Question about Pool & Spa
My waterco pool pump was working fine yesterday but now when you turn it on makes a buzzing sound and shuts down after a minute or so.
    President:
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
It could be the pump is bound up but it is more likely the motor is failing. It may be a small part such as the capacitor or the starting switch, but could also be more severe such as the winding itself. You will also want to examine the shaft where it passes thru the pump and motor and look for signs of rust from a pump seal leak.
If you are not familiar with testing these parts your best bet would be a local electric motor repair shop to see if the motor can be repaired or if it would need to be replaced. They should also be able to ensure there is no pump damage.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Oct 11, 2010
I have a waterco pump and sand filter and can't get a high flow thru the pump to operate the creepy crawly
see if it works on recirculate if it does change sand or backwash if suction based and you have multiple inlets close the ones not being used if it is connected to a pool return close the other return valves or plug them while cleaning
Sep 14, 2015 | Waterco Pool & Spa
Heat Pump comes on, fans slow down, switches off?
Sounds like a bad temp sensor or switch. Like in cars my guess is that the switch is failing to work causing the fans to stop despite the pump getting hot.
Jun 23, 2014 | Aquacal ICEBRKR HEAT/COOL 110K TITANIUM...
Why is my Jandy JHPU pump motor Struggling to start up
sounds like motor is going need a new motor dont forget to change the seals
May 20, 2014 | Jandy PUMP SHAFT SEAL - FITS PUMPS
Waterco Aqua Heat Titane 101, The Fan Come On But Compressor Does Not KickIn?
make sure your filter is clean, heat pumps are fussy about too much back pressure. you might try it with the filter cartdrige renoved
Sep 21, 2013 | Waterco Baker Hydro 80K Btu Titanium...
Fan Runs But Compressor Does Not kick In Waterco Aqua Heat Titane 101
I had the same problem last week. I called a technician who found out that the capacitor was defective. Cost 50$ + the service call.
If the capacitor is working, it might be the compressor...
Pool Pump Runs Intermittently (~10 seconds on, ~1 minute off)
Need more info. What is the voltage at the pump? What voltage is the pump wired for? Sounds like your pump is shutting down from heat thru a safety. If the voltage is wrong the pump will heat up very quickly and a thermal switch will cut out, it will then cool off and try again. Get the readings at the motor connections NOT the breaker.
Apr 02, 2017 | AO Smith A O Smith Motors Century 1hp 115v...
Pump motor makes burring sound then turns itself
could be the start or run cap. its a hard pump to find parts for
Jan 06, 2010 | Electronics - Others
Intex pool filter/ pump just stopped working
Try giving your pump more air circulation.
Turn off pump when not around it.(should only need to run for around 3 - 4 hours on a small (kid) pool 6 - 8 hours for standard house pool
You could put you pump on a timmer - set shut off time to just before you pump shuts down.
Check you pump (when not conected to mains power) - get some WD40 into it - (salt and metal no like each other)
Jun 09, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Pool & Spa Logo
194 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
