SOURCE: trips out electric
check the wireing on the oven supply line check the breaker it may bu too small or week check ehere the cord is attached to the range most of the time this is where the promblem is
SOURCE: Belling XOU252 Single Oven Trips Fuses Repeatedly
Hi.
Probably a faulty element, if you feel competent enough, disconnect the feed to the elements in turn, this should eliminate the problem.
Good luck.
SOURCE: We've inherited a belling electric double oven.
seems the heating element burnt out, inspect it for small melted section, element needs replacing, about 25$ at hardware store
SOURCE: belling oven xou592 bottom fan oven not heating up
You need to fit a new oven element.
This is located at the rear of the oven behind a removeable cover, where the fan is
It is a fairly straightforward job to replace.
Hope trhis helps with your problem.
Testimonial: "Thanks very much , wasn,t sure whether thermostat could be at fault so this has helped. Will buy an element and fit and let you know outcome. Thanks "
