Question about Stoves 900DFa Dual Fuel (Electric and Gas) Kitchen Range
I have a Stoves 900FA cooker and the problem is that when i turn on the oven, after a miunte the whole electric in my house switches off. I have to wait 10 miuntes before I can try to switch on my oven again...
4 Suggested Answers
aardvarkrepr
  • 62 Answers
SOURCE: Stoves 900DFa oven cuts out
Hi.
The most probable cause is failure in your panel cooling fan 9not the one inside your oven)
If the appliance switches on again after 15 - 20 minutes then the fault is most likely here.
Unfortunately as you have gas the you will need a Gas Safe Certified engineer to repair
Regards
aardvark repairs
Posted on Nov 18, 2009
Testimonial: "Very speedy answer! thank you."
  • 3 Answers
SOURCE: Top oven thermostat Stoves 800DF - fitting?
you dont need to remove the front panel, you need to undo the two black screws on the side of the hob unit, remove the two plastic plugs they went through allowing you to raise the hob, and remove just the back off the cooker this provides you access to all the areas you need you can then follow where all the cables go oh yes nearly forgot the thermostat is held in place by two screws you simply pull the knob off and there they are. ive just done the fan oven one and it seemed fairly straight forward, but please do remember to turn off the power to the cooker first all the connections push on using spade connectors, oh yes for legal reasons this is for information only and i wont be held liable for injury or damage caused by unqualified people following this information to fix it themselves as i would always have to recommend that you use a competant person ie a person who is trained, experienced and has sufficient knowledge to do the job, but those that do want to fix it do so at their own risk and i hope all goes well with getting the problem fixed
Posted on Mar 27, 2010
SOURCE: i am looking for a manual for my stoves newholme
i am looking for a manual for my stove panache 600 sidLm
Posted on Jul 08, 2010
Grill turns on when cooker is turned from the isolater,
I assume you mean if the main electrical isolation is switched to on , the grill/ upper oven heats up even though the grill / upper oven switch is correctly set to off ......if this is the case you require a replacement thermostat for the upper oven I believe these are now obsolete and the alternative comes as a kit part no. 012959401 to modify the wiring replace both upper and lower oven thermostats see instructions attachedcid:eb5fa66b-5b72-4dad-aafc-a1f3a691fb03
Jul 03, 2014 | Stoves 800DFDOm Dual Fuel (Electric and...
I have a stoves 720ef anf for no obvious reason the clock resets to 23.59 and the oven turns off, can you suggest anything
You obviously have a power loss somewhere. The oven will not work unless a time is set on the clock. I would suggest you have problem with the feed to the cooker which an electician should be able to check it out. If anything else is wrong on the cooker, it shouldn't reset the clock.
Nov 28, 2011 | Stoves 720EF Electric Double Oven
Stove Manuals. My electric cooker is named STOVES 720ef. I dont know how to work it
You're in luck.
I have just uploaded a scanned copy of the manual to the link below.
Requires an Adobe Acrobat reader to view the manual which most computers have.
This address is below:-
http://wl.filegenie.com/~simun/Stoves720EF.pdf
Please share this file with others who need it.
Kind Regards,
Simon
Oct 28, 2011 | Stoves 720EF Electric Double Oven
Moved house no manual to stoves cooker model 4444451 72oef
You will need to post an email address and then i will send you a pdf copy of the handbook.
Sep 02, 2011 | Stoves 720EF Electric Double Oven
I have a stoves cooker which was working fine until we upgraded to the seventeeth edition consumer unit and rcds. Now I have a negative earth fault.Rcd trips out, circuit is fine up to the cooker. Any...
The clue will be when the rcd trips out. If everything is switched off on the cooker with the exception of the clock when you power it up and then it trips out, it could be in the wiring to the oven from the control switch and or the wiring in the oven. The only way you are going to find this is to take the oven out of the housing and test the wiring, isolating components until you find the problem.
Jul 31, 2011 | Stoves 720EF Electric Double Oven
Hello, i have a stoves q720 grf do double oven and the problem is with the lower oven, after about 20 minutes the oven switches itself off and the lights on the front of the oven flash on and off. van...
I have the same problem. After anywhere from 5 to 30 minutes the oven(s) switch off and the light and clock start flashing - I have to switch the cooker on and off to start using the oven again.
Any resolution please?
Oct 07, 2010 | Stoves 720EF Electric Double Oven
Hi, we have had one of these ovens for 8 years (it was in the house we moved into). We had a new control fitted for the top oven (it took the repair company three tries to get the right part) and the problem didn't go away. To be honest, we can't stand this oven but are waiting until we replace the entire kitchen to replace it. The bottom oven is fine. The top oven is fierce and burns food all the time. Overall it's a ridiculous oven - I'd much prefer a sensibly-sized one that actually worked well! Rant over.
Jun 10, 2009 | Stoves 800DFDOm Dual Fuel (Electric and...
Stoves genus 900 will not switch on
I have a power supply for one and also a front panel dont know if this helps.
Jan 19, 2009 | Stoves 720EF Electric Double Oven
Stoves dual fuel cooker
if your qulified enough you need to bypass the timer electrically so as to put power direct to the oven
Nov 10, 2007 | Stoves 900DFa Dual Fuel (Electric and Gas)...
The cooker stays warm when mains cooker switch is on.
Either teh grill element or the oven heating element is fault or the thermostat or grill regulator, locate which element is warm, if the grill then it is most likely the regulator, if it is the oven it is the thermostat. Engineer
Jul 20, 2007 | Stoves 800DFDOm Dual Fuel (Electric and...
Stoves 900DFa Dual Fuel (Electric and Gas) Kitchen Range Logo
Top Stoves Kitchen Ranges Experts
paulcarew
Ismael Rodriguez...
wayne murphy
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
