Question about JVC KW-AVX810 Car DVD Player
Hello, My JVC 826 does not respond at all!!. When I click th erest button, display comes as usual - with all scrolling of songs etc - however - I cannot listen to any music!! - Touch screen doesnt wotj at all. With remote I can select next track - but no sound. The onboard hard buttons deosnt work, the touch sensor wirks however. It doesnt turn on when click the power button, but will come up when I click the reset button - can you help pls
4 Suggested Answers
SOURCE: KW-AVX710 Screen stays black (off) untill I hit the open button
So I decided to verify all the connections after I got frustrated with it. Everything was correct except one wire that was on the new harness I got that for my car that was labeled "12V fused" (supposedly the key on power source). I tested it with my volt meter and it did not have power at any time, even with the key on. The constant power source wire was hooked up so that's why I was able to open the face and eject CD's and DVD's but not do anything else (like when your ignition is off). So I ran a new wire from my fuse panel and everything works now. Just like my Thermodynamcis professor says "nullius in verba" (take no one's word for it), just because the wire was labeled doesn't mean it's right! Hope this helps.....
Posted on May 26, 2009
  • 5370 Answers
SOURCE: i have a jvc JVC KD-AVX40 dvd car sterio and the
If there is no display,but other functions working properly.Then the problem is related to display connecting wires.In the unit there is a main circuit board.The display board gets power from main board.But if the connecting wires between main board and display board is loose or short then screen will be white.The unit needs to be disassembled and internal wiring connections are to be checked.If there is loose soldering inside then just re-solder the loose wires and recheck.If there is any component got short or burnt out then that particular component is to be replaced. -------- This should help.Thanks.Helpmech.
Posted on Dec 21, 2010
  • 7 Answers
SOURCE: I have a JVC KW-AVX840
You can try disconnecting the battery for like 15 seconds and it should restart your stereo and might work again good luck!
Posted on Sep 13, 2011
Hello, My jvc kd-r716 car stereo has faulted. I can not turn on. I have checked power source and all is okay. If I push eject or display the unit responds to those 2 functions brieflly then turns off. The...
You can reset the radio, there is usually a small reset button that you need a small pin to push or you could disconnect the battery for five mins and reconnect. See if that helps.
Dec 01, 2012 | Car Audio & Video
Dryer of stacked W/D unit (Frigidaire FLEB8200DSO) is producing way too much heat. My research suggests the problem is the control thermostat, but I can't find definitive info on where the part is or...
On the stacking laundry center the cycling thermostat is going to be in the bottom of the dryer blower housing. Remove the diagonal panel between the washer and control panel and remove plate behind that outer panel to access the cycle t-stat. BUT FIRST check that the venting is clear and not restricted from the dryer all the way to where it goes outside.when a dryer feels extra hot its usually because the heat isnt being vented and it builds up in the dryer,also make sure the blower wheel is not broke and turning,usually if its bad a clucking noise is made at start of dryer and when it stops but quite th erest of the time.
I hope this helps you to fix your dryer,
Gene
Aug 09, 2011 | Frigidaire Washing Machines
How can i download a song to my usb?
Go to www.4shared.com and type your favorite artist or song then click the search green button. Click the song you want to download and the there will be a new tab or new page will display. Then scroll down a little to see the download now button click that button and wait for the counter to finish counting. After the counter the download link will appear click to that and it will start downloading the song. After downloading just copy the song that you have downloaded and paste it on to your usb hard drive. Have a nice day.
Mar 22, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
KW-AVX-826 NOT GIVING ANY VIDEO BUT NO PROBLEM WITH AUDIO WHILE PLAYING DVD DISC
press the display button, until the desired screen comes on, and make sure handbrake wire is earthed.
Apr 20, 2010 | JVC KW-AVX810 Car DVD Player
My JVC TH-G30 gives me a locked message when I try to open the load tray what should I do?
hello Setting the disc ejection lock
You can lock the disc tray to prevent the disc form
being ejected.
When the main unit is turned off, hold down the STOP
key at the front panel for 5 seconds
If you attempt to open the disc tray by pressing
OPEN/CLOSE key, the disc tray does not open and
“LOCKED” appears in the display window.
To cancel the disc ejection lock, hold down the STOP
key at the front panel for 5 seconds again when the
main unit is turned off.
“UNLOCKED” is displayed in the display window.
Note:
Before the main unit is turned off, DVD/CD function
should be selected.
Mar 29, 2010 | JVC TH-G30 Theater System
Hello I recently bought the phillipsgogear vibe and I don't know how to down load songs to the MP3 player
here are two methods for loading that model i know they're long but they will work either one will do whatever you prefer :)
**Drag and Drop**
Connect your MP3 player to the computer. Some MP3 players connect directly to a USB port, while others connect to a USB port by way of a specific USB connector that comes with the MP3 player. Open the folder on the computer that contains the music files you want to transfer. This is usually the "My Music" folder, available from the "Start" menu, but it can be any folder where you save your music files. Scroll down to the song you want to transfer to the MP3 player. Right-click on the title. When the options are displayed, click on "Send To." Scroll down the "Send To" options and select your MP3 player. This can be listed as your MP3 player's name or as "Removable Drive." Click on this selection. Continue this process until you have transferred all songs that you want to your MP3 player.
--**Windows Media Player**--
If you have a large playlist to transfer, you may prefer to do it from your media player, such as Windows Media Player. Once your MP3 player is connected to the computer, open Windows Media Player. Click on the "Sync Music" tab. Drag songs that you want from your Windows Media Library over to the "Sync Music" column to create a playlist. Click the "Begin Sync" tab at the bottom once you have all of the songs on your playlist. This action will sync all of the songs to your MP3 player with one click. Disconnect your device once songs have been transferred by clicking on the "Safely Remove Hardware" icon in the bottom-right side of the desktop tray.
Oct 29, 2009 | Philips GOGEAR SA6045 MP3 Player
JVC KD-G322 Demo mode
Hold down the "SEL" button, and use the CD track skip button to scroll to where the display says "DEMO," and use the volume knob to change the setting to "OFF." Push SEL again and you're good to go.
Apr 03, 2008 | Kenwood KVT-617DVD Car DVD Player
Cannot TV to play throught JVC TH-C50
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=9f8aca666be88c19dfe7c8b7d3504340&q=JVC+TH-C50
Dec 24, 2007 | JVC TH-C50 System
JVC KW-AVX810 Car DVD Player Logo
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
