Question about Microwave Ovens
I was given a Breville Waffle Supreme Maker but it didn't come with any instructions for what recipes to make in it - I would dearly appreciate some waffle recipes - thank you so much Kerrie
GodBlessU
  • 3513 Answers
SOURCE: How do I remove the
Here is how you need to replace or bring out the plates.
Make sure you are unplugged from the wall before doing anything or you will get shocked. You do not need to take the bottom cover off the base. You do not need to take the top plate apart (they super glued one screw in the top plate (lid), you'll strip out the screw head trying to remove it anyhow). All you need to open is the bottom plate, it has 4 screws in it you will see when you open the lid, these screws are not super glued and will come out. 2 on each side in the back, 2 in the center of the front, long screws go in the back, short in the front.
There are 2 white wires, 1 black wire, 1 green wire that run up the neck of the waffle maker to heat the top and bottom heating elements. The 2 white wires are neutral, the green wire is a ground, the black wire is power.
This black wire runs from the electronic control board in the base of the unit, up the neck in the rear, through a thermal fuse, to the bottom element then jumps up to the top element. All you need to take apart is the bottom plate, the part you pour the batter into. It has 4 screws you will see when you open the top plate up, take those out and you are going to find the black wire is covered by a white rubber like tube about 3 inches long. In the center of this rubber insulation there is a metal clip with a single screw. Take that screw out, pull off the metal clip and slide (don't cut) the rubber like insulation back.
You will find the black wire is crimped onto a silver metal bullet looking component. This component is called a "thermal fuse", its designed to fail at 240 degrees C. Its obviously a design flaw and the thermal fuse is under rated for the actual heat within the device. Its also a one shot fuse, so when it blows it kills power on the black wire from going to the top and bottom plates, thus no heat. It is not resettable.
I didn't even cut mine out (Waring is very skimpy with their wire, they don't leave you even a hint of extra wire to work with). I just tightly twisted the bare metal wire on each side of this component like a bread tie leaving the blown fuse in place. Then be sure to slide the rubber like insulation back over all of the bare metal so it is covering the black wire on both sides. If you don't it will short out and blow your house circuit breaker when you turn it on.
This thermal fuse was probably a requirement of the UL Listing. Its over kill, everything in there is metal so if it over heats in that area there is nothing flammable to burn. If a run away temperature occurs the wire itself will melt, short out and trip your house breaker. There are stacks of these units brand new with this same problem anyone reading this is having, the thermal fuse is under rated, the fix is simple
Thank you for contacting Fixya.com
Posted on Nov 22, 2009
graemevm
  • 519 Answers
SOURCE: We made waffles this morning and the waffle stuck
I don't know what model you have but it most likely has a non-stick surface. This only lasts for a certain time before it wears off. Do you use oil or butter on the surfaces? Also, did the waffles turn out alright the last time you used it? If they were fine the last time try making the batter once more and make sure you follow the recipe exactly as it was made the last time it was successful.
Let me know what the outcome is.
Best wishes,
Graemevm
Posted on Jan 10, 2010
justinbur167
  • 257 Answers
SOURCE: i bought the waffle iron
Hello Anyduckfood,
I understand that you purchased a Waffle Iron at a church thrift shop you did not receive the directions or any type of recipes for the unit.
Most waffle irons are set up to cook a waffle in one minute. They take a few minutes to heat up like about 5 and then you may cook with them. You generally use a nonstick spray (pan, etc) then put your batter on the lower griddle and close the upper griddle. The batter will expand to the upper griddle and make the shape of your waffle iron.
Recipes: there are many different places that you can find waffle recipes, here are a few links to recipes
http://allrecipes.com/Recipes/Breakfast-and-Brunch/Waffles/Main.aspx
http://www.waffle-recipe.com/
http://www.mrbreakfast.com/recipe_collection.asp?subcategoryid=5
to find more waffle recipes just type "Waffle Recipes" in a search engine of your choice and you will probable by amazed at how many different recipes there are.
Thank you for choosing FixYa.com
Justin
Posted on Mar 31, 2011
Testimonial: "THANK YOU!!!!! YOUR REPLY WAS CLEAR, - I CAN DO THAT! THANK YOU FOR RECIPE SITES. wow"
  • 794 Answers
SOURCE: i lost the book and
Hi teresa11,
You may download the Breville BB300 instructions and recipe book on this link. It was taken directly from Breville's website.
Hope it helps.
Thank you for using Fixya.
Posted on Apr 14, 2011
HansPP
  • 2510 Answers
SOURCE: My Belgian Waffle Iron does
Are you operating a 220 volt unit on 110 volts? Then it will not get hot enough.
Posted on May 14, 2011
I need to know how to use it. I didn't received any instructions (recipies) as such with the unit.
Visit the following website & there are many recipes available on the it.
http://www.microwaverecipe.net/
Many more recipes are available on some other websites. Some are downlaodable.
Aug 04, 2011 | Microwave Ovens
LOST THE BEATER TO MY ICECREAM MAKER
Here is a tip that I wrote that will help you with getting parts and manualsfor your Ice Cream Maker
Ice CreamMaker Parts, Instruction Manuals and Recipes
heatman101
Jul 24, 2011 | Microwave Ovens
I bought the waffle iron at a church thrift shop and there wasn't a manual or recipes
Hello Anyduckfood,
Justin
Mar 31, 2011 | Microwave Ovens
Can you help please, I cant use the breadmaker as have no recipe or instruction book, didnt come with the breadmaker, would appreciate if someone could email the pdf recipe and instruction book to allow me...
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Jan 07, 2011 | Microwave Ovens
I bought a Russell Hobbs Biscuit and cookie maker but there is no recipe book inside. Can you please tell me were can I find recipes and a instuction book
media.hirschs.co.za/pdf/Russell_Hobbs_Cookie_Maker.pdf You will find the instruction book here. Regards Liezl
Dec 03, 2010 | Microwave Ovens
I would like to buy a breville cappuccino maker but hear the dial at side gets stuck and breaks easily,even when cleaned well after use. Has this been rectified. Doreen
Hi, apparently Brita, that owns Breville, did not fix the problem yet.
I can see that complains keep coming.
The problem is apparently on CM8 and CM9, the more expensive Cappuccino Maker BES200XL
does not have the problem.
One suggestion, Breville are nice budget coffe maker, if you want to spend some mor money on a better product buy a Gaggia or something similar. Italian coffee makers are usually the best for espresso/capuccino. If you want a Breville buy the ESP8XL Espresso Machine.
Here is another good brand.
Sep 13, 2008 | Microwave Ovens
Recipe book for breville microwave with grill not included when bought.
You can try calling 0161 621 6900 or use the e-mail form here or contact the dealer where you purchased it for either the cookbook or a better number for Breville.
Good luck.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 23, 2008 | Microwave Ovens
Microwave Ovens Logo
344 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
