Question about Garmin StreetPilot c550 GPS Receiver
Unit does not turn on
It worked just fine and I turned it off. I could not turn it back on. Charged it for a while, but it still does not turn on.
  • 11 more comments
  • djeez Jun 03, 2008
    Exactly the same; had it shut down after I stopped the engine of the car. Now it doesn't turn itself back on again
  • Anonymous Jun 14, 2008
    I hvae the same problem I just bought it from ebay three days ago and it worked fine till today I turned the car on and no luck with any power
  • Anonymous Jun 19, 2008
    Exactly the same problem - tried reset with no success.
  • AS448 Jun 28, 2008
    was entering an address, screen went blank, just does not come on again!!
    Worked great for 8 months.
    The screen is dark as night. I don't have any money for a new one and i moved to a new city 3 days ago.
    Help!
  • e0031 Jul 02, 2008
    Same problem
  • Anonymous Jul 17, 2008
    same problem after 2 days of use, and this is my second Garmin having this kind of problem
  • bart279 Jul 18, 2008
    unit shut off after using it for more than a year and will not turn back on.
  • haist Jul 22, 2008
    One day it works fine the next it won't turn on, even after charging. Is there a reset button or something? Had this for about a year. Tried holding in the power button, tried pushing the power button several times in a row, tried to find a reset button.
  • Hindenburg Jul 27, 2008
    I have had my Garmin C550 over a year and ran into the exact same problem....won't turn on afer shutting it off, even after it was working perfectly just hours before??? I see a lot of the same problems, but have yet to see an answer?
  • csuarez6 Jul 30, 2008
    Same problem
  • Anonymous Feb 26, 2009
    same problem. No fix yet.
  • lvmickey Feb 28, 2009
    My unit turns on, but goes black within seconds. Fuse is okay
  • mylaker Mar 01, 2009
    i have the same problm - turn it on and it s off within 30 seconds
    what do i do?
    laker
I had this same problem - the unit doesn't turn on.
I took the silver bezel off the front, and found that there were 4 screws holding the thing together, and that there was a reset button on the front. Reset button didn't do anything, of course, in my case, but after opening the case I found the culprit:
The board which has the charging unit, mic in, and line out on it, with markings
"MV11
94V-0", "172-7", and "01067-00 V8", had blown a component on the board - it was black right next to where the line plugs in for the speakers and the battery. Looks like there's a 6 pin tiny component which looks like a relay or a pROM like a SPD chip on memory. Unfortunately, I don't see any markings on this. I think a solution would be to get a similar unit which uses the same charging/IO board and swap it - bad/cracked screen would be a perfect candidate. The other way would be to figure out how to get the particular part from Garmin themselves, because I'm not really into fixing surface mount solder points.
Posted on Mar 03, 2009
Same problem for me today
Posted on Jul 02, 2008
My car won't turn on it was working fine last
Just because you charged the battery it doesn't mean it is any good. Modern sealed batteries fail; just as you described, fine one moment and then nothing, they go open internally.
Jul 19, 2013 | Cars & Trucks
Has been charged, but has no power, will not turn on.
mine did that aswell.checked out n tried solutions on this n other sites with no luck.i eventually just opened it to check the battery(unit 1yr old).batt was fine.when i put it all back together it works fine.assume that disconnecting battery is the mysterious reset button.hope this helps
Oct 14, 2010 | Garmin Nuvi 255 GPS Receiver
I have a sony cibershot camera for over a year now, it has always worked nicely, up until a month ago, it suddenly wont turn on anymore. I,ve already charged and re-charged the battery but nothing...
make sure the batt is charging and working fine.check also the batt contacts.make sure its clean.insert batt to your camera.instead of pressing the power button, press the play button instead to power camera on. if unit turns on,might actually be an issue w/the camera unable to power on in camera mode.if it turns on initialize cam (p.75 of the manual).see if it works.if still wont turn on try using a diff batt (or if you have an optional ac adapter model#acls5k use it, attempt to power on cam to isolate issue w/power source).if batt or ac adaptor not available try to check batt with another cam if possible to test batt. if still unit doesnt turn on using a fully charged, diff batt, or using an ac adaptor,unit would reuire service. hope this info helps.thanks:)
Apr 06, 2010 | Sony Cyber-shot DSC-H9 Digital Camera
Its charged. i turn it on and it chuts right back
1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 4. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 14, 2009 | Kodak EASYSHARE M1063 Digital Camera
My msi won't turn on. Battery is in, charged, and
Try unplugging it and removing the battery. Wait a few minutes. Yes actual minutes. Then put the battery back in and try again.
When you get back in try rolling back to a restore point when you know things were working well.
Could be a software update of some kind threw things out of whack.
Aug 11, 2009 | MSI Wind U100-004US Notebook
My Navman N40i won't switch on
turn it off at the bootom of the unit then turn it back on via the same switch. then pug in the charger and it should turn back on. it works for me when it happens to mine.
Jan 21, 2009 | Navman NavPix N40i GPS Receiver
TOM TOM 910 won't charge/turn on
there is a little push button on the back. use a niddle and push that down at the same time hold the power button. you will hear the unit turning on itself and then it should work fine
Aug 10, 2008 | Tomtom GO 910 GPS Receiver
Unit turns on for 5 seconds then shuts off.
I charged the unit and now it works fine. Plug into computer and charge for a while and the unit should work fine.
Mar 02, 2008 | Garmin StreetPilot c550 GPS Receiver
H500 does not turn on
take it back to the store. motorola sucks
Apr 02, 2007 | Motorola Mobility H500 Wireless Headset
Garmin StreetPilot c550 GPS Receiver Logo
272 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
