Question about Digimate DGL32 32 in. LCD Television
Sky remote code!!!!
Hi can you tell me if the 32" ltv 3204h has a code for my sky+ remote control if not is there another models number that may work and how can i stop it changing screen size when i change to some channels. thx
  • 1 more comment
  • tdardis Sep 22, 2008
    Cannot find remote code for my sky+ remote control unit
    td
  • Anonymous Mar 01, 2009
    same
  • vinnykav06 Mar 03, 2009
    i have recently bought a digibox 4 usb super and no matter what button i press on the digibox remote it changes the tv channel or switch my tv off or brings up text etc,is there some way i can change the frequency on my digimate ltv-3204h remote to stop it interacting with my box receiver as i tried this box on another brand tv and it worked no problem so it only the digimate tv
Go on system setup go on pic setting turn scart control off and all the pic sizes will be the same!!!!!!!!!! still cant find my remote code waht a bummer
Posted on Sep 07, 2008
Did you ever get a code for this?
Posted on Aug 13, 2008
I need remote code for digimate for my sky remote
Posted on Feb 13, 2009
Need code for polaroid tv for sky
I've posted a clarification request above. You need both the TV model number and the version number of the Sky remote to find the correct code. I install satellite systems - I have access to the entire code database for all versions of Sky remote.
Oct 19, 2011 | Televison & Video
Cant get sky code so sky remote wont turn sound down
Hello Heidi, you will need the brand and model number for your TV when you click in to sky.com. after you do you might have to sign in or register if you haven't done so. Then click on watching sky, then remote control help, this will take you to the find your code, this is where you'll need the model and make for your TV.
Jul 28, 2010 | LG 32LD450 32 In. LCD HDTV
REMOTE CONTROL CODES FOR ASTAR TV
Have you tried a Code Search with your remotes. If that does not work try calling or emailing Astar they may be able to help.
Astar Electronics
Tech Support:: (626) 851-2528
info@astarelectronics.com
www.astarelectronics.com
Feb 09, 2009 | Astar LTV-3201 32 in. LCD Television
Sky remote tune to samsung
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Aug 13, 2008 | Samsung WS32Z308P 32" TV
Sky TV Remote Control Code For Vistron 40" TV Required
TV maker is Palladium codes are 0560, 398, 391, 446
Jun 27, 2008 | Televison & Video
Mirai TV remote control set up code
does anyone know the codes for a mirai tv for a universal remote
May 07, 2008 | Jensen TS2750J TV
Sky remote code for LG 42LC46 tv
Hi - I also have the LG42LC46, i got it to work by using code 206 but you need a REV 8 remote, i tried it with a REV 4 and it doesn't work.
Regs
Dee
P.s. let me know if it worked for you.
Mar 20, 2008 | Televison & Video
Sky code for remote
The code for you sky remote is 0125.
4 digit' method
1. Turn on your TV.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the Brand Set code for your brand of TV then press select. The light on the Sky remote control blinks twice.
If the light blinks once only, re check the code for your TV and start again at step 1.
6. Press the on/off button (power-top right button on your Sky remote control).
If your TV switched off, press select . The light on the Sky remote control blinks twice.
If your TV did not switch off, press tv , then press the on/off button. Repeat this (press tv , then on/off) until your TV turns off, then press select.
If the light on your Sky remote control blinks three times, your Sky digibox has checked all the possible settings for the code you used. Check that you have the right 4 digit code and start again at step 1.
7. Press tv guide .
If you see the TV Guide screen, the remote control setup process is complete.
If you did not see the TV Guide,you must now set the TV Guide function as follows:
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
10. Key in the number of the channel on your TV that you use for watching satellite TV (For scart switching, this may be one of the other buttons on your remote e.g. help, i or a colour button).
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
Feb 13, 2008 | Televison & Video
Remote control code
Hi.
Try this,
It involves finding your make & model number from Sky.
Press INTERACTIVE BUTTON., then SKY CUSTOMER SERVICES,
then TECHNICAL ASSISTANCE, FOR ALL SKY REMOTES.
Now follow the on screen instructions.
http://dysonmanuals.inc.io/
Chris.
Jan 07, 2008 | Televison & Video
Sky remote code
codes for bush are
107
031
codes for bush uk are
005
038
140
018
052
143
020
058
152
022
085
169
031
107
172
036
121
175
015
043
141
019
053
144
021
078
156
026
099
171
033
109
173
226
196
hope this helps
Dec 08, 2007 | Directed 434MHZ Remote Control
Digimate DGL32 32 in. LCD Television Logo
270 people viewed this question
Top Digimate Televison & Video Experts
Jaime Hernandez
Computer Repairing
Computer Repairing
ray gallant
Are you a Digimate Televison and Video Expert? Answer questions, earn points and help others
