Question about Pioneer Audio Players & Recorders
Pioner stereo tuner CX-770S, display light does not work.
freetek
  • 5568 Answers
SOURCE: Have not had my stereo on in months, and the power
Depending on how it was stored (temperature controlled?) it can be damaged while stored although I suspect the power supply is just refusing to start up. You didn't list the model number so I can't check to see if it uses a switched-mode power supply. If it is relatively new, it probably does and they can be finicky if using cheap capacitors in the wrong areas.
Posted on Jan 04, 2010
Coby cd troubleshooting
Coby outta business - bankruptcy. Cannot get parts so ..............
Jul 31, 2016 | Coby CX-CD377BLK Micro CD Player Stereo...
Marantz tuner 120 stereo light will not come on,
Probably it is suffered by over aging. You need a skilled repairman.
Oct 01, 2014 | Marantz Audio Players & Recorders
The stereo light on my marantz 2226b receiver does not come on even on a stereo fm station
my first question is does the light come on when you turn to Tape, Phono, Aux selection? If no lamp is blown, if it does come on then your tuner need to be serviced. FM tuner work is NOT for a novice. I would be glad to take a look at the unit.
Thanks
www.back2lifeelectronics.com
Sep 23, 2012 | Marantz Audio Players & Recorders
What color wire goes were on a pioner super tuner deh-10 i cant get the lights on the tuner to come on or when i have it wired every thing works but no lights and it wont take in the cd it will when i push...
unplug all wires and try these basic ones.red(power/ignition), yellow(power/battery voltage), and black(negative/ground). connect all those, and try to power it up and insert a cd. if it still gives you the same problem, then the radio is bad.
Feb 16, 2010 | Car Audio & Video
Have not had my stereo on in months, and the power lite will come on, but the tuner display wont' light up and nothing will work on it. It's been in storage and no way it could have gotten fried. The fuse...
Jan 04, 2010 | Aiwa Audio Players & Recorders
93 Suburban Stereo problem
could be a short. you are going to have retrace power wire ,start at fuse box woke way towards with no power first . take your time try not to get to mad you will find it good luck later
Apr 01, 2009 | 1993 Chevrolet Suburban
TUNER PROBLEM
probably you blocked dont worry unplugg it wait 2 mins and if your device has a reset switch just push it while you connect it. this most solve blocked devices....saludos
Nov 18, 2008 | Samsung HTQ100 Shelf System
My pioner stereo is wired up and the only way i can get it to play is to turn my head lights on. is there another way to hook it up.im loosing all of my settings when i turn off the lights. all the wi
first take a test light hook it up to ground metal of carfind witch wire got power when you put the light on disconnect the wire and find a wire that gonna work when you put the ignition on maybe in the fuse box be carefull not to hook it up to direct battery it gonna work but if you forget the radio on it gonna drain our battery cheers
Jan 13, 2008 | Pioneer DEH-P6600 CD Player
545 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Dennis McCollum
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
