My bush lcd32tv009hd wont work after moving houses.The light goes green as it should be but no sound and picture onlyblack screen. What is causing it and how to fix it?
  • 998 Answers
Some parts may be loosed try to reinsert the connectors.
Posted on Oct 11, 2010
  • netka88 Oct 11, 2010
    My boyfriend have me his Tv while he is away doing his training. I dont know anything about Tvs :(
    We tried connecting and disconnecting from the socket million times but still not working.
  • Noel Jucutan
    Noel Jucutan Oct 12, 2010
    did you open the back of your tv try to open it you will see connectors that connecting in the mainboard try to reinsert the connectors but be sure to unplug your tv before doing it and be very carefull.
Bush lcd32tv009hd
Could be a bad connector on the set or a bad cable.
It could also be a bad circuit board. If the connections are good, take it to a repair shop.
Apr 03, 2014 | Televison & Video
My bush lcd32tv009hd wont turn on. red standby light comes on and then green power light when turned on via remote or set. what is causing this?
Good day!
That problem is 2 causes,its either power supply or system board.
This are some D.I.Y procedure for troubleshooting.
  1. Open the back cover by removing all screws at the back.
  2. Try to look at the power supply board and find the leak/bulge on top capacitors.If you found,replace it with the same type and ratings.
  3. If the power supply doesn't have any leak capacitors.Try to power it ON to perform voltage checking.
  4. Check the output voltage of power supply such as 5vdc,12vdc and 24vdc by using voltmeter.If this 3 supplies having a voltage drop or flickering voltage while on power ON.Check the following parts on the power supply,change value/open resistor,shorted transistor and diode or repeat step # 2.
  5. When the output voltage is stable and all parts looks OK.The problem could be on system board.Unfortunately the system board or main board is not for D.I.Y because the parts inside is very logic and very sensitive.That is replaceable.
Thank you and good luck.Please don't forget to rate my answer.
May 09, 2011 | Televison & Video
TV WONT COME ON AND THE LIGHT KEEPS FLASHIN RED AN GREEN ON THE STANDBY BUTTON
  1. If your Sony Wega will not turn on, the front green light blinks, you hear a faint whirring sound and the green light turns red and flashes, it probably means the lamp inside the set is no longer working. If you noticed the screen beginning to dim in the preceding days or weeks, this most likely is the cause.
  2. If the green light flashes and the picture comes on momentarily but then goes off, and the green button flashes until the set restarts, then the seal around the lamp mount is loose and needs to be refitted.
  3. If the picture on your Grand Wega cuts in and out and the green standby light flashes, both of the set's STKs need to be replaced. STKs are small chips on your television's circuit boards and are identifiable by their labels. The specific STKs used in your Grand Wega TV will be identifiable by the numbered labels on top of the STKs.
  4. When you plug in your Sony Wega and hear a loud popping sound, it's probably caused by a defect in the high-voltage circuit. Let the professionals take care of this one.
  5. If, after turning on your Sony Wega, you can hear your set but the screen is black, you most likely need to replace your projection lamp.
Read more: How to Troubleshoot a Sony Grand Wega ' eHow.com http://www.ehow.com/how_5243554_troubleshoot-sony-grand-wega.html#ixzz1EoY37gpC
Feb 23, 2011 | Sony Grand WEGA KF-42SX300 42" LCD TV
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
Bush lcd tv has sound but no picture when switch on tv screen is blue then goes black and you can hear the proggramme that is on
acoustic solutions lcd tv when i switch it on the screen flashes blue, green then red no picture??? it was working ok last night any ideas?
Jan 23, 2010 | Polaroid FLM-2632 Television
I need an instruction manual (user guide) for a Bush T.V. model no.15w0084d
i have bush lcd32tv009hd and tv come out of standbay but no pictures
Sep 17, 2009 | Televison & Video
Samsung hl-s6186 screen flickers and sometimes goes green
The humming will usally come from the color wheel(one of the only moving parts), which is part of the light engine. If the tv is starting to get a green picture that is a sign that the light engine is on it's way out.
Aug 05, 2008 | Samsung HL-S6187W 61 in. HDTV
Televison & Video Logo
196 people viewed this question
Top Televison & Video Experts
Electro Med Services...
