Question about Candy Dishwashers
I have a candy cdi 3515 and after about 1/2 an hour into the programme it stops and a continuous alarm bleeping starts.
  • Candy Master
  • 3,247 Answers
Is there water in the dishwasher when it stops?
Are you able to check if the water is normal temperature or warm/ hot?
Can you try the dishwasher in a short cycle and see if it completes the cycle?
Posted on Oct 11, 2010
  • 1 more comment
  • Will Johnson Sep 29, 2011
    HI, I've got the same problem with my dishwasher. How did you fix yours in the end?
  • alberto Apr 12, 2012
    have u found a solution? same problem
    Have u found a solution? i've the same problem, same dishwasher. is the mainboard?
I am interested for answer too. My dishwasher Candy CDF 315A stops after some period of working, and fast blinked. There is water in, and on some other program it can finished job.
Please answer!!!
Thanks
Zed
Posted on Oct 18, 2011
  • Sam Oct 20, 2011
    It has been over a year when this problem was raised and I am not sure if the client actually got it working. However, from what you have mentioned, it is likely the heater or the thermostat are not working. Is the problem only occuring with the heavy cycles which use hot water? Is the water inside warm or normal temperature when it shuts off.
NEFF S5443X1GB/29 My dishwasher isn't completing it's full cycle. It seems to be washing ok, however towards the end of the programme instead of going quiet whilst drying and then gurgling quickly and a...
Does the drying occur? If the heaters are not working it may need the temp to be high this may stop it moving to the next part of the program ?
Nov 02, 2013 | Dishwashers
Candy Futura CDF 325 beeping alarm
Is there a sequence to the beeps?
Jun 04, 2013 | Candy Dishwashers
DISHWASHER GETS STUCK ON THE 1ST RINSE CYCLE
see the diagram attached.
1) Test the switch door,it is defective, the starting relais turn off, and consequenc the motor off.
2) TIMER: TEST FOR DEFECTIVE, clean contacts, repair wires loose, burn or broken.
God bless you
May 09, 2012 | Candy Dishwashers
1)My Candy DFI 50 is not washing properly, it leaves residue on the pots. 2)The programme controller on my DFI 50 seems to be sticking. Sometimes the dial doesn't move at all or takes 'hours' to run a...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Aug 09, 2010 | Candy DFI Plan Built-In Dishwasher
Too much bleeping
The alarm is caused by either temperature disorder, check on your thermostat settings, or it is being caused by unbalanced level of freon gas in the system, or the door of the freezer does not shut correctly.
Thanks
Nikunj Pattni
nikunj@qool-point.co.kr
Nov 17, 2008 | Liebherr Refrigerators
Machine emits continuous high pitched bleep and power light flashes blue/red
If working OK, probably means that the temperature alarm goes off because is getting hot the PC. I suggest to check why is that happening. All fans working OK? is the CMOS temperature alarm set too low? check your motherboard instructions booklet- It will tell you what the beeps mean probably in the last pages. Good luck
Sep 28, 2007 | Sony VAIO PCV-RX511 PC Desktop
Dishwashers Logo
1,392 people viewed this question
Top Candy Dishwashers Experts
 Evgeniy_Getz
Evgeniy_Getz
Charles T Nevin
Charles T Nevin
Are you a Candy Dishwasher Expert? Answer questions, earn points and help others
