Question about Whirlpool Refrigerators
I have whirlpool refrigeration model qwick chill 220 elite .the problem is door not properly close so water doesnt cool .
joboo1
  • 257 Answers
SOURCE: Refrigerator Door not closing properly
Hi, No the door is not adjustable like you might think Since it is smaller than the other door any alignment problem is really visible. First do check the bracket to make sure you didn't lose a screw and that the brackets are solid and don't move. The problem is the level of either the refrigerator or the floor. If you have a 3 ft bubble level put in on the top of the refrigerator along the front, NOT on the door. There are feet on the bottom front corners of the refrigerator, you may have to remove the plastic grill to access them but depending on the model and age of your refrigerator it should be attached with clips. The feet screw in and out but with weight they won't move easily so you may have to jack the front a little, remove some stuff or try a crescent wrench. Once the front is level check the front to back, the refrigerator needs to tilt slightly to the rear so the door when partially open will close by itself. Again you didn't give a model so on some the rear feet are not adjustable and some are. I suspect you may have adjustable and the box is not squared up. If after adjusting the front and the entire refrigerator tilts like an uneven table leg then you have to adjust the feet likewise. Use your level diagonally across the top both directions, it should be exactly the same. If you have non adjustable and they are uneven it is the floor and you have to use shims under the low foot. Good Luck!
Posted on Jan 30, 2009
freetek
  • 5568 Answers
SOURCE: Refrigerator and Freezer Not Cooling nor Freezing
That leaves only one possible fault; the volatile component of your coolant/lubricant has escaped.
If the unit has been moved or cleaned carelessly, one of the coolant- bearing tubes has developed a leak. Any refrigeration tech will have a leak detector in his tool set so it shouldn't be difficult to find.
Depending on the area in which you live, expect the troubleshooting and recharging to run ~$150-$250 US.
If you reside in the US, check your local (area) Better Business Bureau for a trustworthy service company.
Posted on Mar 16, 2009
kram26
  • 544 Answers
SOURCE: Refrigerator is not cooling properly/fan is not running
HI,
The click and hum your hearing is most likely the compressor trying to start. The most common problem is a bad start relay on the compressor. In rare cases the compressor may be bad. If you are mechanically inclined you can replace the relay yourself for less than 50 dollars. You will need model and serial number off of the unit and order the part by those numbers. if the compressor is bad you will need to hire a good service company
anu further question don't hesitate to contact me.
thanks,
Posted on Mar 24, 2009
  • 22 Answers
SOURCE: My whirlpool refrigerator (Model ET18DK) does not cool
Most likely one of two conditions are the root of the problem. Either the fan in the freezer is stalled or the defrost system has failed. The fan in the freezer should run any time the comressor is running; if it's not, there's your problem. If you can hear the fan, check for frost or snow developing across the back panel in the freezer. Local repair service could probably supply replacement parts quickly for defrost failures (most likely a bad terminator if defrost system isn't working).
Posted on Apr 25, 2009
bobicehouse
  • 1524 Answers
SOURCE: i have whirlpool icemagic FF 350 Elite
Check the relay inside the little black box on compressor.
Posted on May 07, 2009
Why is water coming out onto the floor and the drip pan is dry
items touching the side walls
refrigerator tilted forward
door not closing properly
faulty door seal
unit not cooling properly
Feb 15, 2016 | Whirlpool Refrigerators
Ice maker not working just changed the filter water works but ice maker not working
Check the plastic lever on the door. It usually moves closed when the door is shut to turn ice maker on. The lever can freeze and stop the ice maker.
Sep 23, 2013 | Whirlpool Gold GI6FARXXF 25.5 cu. ft....
Ice maker kitchenaid super ba is not working . Chilled water dispenses but no water seems to enter ice maker.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | KitchenAid Superba KSRG25FK Side by Side...
CSCP5UGXSS water temp
Hello dharitos1. I understand you are concerned about the temperature of the water in your refrigerator. Since the line runs through the door, the water will be slightly chilled, but will not be cold. You may need to run the water through a couple of cycles to get the chilled water. This is normal. I hope this information is helpful. Sincerely, Melanie, Whirlpool Social media group.
May 24, 2012 | Whirlpool GS6NBEXR Side by Side...
My whirlpool fridge makes a loud humming noise when the door is closed. It is not freezing items in the freexer and is not cooling items in the fridge section. The freezer is above the fridge section in...
The fan is hitting ice build up...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 11, 2010 | Whirlpool Refrigerators
The Whirlpool side-by-side refrigerator, model ED2KVEXVQ01 occassionally leaks water onto the floor. There could be a cup or more of water, but the problem has occurred a few times, but may go weeks or...
sometimes we overload our refrigerators and the doors will not close properly, next time you notice the water see if your doors are closed tightly and the seals engaged tightly. My wife has this habit of not checking after she has put away the remains of a big dinner or BBQ and I find drips of condensate water all over the floor as a result. The defrost collection pan overfills and the excess water goes on the floor. once the doors are closed properly the problem goes away.
Aug 03, 2010 | Whirlpool ED2KVEXVQ (217 cu ft) Side by...
Older (20 to 25 years old) non-frost free Whirlpool refrigerator is not cooling below 60 degrees. I defrosted it and left it off with doors open in garage for 10 hours. Turned the cooler knob to 4...
Good day,
If it is a conventional refrigerator, there should be a cooling plate on the top back of the wall in the food section.
Assuming the door fits and closes properly, and the light goes out when the door closes, the plate described above should have a frost pattern on it. That is what cools the bottom fresh food section.
If left on for plus 12 hours normal cooling should exist.
If the plate is not frosted, and the machine runs constantly, you have a freon leak with no real practical repair possible.
You could recharge it, but it would be pricey, and just repeat the problem shortly.
Jun 16, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
My Whirlpool side by side is having issues. The refrigerator is not cooling although I have set the settings to 5 (coolest). My freezer is over freezing with big chunks of ice every where. What is the...
Hmmmm, chunks? Are the doors properly aligned? Closing completely? dispenser chute door closed? if so may have frosted the airway to the refrigerator and blocked it. I would totally defrost it and check again.
Jun 11, 2009 | Whirlpool ED2FHEXN Side by Side...
Chilled water stopped .chiller frozen in bottom of fridge
SR-32 EMB MODEL, FREEZER OK, BOTTOM NOT COOLING PROPERLY. ADVICE SETTINGS
May 28, 2008 | Refrigerators
Er dh ken bot.fridge. 795.77552600
one thing to try first is make sure there is enough air flow in the freezer and that the airway between the freezer and refrigerator's is free and clear
Mar 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
19 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
