Question about QDI Group QDI Advance 10F Motherboard
Manual para conectar los puertos usb delanteros
Pasar imagen a una tv
Si su TV tiene puerto USB solo tiene que pasar la foto al un USB y luego conectar el USB a la TV. Tambien si la foto esta en la camara, en mucho de los casos la camara viene con un cable para este proposito. Vea algunos ejemplos aqui
cable camara tv Google Search
Mar 12, 2014 | Gateway NE56R10u Laptop Intel Celeron...
No puedo saber como conectar los puertos usb delanteros
google translated
I can not know how to connect front usb ports
if you are referring to a usb drive
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp or earlier
click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with this or if i have missed the problem post a reply
hope it helps
Oct 01, 2012 | Intel Motherboard
No se puede conectar usb y como hago para atualizar el sistema
No estoy seguro de lo que quieres decir pero si te refieres a:
No puedo conectar un USB mientras estoy actualización:
Usted tendrá que esperar para que sea terminado antes de que conectarlo
Si se refiere a:
No puede conectar algo en el usb:
Busque en su guía del usuario para ver donde están los puertos. htta pueden serle de ayuda.
Espero que esto ayudó!
May 26, 2011 | Computers & Internet
Deseo conoser con exactitud los tipos de puertos o conexiones que lleva el computador hp pavillon 1000 grasias
2 puertos de salida de audio para aud?fonos/bocinas
1 puerto de entrada de audio para micr?fono/l?nea
3 puertos USB
1 puerto VGA (monitor, proyector)
1 puerto de expansi?n
1 puerto RJ-45 (red)
1 puerto RJ-11 (modem)
1 bah?a PC Card
1 puerto S-Video *depende del modelo*
1 Lector de memorias 6-en1 *depende del modelo*
1 puerto 1394 (firewire) *depende del modelo*
May 04, 2011 | HP Pavilion dv1000 Notebook
NECESITO EL MANUAL DE Placa base 945GCT-HM PARA CONECTAR LOS CABLES DE PW ETC DE ESTA PLACA
Apr 25, 2011 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Me han venido un monitor compac presario fx 700 mas no se el manejo de sus opciones por ejemplo para escuchar los puertos de usb no funcionan o que debo presionar o es qe no me han entregado todos los...
Lo único que puedo decir es ir a este sitio web, http://download.driverguide.com/driver/COMPAQ+Presario+FX700/Microsoft/d75443.html y descargar los controladores para el usb, y visite el sitio web de HP www.hp.com y encontrar el manual para ello. Lo siento por el español malo, yo estoy usando traductor Google para hacer esto.
Jan 29, 2011 | Compaq Presario FX700 17" CRT Monitor
Deseo instalarle unos puertos de usb y audio y video frontales pero no se donde conectarlos
Los puertos en donde tienes que conectar el USB y puertos de audio se da en el manual de la placa.
Jan 28, 2011 | Compaq 187498-001 Motherboard
Necesito configuracion de m955g v3.0a
Intente distinguir que tiene el problema. Si más de un dispositivo del usb no funciona, necesitamos localizar averías los puertos del usb. Si usted tiene apenas un dispositivo del usb para probarlo con, usted puede querer intentarlo en otra computadora. Dónde usted está conectando los audiophones?
Nov 04, 2008 | PC Chips M955G Motherboard
Como hago para conectar los puertos usb
Hola, espero que sabes leer ingles, baja el manual (ingles) en la sigiente coneccion: http://download.asrock.com/manual/K7VM2.pdf
Apr 30, 2008 | Asrock K7VM2 Motherboard
QDI Group QDI Advance 10F Motherboard Logo
104 people viewed this question
Top QDI Group Computers & Internet Experts
Tom Chichester
Bill Boyd
Are you a QDI Group Computer and Internet Expert? Answer questions, earn points and help others
