Question about Franke Plumbing
I have a Franke faucet MH 280 model. Cold water is dripping so I'm trying to locate the parts I may need to replace.
  • 37 Answers
SOURCE: tub faucet drip
Hi, You have to replace the two rubber cups in the hot&cold faucet lever. Let me know if you need more info.
Posted on Nov 09, 2008
arealplumber
  • 33 Answers
SOURCE: low pressure and flow on hot water side of single handle faucet
It could be one of two problems, one simple, one serious.
  • Easy fix
  1. Turn off hot water angle stop under sink to faucet.
  2. Remove supply line from hot angle stop.
  3. Place end of supply line in a small bucket to catch some water.
  4. Turn on cold water for a couple of seconds and backflush debris from faucet.
  5. Reconnect supply line.
  6. Turn on angle stop and test
  • Complex fix
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
Posted on Dec 05, 2008
  • 244 Answers
SOURCE: No Cold Water from Kitchen Faucet
call moen for new cartridge
Posted on Jan 18, 2009
jj505
  • 195 Answers
SOURCE: no hot water
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
You will find a quicker answer and free parts for your bath room faucet at link above . I am sure it is the mixer valve assembly. If you are not a plumber I suggest a pro be called.
John
Posted on Mar 16, 2009
jj505
  • 195 Answers
SOURCE: single handle pull out Franke faucet stopped working
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
Thanks and Please Rate jj505
Posted on Apr 06, 2009
Constant drip of water on my Franke manor house gooseneck bridge faucet. how do I repair the faucet from dripping water?
Check the washers and o rings that are a part of the faucet assembly. If possible tighten fittings.
Aug 23, 2017 | Franke Plumbing
My Franke FF-200 faucet does not swivel -
get the water main turned off , drain faucet then take top of tube off carefully. get a tub of vasoline and grease it put it back together and turn on water
Feb 13, 2015 | Franke Plumbing
LB2280 leak
If this is instant heat faucet, then contact manufacturer.
Most these faucets have 1 year limited warranty
Replace faucet?
http://waterheatertimer.org/How-to-install-point-of-use-water-heater.html
Gene
Water Heater Timers Save Money
Dec 02, 2014 | Franke LB2280 Instant Hot and Cold Water...
I need a Franke faucet model # FF 822
I would try E-bay. Might also look for a rebuild kit. A last resort: Take it apart clean all the parts and then reassemble. Good luck.
Apr 01, 2014 | Franke Plumbing
It sprays fine but off the spray thair is no presuser . we replaced the water lines in the house we have good preasure though out our home jest not at the kitchen sink
One of the greatest things about Franke Faucets is that they have a lifetime guarantee. If you recently changed the waterlines in the home then more than likely when the water was turned back on or lines pressurized the settlement in the water main (Outside of your home) was activated and clogged the aerator. Most aerators simply turn counter clockwise (With the water off) after remooving the aerator simply clean and dislodge any particles in another sink. As for the pull out, some models have an inline screen located between the hose and the faucet handle. Simpy remove the handheld faucet (With the water off) and clean the screen.
Feb 02, 2011 | Franke FF-303 Kitchen Faucet with...
Single handle pull out Franke faucet stopped working
Apr 05, 2009 | Franke Plumbing
I have a franke filtered water faucet and it is leaking
I have a similar problem and while I've gotten further along than you have, I still don't have the complete solution. The little "ceramic" disk that says "Franke" on the knob does come off. It's just well glued on and requires destroying two x-acto blades and putting some large chips in the logo disk to get off. Once you get the disk off you'll discover that the knob requires a special tool to remove. I haven't been able to locate one but usually when you buy a replacement washer/gasket set it will come with the special wrench to remove the fastener from inside the knob. So if you locate a faucet repair kit for that faucet, let me know!
Mar 28, 2009 | Franke Plumbing
Tub faucet drip
Nov 09, 2008 | Banner Faucets Pro Series M580 Single...
Franke Little Butler instant hot water dispenser
I have the same unit and had a similar problem. If yours is the same as mine, look at the top of the water heater unit. The center spigot is for the for the how water outflow which is connected to surgical type rubber tubing. The hot water eventually dried out the tubing and it cracks, causing it to leak. I had to cut out the decayed portion and replace it. Franke sent me a replacement kit at no charge but I did replace the fitting on top of the unit. The fitting is a standard nipple that any HW store should carry. Mine is a female-to-female reducer that then mates to a nylon barbed fitting which the tubing goes into. Importantly the Franke supplied kit has nylon ratcheting hose clamps that keep the tubing in place as well as a barbed union with hose clamps to join to the exisiting hose feed (to the faucet).
Hope this helps! I'm now struggling with the hot water tap leaking after using it. It seems to stop after a while but it drips for some time. If you can help me there that would be great!
Apr 13, 2008 | Franke WD751B GPS Receiver
Plumbing Logo
118 people viewed this question
Top Franke Plumbing Experts
Jim Parker
Jim Parker
richie46
ray gallant
Are you a Franke Plumbing Expert? Answer questions, earn points and help others
