Question about Zanussi 23 in. ZKT641H Electric Cooktop
Hi, I've got a ZKT631DX and recently it stop to work and shows the error E3. I've followed the instructions on the manual, turn it off from the plug for a few minutes and connect it again, but it didn't work and it shows the same error E3.
E3 problem in Prestige induction cook top
That error means the voltage sensor has detected higher voltage then should be present. This means power supply is bad.
Mar 04, 2016 | Cooktops
My whirlpool (KitchenAid) induction cooktop works sometimes and other times will. The power comes on but when I try to turn on the burner it beeps and starts flashing. There are no error codes showing
It is likely the computer in the control board I have seen this many times. It is really hard to get the factory to think this cause it's new and it is expensive. But you have checked the power so there is not much more that it could be
Aug 07, 2017 | KitchenAid 30" Electric Induction Cooktop...
Induction cooktop-flashing keypad
Refer to user manual or company support, the keypad is giving you a error message of some sort, and it is dependent on the make and model on what that error message means so by referring to the manual or posting it would further help you in figuring out what the issues
Jan 27, 2012 | Cooktops
Recently i have purchased Prestige induction stove, can you describe what does E3 mean?
e 3 is error because of high voltage may be more than 30 kW at your house......it will not work with it u have to buy a voltage regulator for it........
Jul 16, 2011 | AEG 23 in. 6410KF-N Electric Cooktop
We got an E3 error message on induction cooktop(induction hob), AEG 88101 K-MN, which followed a popping sound. What could it be? We checked the braker and fusers.
Sorry to read about your problem, I hope this helps you out.
stop using and call a service company, before further damage occurs.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | AEG 23 in. 6410KF-N Electric Cooktop
I need instructions for wiring in replacing a dual burner switch on a CVE3400B cooktop. The replacement switch is different from the original. Do you have a diagram for the new switch that shows how to...
We followed the instructions that came with the switch that addressed a "compound wiring" configuration. We also used the black jumper wire as shown in the instructions.
We got to this solution in a trial by error manner though, because the three of us working the problem were convinced the stovetop was wired in a "piggyback configuration" and tried that road first. It would have been helpful if the instructions had included an explanation of the switch manufacturer's interpretation of "compound" and "piggyback" configuration.
Jan 09, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Child lock has come on and I have no instructions to get it back to normal
JUST HOLD DOWN THE CHILD LOCK BUTTON AND THE ON BUTTON SIMUTANEOUSLY FOR ABOUT A MINUTE OR 2. THIS SHOULD RELEASE IT
Aug 25, 2009 | Zanussi 23 in. ZKT641H Electric Cooktop
ERRORS on Electrolux Icon 30'' Induction Cooktop
Call Electrolux or go to their web site and explain the problem there tech department will be able to tell you if you need a service call or can fix yourself.
Oct 03, 2017 | Electrolux Cooktops
Zanussi 23 in. ZKT641H Electric Cooktop Logo
Top Zanussi Cooktops Experts
fyigen
Brian Coughlan
Tom Chichester
Are you a Zanussi Cooktop Expert? Answer questions, earn points and help others
