Question about Apple iPod nano
What is the top switch used for - Apple iPod nano
  • 146 Answers
It is used to lock the navigation button. Thank You.
Posted on Oct 11, 2010
I want to replace a current dual outlet with a combo switch outlet where the switch controls the outlet.
Based on what you said, your hot wire feeds the top left and the neutral connects to the bottom left. The two brass on the right should be connected to each other with a brass tab. If you look at it, you should be able to see it.
This is the way it works: hot feeds top left, when switch is turned on, hot goes through to the top right which also feeds bottom right. Now the outlet is powered.
If you are not sure, use a multi meter set on continuity and check from the top left to the bottom left while turning on the switch. Good luck!
Jan 28, 2017 | Electrical Supplies
07 corvette top will retract but deck lid makes no effort to close, then top will not go back up. Need to release pressure in block lift top up about 1/4 of way then top will go back up
Manually Moving the Folding Top from the Down Position
Important: Allow the system a minimum of four minutes to bleed down pressure after the last cycle.
Manually release the folding top cover latch using the emergency release cable.
Raise the folding top stowage cover.
Manually raise the folding top, holding the 5 bow up.
Manually lower and latch the folding top stowage cover.
Manually unfold the top and latch per normal procedure.
Manually Moving the Folding Top from the Up Position
Manually release header latch per normal operation.
Manually lift front of roof off of the header and raise the #5 bow at the same time.
Manually release the Folding Top Cover latch using the emergency release cable.
Fold the roof down into the well.
Manually close and latch the folding top stowage cover.
Power Folding Top System Components
The power folding top system consists of the following components:
• Folding top control (FTC) module
• Body control module (BCM)
• Folding top control switch
• Serial data communication
• Folding top cover latch actuator
• Folding top cover pull down actuator
• Folding top pump motor with valve manifold
• Position switches and limit switches:
- Pin receiver switch
- Luggage barrier switch
- Folding top cover open switch
- Top open switch
- Top closed switch
- 5 bow raised switch
- 5 bow lowered switch
• Tonneau release relay
• TONNEAU PULL DOWN ACTUATOR Fuse 20 A
• TONNEAU RELEASE Fuse 10 A
• BATT 2 Fuse 40 A
• REAR FOG/ALDL TOP SW Fuse 10 A
• Folding top mechanical components:
- Folding top
- Folding top cover
- Folding top valve 1
- Folding top valve 2
- Folding top valve 3
- Hydraulic lines and cylinders
Folding Top Cover Latch Actuator
The power folding top system includes a folding top cover that is powered open and close by a hydraulic system that is controlled by the FTC module. A power unlatch motor is used to unlatch the folding top cover before the folding top control (FTC) module powers the top cover open. The folding top cover unlatching is requested by the FTC module via class 2 message, but is executed by the body control module (BCM). When requested, the BCM applies battery voltage through the folding top cover release relay control circuit to the tonneau release relay. The relay is energized and battery voltage is applied through the folding top cover release control circuit to the latch actuator. The actuator is energized and the latch releases the folding top cover.
The electronics on this are very complex ,
System Operation
Before any movement of the power folding top is allowed, the folding top control (FTC) module must be aware of the following conditions:
• Unlatch the header. The FTC module reads the pin receiver switch is Inactive.
• The windows must be normalized. Refer to Power Window Reinitialization.
• The ignition must be placed in Accessory or RUN.
• The transmission must be placed in PARK, or with manual transmission, the park brake must be applied.
• Trunk status must not be ajar.
• The luggage barrier must be in place.
• The pump motor temperature must be within the operating range.
After the last cycle of power folding top operation, allow the hydraulic system a minimum of 4 minutes to bleed down before attempting manual operation of the top.
Your best bet take and have it checked for DTC'S - diagnostic trouble codes .
DTC B3666 Rear Tonneau Position Error
DTC B3667 Tonneau Release Circuit
DTC B1011
DTC B1291
DTC B1420
DTC B3602
DTC B3666
DTC B3667
DTC B3670
DTC B3971
Jan 23, 2017 | 2007 Chevrolet Corvette Convertible
I want to replace two regular switches with two utilitech 7 day digital in wall timers.
Go to lowes or home depot and get a book on simple wiring. they have the same ones at the library.
Nov 08, 2013 | Intermatic Inc. ST01C Digital In-Wall...
How do i turn on an insinkerator
There are two different types, those that have the switch built into the top, and those that have a separate switch mounted on the wall or maybe inside the cabinet under the sink. It is possible that you have the type with the built-in switch that was installed with the separate switch too - in that case you would have to turn on the swithch AND turn the top.
