Question about Vacuums
Need instructions for sioscan automic clock - Vacuums
  • bjhutton Oct 11, 2010
    These instructions won't work with my clock. It has only 4 buttons on the back for setting it---set, +, alm and snz. The model # is 86722.
  • bjhutton Oct 16, 2010
    thank you
  • Vacuums Master
  • 6,993 Answers
unfortunately, the instructions/manual for your sioscan automic clock is not available anywhere online. The manufacturers of this product did not make it available. I went further searching and couldn't find any.
I would suggest you contact the manufacture of the
sioscan automic clock via phone or e-mail and request for the manual from them. They might give it to you or direct you to a dealer where you can get the manual.
But I can give you instruction on how to set time on your sioscan automic clock:
A SkyScan Atomic Clock (SioScan refers to the built-in thermometer in some models) sets the time and date automatically by receiving an accurate time signal from the U.S. National Institute of Standards and Technology. However, your clock may not receive the signal due to geographical location or a close proximity to transmitting electronics like antenna televisions and cordless phones. If this is the case, you can easily set the time and date manually on a SkyScan Atomic Clock.
  • Slide the power switch to ON.
  • Find the reset hole on the back of the clock. Use the paperclip to press the reset button located in the hole
  • Set the clock to Daylight Savings. Slide the mode switch to Lock. Press the DST/YEAR button once to turn on. A "*" symbol will appear on the display that will indicate that the clock will automatically change during Daylight Savings Time.
  • Slide the mode switch to DATE. Hold the Year button and release once the on the correct year. Hold the Month button and release once on the correct month. Hold the Date button and release once on the correct date.
  • Slide the mode switch to TIME. Hold the Hour button and release once on the correct hour and AM/PM. Hold the Minute button and release once on the correct minute.
Good luck.
Posted on Oct 11, 2010
  • Walesarumi
    Walesarumi Oct 11, 2010
    Finally, I was able to get and instruction/manual for your sioscan automic clock; model 86722.
    Find the manual on the below link:
    http://www.atomicclocksstore.com/skyscan...
    I hope this helps.
    Good luck again.
Need manual for Travel Companion Model S1500 Alarm Clock
Travel alarm clocks can have varying instructions, depending on the type of clock you are using. Here are some tips for use that will apply to any alarm clock.
  1. Power source
    • Travel alarm clocks will need to have some sort of power source. Depending on the type of alarm clock, it might be battery-powered or it might have a cord that needs to be plugged in. Battery-powered alarm clocks can take mini watch batteries, AAA batteries or sometimes AA batteries. Travel alarm clocks, because of their tiny size, usually have the small batteries that need to be bought from a watch store or a dollar store. Before you leave, make sure you have a working power source and can turn it on.
    Changing the time
    • After you reach your final destination, power the alarm clock on. Now you'll need to set the time and date correctly. Check a watch, cell phone or television to get the exact time and locate the buttons or dials on your alarm clock. On some, there will be a "time" or an "hour" button you need to press and hold to activate the alarm time change. While you are holding it down, turn the dial, press the hour button or press the (+) button until you notice a time change. On others, simply pressing the hour or minute button will let you change the time shown.
    Setting AM/PM
    • The AM/PM option is critical in setting your alarm clock correctly. Make sure the LCD display on your clock has a light beside the correct AM or PM setting, or look for the letters AM or PM on the display. If you get this wrong, the alarm won't go off in the morning!
    Setting alarm time
    • To set the alarm time, look for a button or a switch that says alarm. If there is a switch, move it to the alarm setting. If it is a button, you'll need to hold it down until the time starts flashing, signaling time to change the hours and minutes to the desired alarm time, or hold it down while you press the hours and minutes buttons to reach the alarm time you want.
    Turn alarm on
    • Now double-check that your regular and alarm times are correct by switching the switch back and forth again, or by pressing the alarm/time buttons long enough to read the time set. There should be a picture of a bell somewhere on your LCD display showing that the alarm is set to "on." If there isn't, look for the on/off alarm button and move it to the correct position.
    Music options
    • The last step is finding the alarm wake-up option. Not all travel alarm clocks have this option, but if yours does there will be a switch or button that lets you choose to wake up by a buzzer, the radio, a CD, or another device.
Read more: Travel Alarm Clock Instructions ' eHow.com http://www.ehow.com/way_5250617_travel-alarm-clock-instructions.html#ixzz1YfneKhGw
Sep 22, 2011 | Vacuums
I am trying to find an instruction manual for a Mechtronics Corp. Planter's Clock - model #4.
I actually have one of these. Pull the back cover.it might be in there.otherwise i can email you pictures of mine
Apr 17, 2011 | Vacuums
HELLO MY CLOCK DID NOT DO AUTO DAYLIGHT TIME HOW DO I FIX THE TIME TO ADJUST TO ONE HOUR A HEAD THANK YOU INGER WELCH
All you need to do to advance your clock an hour for daylight savings time, is hold down your clock button without letting it go. Then press your hour button once and you should be all set.
Most clocks that are older than when they changed the date of daylight savings time will either not change it for you on the right day anymore. Or they don't have that feature in it.
If yours does have an automatic daylight savings feature...you may find it helpful to take it off "automatic" and just change it manually from now on. That's what I do with my VCR. It has an automatic daylight savings time feature, but it's useless now that they have changed the date when we set our clocks for DST.
Some manufacturers will give you instructions on how to change the feature settings so your product will again work correctly for you. But not all will or can. You can look it up at your manufacturers website to know for sure.
Good Luck...and I hope this helps you.
Mar 13, 2011 | Vacuums
I have an older model rca cd clock radio dual alarms. I cannot find my instructions for setting the clocks time. The batteries were dead when the electricity went off. Now the time keeps flashing the time.
For most clocks of the RCA clocks without a clock or time set button, press Set until you see the clock icon. Press the fwd or rev button to change the time. Release the button when you reach the correct time. (AM or PM will be indicated next to the time.)
There are manuals for several RCA cd clock radios available from their site: http://support.rcaaudiovideo.com/select.aspx?u=manual . Check if your specific model is listed in the menus.
I hope this helps.
Feb 03, 2011 | Vacuums
I have a Silicon Scientific Atomic Projection Clock I don't have a manuel for the clock was wondering if you could walk me through how to set
I have the instructions that came with the Silicon Scientific Atomic Projection Clock and was going to attach them as a PDF but it doesn't look like it's allowed here. If anyone know how to do that let me know.
Sep 06, 2010 | Vacuums
I bought a Caixing CX-2158 led digital clock in Thailand and there aren't any instructions to operate it eg; set time alarm etc. Can you help please? (i am in Australia.) Thank you in anticipation.
I bought a Caixing CX-2158 led digital clock in Thailand and there aren't any instructions to operate it eg; set time alarm etc. Can you help please? Philippines Thank you in anticipation.
Jul 12, 2010 | Vacuums
Vacuums Logo
350 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
