Question about Toys
How to fit - Toys
  • 17,129 Answers
Please mention the question in detail so that we are able to help you.Mention always the product and fault.
Posted on Oct 11, 2010
How do I remove a quick connect
Quick connect fittings will have a small sleeve that fits around the pipe but slides into the fitting. When you apply equal pressure to the fitting it will slide up into the fitting and release the locking tabs. While maintaining steady pressure, gently twist and pull at the same time and the pipe (waterline) should release and come out of the fitting. Most hardware stores that sell quick connect fittings will also sell a "C" shaped release tool that will make the removal easier.
Jul 13, 2014 | Home
Tip
Brass Tube Fitting
The essential step of tube fitting production include heating, melting, mixing and conveying the raw material into a particular shape. It is important that this shape is maintained during the cooling process. All Brass tube fittings are made in accordance with ASTM standards. All diameters of solid wall Brass tube fittings are continuously extruded through an annular die. Thermoplastic fittings are either injection or compression molded. They are fabricated using section of pipes or machined from molded plates.
Om Tubes Brass Tube Fitting connects different types of tubes to one another. It can be used for in-line, offset, multi-port, and mounting configurations. Various tubing sections like pipe, hose, or other components are connected through tube fitting. Usually the system is configured with straight sections connected by fittings or some specially formed connections and joints. Om Tubes being Brass Tube Fittings Distributors provides you with best quality & services. Products at Om Tubes are of various wall types and all are produced in accordance with the requirements of a variety of industry standards and specifications like ASTM and AWWA. We sell Good Quality Brass Tube Fitting at Om Tubes.
http://omtubes.com/brass/brass-tube-fittings
on May 08, 2017 | Miscellaneous
Will a 22R exhaust manifold fit on a 20R?
it be TOYOTA what>? and what year.?
1981 to 1997, if not a clue.
you do know that the EGR fits on some on not on others right>?
and varies by country ?
spec out your car, and year, and country
even cars in calif here are different. so pretend calif is a country if yours is. (c.a.r.b rules)
fits all-ways? factory fit, fits all other parts. and legal ?
see car-parts.com
or dealer pages for parts. does the p/n match?
if yes, its the same ,or is not a fit.
fit means to me fits right and passes spog tests USA.
and means legal.
May 03, 2014 | Cars & Trucks
Honda fit
no year stated
fit has no meaning, unless defined.
i can weld anything to , well, anything, brackets made and all.
fit and look OEM./ fit and be legal.
fit and be safe
fit and not interfere with air bags.
pick one. it's no honda
http://en.wikipedia.org/wiki/Suzuki_Aerio
Apr 24, 2013 | Suzuki Aerio Cars & Trucks
Fitting a car seat
To be able to provide assistance we'd need to know which make and model carseat you're looking at fitting.
If it is fitted with IsoFix, has it been confirmed as appropriate for use in your vehicle?
If it is fitted with the seatbelt has a physical fitting by trained staff been carried out to confirm a safe fit can be provided?
It would be recommended that you contact your retailer and ask for a demonstration of fitting the seat to ensure you can fit it safely and securely.
Nov 13, 2012 | Baby Gear
How to do a quadratic regression?
I am sorry to say that natively the HP 49G+ does not perform quadratic regressions. The models that are vailable are Linear fit, logarithmic fit, exponential fit, power fit, and best fit.
These options are available under Right SHIFT (Orange) 5 (STAT)>3:Fit data.
Feb 25, 2012 | HP 49g+ Calculator
Need to charge airconditioning system, and the recharging kit doesn't fit on.... how and what do you use to recharge on 5.7 L engine, 1997 1500 4x4 chev pick up
the recharge kit will only fit on the low side fitting which is the smaller fitting on the larger lines/hoses. If it doesn't fit on the fitting you have tried than you are probably trying to put it on the high side fitting which is the larger fitting on the smaller lines/hoses. I think the low side fitting is on the receiver drier on this model which is the canister looking thing back by the passenger side of the firewall.
Jun 29, 2011 | Chevrolet 1500 Cars & Trucks
1994 softail springer with harley carburator. fuel fitting on carb that was there had a plastic clip and small line going to hose. This hose broke and I was given a different fitting. This fitting presses...
The original fuel line fitting on the Keihen carb is a pressed in fitting made of brass and plastic. The plastic piece breaks off leaving the brass nipple in the carb. Harley makes a replacement fitting as well as the aftermarket parts suppliers. The Harley replacement is better because it's made completely of brass where the aftermarket replacements are made of brass and plastic like the original. To get the old fitting out, thread it with 1/4 X 20 tap and use a bolt, washer, and a deep well socket as a "puller" to get the old fitting out. To press the new fitting in, lubricate the fitting and the hole in the carb and use a vise to press the fitting in. Be sure to position the fitting correctly so that the fuel hose goes on in the right direction. I'm sorry but I don't have the part number handy. Your local dealer can look up the number easily.
Good Luck
Steve
Jun 07, 2011 | Harley Davidson FXSTS Springer Softail...
Whats the diffrence with the wii fit plus and the wii fit
They are just two different versions of the Fit game. The actual Wii Fit device is the same. If you already have a Wii Fit, you can buy Wii Fit Plus as a stand-alone game without the device. The Plus has some newer exercises.
Feb 18, 2010 | Nintendo Wii Fit for Wii
Toys Logo
42 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
