROKE THE GLASS WHERE CAN I BUY A REPLACEMENT GLASS FROM
Getting a glass shouldn't be a problem, but as it sounds as though you intend to fix it yourself, then please be aware of the following.
It is essential to get the correct size glass - even 0.5mm difference in the diameter means either it won't fit or it's too small and falls out again. As you say that the glass is broken, I would be surprised if you could remove it and still determine the correct diameter.
You need to think not only about how to remove the broken glass, but also about how you are going to fix the replacement one. Many watches have a very fine plastic ring around the glass that holds it in place and this may have also been damaged.
Also, with many watches it's necessary to remove the back, crown and movement to effectively replace the glass.
If your watch has any sort of water-resistance rating then it would need to be retested afterwards.
Bearing all this in mind, I strongly advise you to take your watch to a reputable watch repairer and let them sort it out.
If the glass is anything other than round, then the cost tends to go up. Get an estimate from them first, and decide if what they will charge you is reasonable - if it isn't then spend the money on a new watch.
Hope this is helpful.
Oct 22, 2017 | The Watches
How do I replace a broken rear quarter glass?
You have to remove the rubber moulding that holds it in place. I would highly suggest a windshield/glass shop for this repair so no moulding/paint damage occurs
Oct 04, 2015 | 2005 Saturn VUE
1991cadiliac seville how to put front driverside window back on track
When your window is frozen shut, and you try to clear the snow or ice by rolling it down, you risk detaching the piece from the window that connects it to the up/down arm.
Take it to an auto glass repair place. Let them take the door panel apart for you and replace the broken piece for you---it's harder to do yourself than you think.
Mar 05, 2015 | 1991 Cadillac Seville
Window on 2001 toyota solara "fell" down. What's wrong?
A few possibilities, either the window regulator has broken, or the bracket that holds the glass at the bottom has come loose from the glass. The bracket can pull off the glass, especially with power windows when you're trying to lower the window and it is stuck from freezing or old glass runs that are trapping the window from moving.
re-installing the bracket to the glass is often tricky, and it is easy to shatter the glass. Often best left for a car repair shop or an automotive glass shop to repair.
You will need to remove the door panel to inspect for what the issue is, and then repair it accordingly.
Jan 16, 2014 | 2000 Toyota Camry Solara
Water drains back into dishwasher from sink or disposal
You've got a broken piece of glass or something holding the drain valve open.
Solenoid operates the valve to drain water from dishwasher into drain line.
When power shuts off to solenoid...valve closes.
If valve is blocked by a piece of glass or toothpick or a sliver of bone...it can't close and draining water from disposal or sink can back flow into dishwasher.
I had a piece of glass caught in mine.
Hope this helps...
Jul 23, 2011 | GE Dishwashers
I can no longer unscrew the plastic part that the glass container fits into on my old Waring 18BL28 blender. It is a simple 10 speed that works perfectly.
Something sticky is in the threads... Try very hot water in the sink as a start, while boiling some water on your stove. With the glass and plastic preheated, install them to the blender base which must be unplugged for the rest of this adventure. Pour the boiling water in, only to about 1/3 of capacity. Install the top cover to protect from the hot water. Hold the glass by the handle and with a rubber glove on the opposite corner or pour spout side. Hold high to avoid the heat from the water. Have a large burly man hold the blender base so that you may twist the glass container counter-clockwise. Stop as soon as it starts to turn the plastic ring off...and go the the sink... Continue after pouring out the hot water. Remember that his procedure is likely to cause broken glass or broken plastic and exposure to scalding hot water. If those risks are acceptable you should still take precautions to protect your flesh. Otherwise order a replacement ring and pitcher for the blender.
Dec 23, 2009 | Waring Blenders
Outer glas of the dor broken its a QA make built
I will give you summary instructions on how to repair the door outer glass on a built in kitchen.
Prepare a space on a table, where to work on the door. Cover the taple with newspaper.
Remove the door. On some model you may just need to lift and pull, on others you need to free the hinges, usually undoing few screws.
Put the door on the table. Remove fragments of splintered glass if the glass is falling apart, otherwise leave it all in one piece.
On the table remove the set of screws that are holding the external frame and glass.
Remove external glass and replace it. You can use pliers and a cloth if needed.
Do operations in revers order to refit new glass.
You can find parts here:
Appliance Parts -Research, Repair & Replace.
Oct 14, 2009 | Ovens
Is there a way to glue or bond or somehow repair broken plastic on a side mirror on a 2005 RAV-4?
Yes there is is you have a broken glass you can go to a local mirror shop and they can cut you a new one for about 10 bucks, then you can supergule it onto the inside fixture where the glass rests and hold it for about 4 minutes in place. Or use masking tape to hold it in postion. There are some plastics that super glue wont stick to so you may have to try 5 minute epoxy to hold it in place mix enought so that the epoxy will surrround baracket that holds the mirror.
Jul 19, 2009 | 2004 Toyota RAV4
Water standing
Heool Isharpbailbo,
ngfam1 At your service!
Sounds like it may be one of a few problems,
1.The drain may be clogged going out to your kitchen sink
2.There may be some food or debris at the bottom of the inside of the dishwasher blocking the drain screen. BE CAREFUL RUNNING YOUR FINGERS DOWN IN THE BOTTOM OF TH WATER!
There may be broken glass in there that you can not see through the water , holding back food causing the blockage!
I cut my finger once clearing this to quickly.
3- you may have a bad pump that may need to be replaced.
USUALLY its a blockage some where from the dishwasher to the drain.
I once saw a large piece of broken glass in the drain holding the food particles back.
That's the on that got me so move your fingers real slowly in there , if you must use your hands.
I recommend hands on service if it's a fairly new machine!
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN O
Sep 10, 2008 | Dishwashers
Oven Door Inner Glass Replacement
can you gals get me the complete model # off the stove and i will look up the parts diagram & exploded view.
Nov 20, 2007 | KitchenAid KGST307 Gas Kitchen Range
Globe AUBURN TIGERS MUSICAL GLOBE - TERRAPINS MASCOT REPLICA IN MUSICAL GOBE Logo
285 people viewed this question
Top Globe Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Globe Toy Expert? Answer questions, earn points and help others
