Question about Metra 705512 Ford Prm Snd Amp Plug Wiring Harness
Got this amp from a friend and want to wire it up to my Sony head unit. The HU does have pre-out in RCA plugs. please help. I have tried it with: RED - stereo Amp Rem In YELLOW - 12V BLACK - -12V RCA - from stereo RCA OUT WHITE/WHITE-STRIPE - to Subwoofer . I tested the subwoofer and it works fine.
  • Senshin Oct 11, 2010
    Sorry, it seems like I have a wiring harness problem, this is wrong. It is an amp wiring problem. I am not sure how it ended up with with a plug wiring problem.
    the amp is a Ford 1r23-18t805-aa amp, if that makes sense.
  • 30 Answers
Senshin,
Red- 12 volts switched (ignition)
Yellow- 12 volts constant
Black- Ground
Blue/white stripe- remote amp turn on/ power antenna
If you have any orange wires there for the Illumination dimmer. (head unit dims when you turn the lights on). The white and gray are front speakers and purple and green are for the rear, solid being + and black striped being -. (gray and purple are right channels)Make sure that the RCA plugs go to the input side of the amp. I hope this helps, Ray
Posted on Mar 06, 2015
Amp stopped playing riding down the road, power light turned off. came back on when i unplugged the rca's and cuts back off when i try to plug them back in.
Faulty RCA cables, Or worse possible solution is if your amp stopped playing when it was pumping at high volume, you may have blown the RCA connectors inside your head unit Or inside your amp. If possible try another known good working amp with the wires you already have, If same happens, try different RCA cables. If problem persists after trying these, Its your head unit RCA connecters or amp RCA connectors. To rule out your amp connectors, try your amp in a friends car if possible, to rule out your head unit, try another good known working amp in your car with the wiring you already have
Mar 03, 2011 | Kicker ZX300.1 Car Audio Amplifier
Another conundrum
To check for yourself, get an Ohmmeter and see if the outers of the amplifiers RCAs are connected to the ground or each other. If so then it cannot take speaker signals directly.
I suspect the 'High Level' the manual speaks of are the 4volt auxilliary audio signals that can be found on some newer head units, not speaker signals.
Speaker level signals from a bridge amp CAN be used on grounded RCA inputs if the signal is first passed through a simple decoupler and attenuator.
Diagram to explain....
Nov 22, 2007 | Infinity 475A Car Audio Amplifier
I have the pionner deh p7300 i want to hook up a ipod i have a sub woofer and amp. on the back of the headunit i have rca plugs for the amp in the rca plug on back of unit. the there are 2 other sets of...
Buy a rca to aux 3mm plug then you can connect to aux port.
RCA out is for the signal to the amp from the Head Unit. Mic is probably for your cell phone.
Am pretty surprise that an HU like that doesn't have USB Ipod support?
Feb 06, 2011 | Pioneer DEH-P7300 CD Player
I have two 12 inch rockford p1 punches powered by an 800 watt sony explode amp (2 Channel) and i want to install another 15 inch kicker with a 1200 watt amp not sure the model, i got it from a friend and...
I have a similar setup & I just run the second amp straight off the other amp by running positive & remote wires directly from 1 amps positive & remote inputs to the others amps inputs. But my head unit has RCA inputs, (sub in & front & rear inputs) so from my 4 channel amp I run 2 6 inch alpine S's to the front to the front RCA inputs of the head unit, & 2 Pioneer 440w 6x9 inch speakers to the rear inputs. & my 800w 12 inch sub from my 2 channel amp to the sub woofer inputs on the head unit. Has blown my eardrums for nearly 12 months now great stuff! Hope this has helped
Mar 12, 2010 | Sony Car Audio & Video
Rca preout not putting out anything after amp/subs are hooked up and ready to pound
On most Pioneer's, there is an option in the main menu that allows you to turn the sub-out on or off. This must be on to let a signal pass from the head unit to the amp. Check this, and if it is on, try replacing the RCA cables. Let me know if this helps :)
May 25, 2009 | Pioneer VSX-D557
P-301 onkyo pre-amp
Hi juicer, If you use the switched outlet, then everything will be turned on/off when you operate the preamp power switch. Use the unswitched, then you have to turn off each unit separately. You choose which one you want. It wont matter.
What connection do you intend to use to connect the LBT zx6 to the Onkyo preamp??
Mar 20, 2008 | Audio Players & Recorders
Protection Light Is Coming On
You say the protection mode only occurs when you plug the RCA's in. Does it have to be both RCAs or just one?
The other end of the RCA cable is plugged into the HU?
It possible the RCAs have too much DC voltage on them, causing the amp to go into protection.
Is there a short in the RCA cable?
I would definitely check out the RCA connection at the back of the HU, as it sounds like there could be other issues there. Make sure the RCA connectors aren't touching any other metal (especially +12V).
Mar 14, 2008 | Car Audio & Video
Alpine
If this occurs with the head unit plugged directly into the amp (no signal processors inline, you probably have open shields on the head unit.
To check the shield ground, disconnect all RCA cables from the head unit and measure the resistance between the RCA shield on the head unit and the case of the head unit. It should read ~0 ohms.
Dec 03, 2007 | Car Audio & Video
Stop putting out sound to subs
Ok This is a two channel High Current amp. It is stable to one ohm. If the Subs are single voice coil at two ohms the they have to be wired in Parallel that means (Red +) (Black -) are connected to the + and - of another sub and then the (RED +) (Black -) from both go to one output channel of the amp. You pair the other two in the same fashion on the other output channel. If you are getting no output (sound) at all first check if the amplifier is going into protect. (Usually indicated by a red led on the unit. If it is connect only one Sub to each output and see if the protect LED goes out. If it does then you should have sound at the subs. If not check that you have the sub output enabled on the HU some head units do not come with the sub output enabled on the HU. If every thig is enabled, with only one sub connected to each output and the protect LED is not on then your amp is probably blown and needs repair. Nice thing is that MA has a great warrenty policy. Check and make sure the protect LED is off. If it is on you probably have the SUBS wired wrong
Jun 23, 2007 | MA Audio HK802SX Car Audio Amplifier
My brand new system isnt working right...
All righty then, This is most often gaused by bad grounds. Make certain the ground of the amp is a solid clean connection. The best place is under one of the rear seatbelt bolts, next check the condition of the ground at the battery this has to be clean with a good connection to the chasis, third make sure the Head Unit also ahs a clean positive ground. If these do not yeild results then get hold of any littel portable radio, cassette player, mp3 player as long as it has a earphone jack. Get one of those cables that have a earphone plug on one end and RCA plugs on the other. Disconnect the RCA's from the HU and hook up the player. Power up the system and play back from your portable player, mess with the gain on the amp and see if you still have the same problem when playing back from the portable device. If the problem goes away then you probably have blown grounds on the RCA's on the head unit and only a repair shop can fix that or a new HU. If you still have the problem with the portable player then adjust your lowpass filters and cut off to a higher frequency until the problem goes away. The gain on these amps should never be used to make up for low output from the Head Unit. (another cause for this condition) Get a HU that has 4 to 6 volt sub outputs and crank the gain down on the amp. That gain control is to control distortion (over driving the amp) not to make it louder. If you want louder then go for the HU with the higher sub output voltage or go with a SUB with a lower ohm rating. Your amp is stable down to 1 ohm. Oh and double check if you have your subs wired correctly improper wiring at the subs can m ake this problem worse.
Apr 28, 2007 | MA Audio HK401SX Car Audio Amplifier
Metra 705512 Ford Prm Snd Amp Plug Wiring Harness Logo
146 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
