Question about Dell Inspiron 1521 Notebook
I replaced the fan. Took most of the computer apart to get to it. Put it back together and fan works. Now I'm having issues with the monitor. It boots up red with flashing lines then pink then the screen goes black.
  • 2 more comments
  • keajg29 Oct 12, 2010
    screen completely black now. It lights up but I can't get to the bios. Maybe a loose wire?
    I unplugged everything plugged it back in now the screen is black. It is lit. I cannot view windows or get into bios.
    I need another idea
    how easy is this to replace?
  • 2,973 Answers
Boot up in Safe Mode and reset the display from the control panel. Else, restore to an earlier date or try the Last Good Boot Up option. Both these are after pressing F8 at boot up.
Posted on Oct 11, 2010
  • Rinoo Kumari Oct 12, 2010
    I am sure the monitor s fine as you have done nothing to it. The only fault lies in the motherboard and its connector. It should be the connector most probably. The 15 pin socket and its lead to the motherboard.
    Then use a different monitor or connect this monitor to a different pc to make sure the monitor works or the pc works. Point is that unless you have display there is very little one can do with it.
Marcy Upright Fan Cycle - Fan Hitting Cage As It Spins
You did great with the assembly, however, you're off on the alignment. Try to adjust to pull the axle in the opposite direction to clear the cage.
Nov 11, 2013 | MARCY MCPL 105 Upright Fan Bike
I took my kitchenAid stand mixer (md# KSM5PSAC) apart to replace the plastic gear inside of it. When I put it back together it would not start. I took it back apart took a good look at all the connections,...
You need to either re-time the speed control switch at the back or replace it. If it worked great before then it is just an adjustment to get it back to running correctly. YouTube viseo available for timing the switch
Aug 06, 2013 | KitchenAid K45SS Classic Stand Mixer
Monitor black but power light blink green
The 470uF 25 Volts capacitors on the power supply board are probably bad. Replace them all and tell us the result !
Feb 24, 2010 | Hannstar I-Inc TW-191D Monitor
Computer screen goes blank after a couple of seconds
the back light of my hp w1907 will only come on for a second than go back off?? the rest of the monitor is working can see the image if you shine a light on the screen ..any help??
Comments: Oct 26, 2009 - so this monitor was not in warranty so i took it apart i found a wire broken off one of the backlight bulbs, ( be very carefull the bulbs all four of them and the lcd screen are very very fragile ) so i soldered the wire back on and put it back together and rechecked it it has been working like new
Nov 24, 2009 | HP w1907 LCD Monitor
The metal strip on the bottom, can it be replaced?
There are no replacement parts for this fan available, however I managed to get mine spinning like new after it had died. I took the two halves of the fan body apart, and scraped the heat sink compound off either side of the power plate. I then applied CPU heat sink compound that can be found at any computer or electronics store liberally to either side, and put it back together. The fan spins like new, spread the word!
Sep 27, 2009 | Cfm 802 Ecofan Table
Same problem here
These fans can be rebuilt! Like many others, our fan died after being placed in the center of the stove top. I took the two halves of the fan body apart, and scraped the heat sink compound off either side of the power plate. I then applied CPU heat sink compound that can be found at any computer or electronics store liberally to either side, and put it back together. The fan spins like new, spread the word!
Sep 23, 2009 | Cfm 802 Ecofan Table
I-BOOK A1005 Monitor dead....
this should be because the parts inside doesnt fit properly
Jul 03, 2009 | Apple iBook Mac Notebook
Ecofan only turns slowly
Nov 28, 2007 | Cfm 802 Ecofan Table
Dell Inspiron 1521 Notebook Logo
97 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