Sep 04, 2012 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
How do you replace the brake light switch on a 2005 Ford Expedition XLT?
follow the brake pedal to the top where it mounts,, you will see the switch located at the top of that bracket,, you may have 2 switches there, or they used a combo switch that would include the starting safety switch , they used 2 methods on your vehicle
Sep 06, 2011 | 2005 Ford Expedition
Washer woant spin after washing heavy down comforter
You most likely have one of two possible issues going on with this machine. Either the lid switch assembly has been damaged by the comforter floating up or the comforter may have gotten torn allowing some of the material to get stuck in the pump. Since you mention no tears, let's check your switch.
As far as the lid switch, there are two different ones that were used in this washer. One was a mechanicel stlye switch that was activated by a plunger attatched to the edge of the lid. You can identify this pretty easily by looking at the lid for a "tab" that hangs down and would go through a small opening in the top of the washer when the lid is closed. The actual switch is below the top of the washer and would have an arm that protruded just below the hole. Pressing this arm should produce a faint yet audible click sound. You may notice the arm is bent out of alighnment causing your no spin problem..
The second type of lid switch used was a magnetic style switch. This is identifiable by a rectangular block attatched to the bottom of the lid, and a corresponding rectangular plastic strip on the top of the washer. The idea being that when the magnet (bottom of lid) is on top of the switch the contacts are closed.
-Unplug the washer-
To access the inside of the machine you will need to use a putty knife to release the front panel. There are two clips one on the left and one on the right between the top of the washer and the front panel. using the putty knife lift the clips on either side while pulling the front forward.
With the front panel removed you will see two tabs that hang from the extreme right and left of the washer top. There will be one 1/4" screw in each of the two tabs holding the top down. Before pulling the top up you wil lneed to remove the magnetic style switch as the wires that go to it are pretty short. You may even see that one of the wires has been pulled out at this point (causing your no spin) if so cut both wires and strip back the insulation and wire nut them together to allow you to use the machine until you get a new switch. To remove the switch you have to press a tab located at the rear of the switch in and push it up through its hole in the top. (WH12X10334 magnetic style switch part number)
I would not reccomend leaving any lid switch bypassed as this could result in a safety issue if children were to open the lid during a spin cycle and reach in the tub.
Good luck with this and feel free to reply with any other questions!
Jun 26, 2010 | General Electric WCSR4170D Top Load Washer
I have power running to a 2 switch gangbox. Each
As long as the power is running from the breaker panel to the switches rather than the fixtures then it should be pretty simple.
1. Run a new 2 conductor wire from the existing box to the new box at the top of the stair.
2. Install a switch at the top of the stairs.
3. Disconnect the hot wire that is running to the two existing switches and connect it to one of the two conductors running to the top of the stairs.
4. Connect the remaining conductor on the wire going to the top of the stairs to the two existing switches.
Note that if you want to be able to use the Dimmer function from the top of the stairs this will be much more complicated. You will need to put two new switches at the top of the stairs, run more wire, the new switches will need to be 3 way dimmers and the existing switches will almost certainly need to be replaced as well. The wiring will also be much more complicated.
Jan 09, 2010 | Lutron Claro Screwless 2 Gang Wall Plate...
I have a 12/2 w ground source. I want to use a Leviton 5224 combination switch to control a double plug. The top swithch for the top plug and the bottom switch for the bottom plug. I will use 12/3 with...
from power source black/hot wire to switch, white and bare/ground wires wire nut white to white bare to bare. run then to outlet white wire to silver screw bare to green screw. black wires to outlet from top switch to top of outlet bottom switch to bottom outlet break off fin on hot side of outlet should be brass screws dont' forget to turn off power before you start.
Nov 04, 2009 | Electrical Supplies
How does the top come off ge washer model wjxr2080t6ww
Use a putty knife to push the spring clips in where the top of the front panel meets the washer top, about 2 or 3 inches in from each side. Front panel pulls forward and lifts off pegs, revealing two 1/4 inch drive hex screws holding top to side panels. If your washer has the lid switch near the front, push the tab on the back side toward the center of the switch and push switch up, then twist 90 degrees and pass switch back through the opening. Now lift washer top at the front side. Most washer tops will unhook from the back side now, but some need to be slid an inch to the side yet to remove once the top is lifted a few inches. If you model still has the lid switch near the back of the washer opening, lift the top at the front and unhook the back of the washer top, pull the top forward a few inches and unplug the lid switch disconnect block. (two wires)
Oct 12, 2008 | GE WVSR1060A Top Load Washer
The convertible top stop working
I HAVE 1994 FORD MUSTANG TOP COVERTABLE TOP NOT WORKING FUSS ARE GOOD I CHANGE THE RELAY IN THE TRUNK.I REPLACED THE CONVERTABLE MOTER IN THE TRUNK WHAT ELSE ARE THEY TO DO
Jul 29, 2008 | 1994 Ford Mustang
Apple iPod nano Logo
23 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
